Fwd: Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Fri Jan 24 14:57:43 UTC 2020
This failed because the tools are old.
[joel at localhost include]$ sparc-rtems5-gcc --version
sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5 (d48abf49ab0a),
Newlib d14714c69)
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
[joel at localhost src]$ cd /home/joel/rtems-work/tools/5/sparc-rtems5/include/
[joel at localhost include]$ grep -r SOCKCLOSE
devctl.h: * definition of the subcommand SOCKCLOSE in <devctl.h>.
devctl.h:#define SOCKCLOSE    _IO('D', 1)    /* socket close */
--joel
---------- Forwarded message ---------
Date: Fri, Jan 24, 2020 at 8:52 AM
Subject: Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE
GCC 7.3.0 POSIX
To: <build at rtems.org>
The Buildbot has detected a failed build on builder CHECK sparc/erc32
FreeBSD 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
Full details are available at:
    https://buildbot.rtems.org/#builders/20/builds/49
Buildbot URL: https://buildbot.rtems.org/
Worker for this Build: build-1
Build Reason: <unknown>
Blamelist: Martin Erik Werner <martinerikwerner at gmail.com>
BUILD FAILED: failed make (failure)
Sincerely,
 -The Buildbot
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200124/c065c80f/attachment.html>
