"atsamv" BSP legacy network driver status
dufault at hda.com dufault at hda.com
Wed Jan 29 12:15:21 UTC 2020
> On Jan 29, 2020, at 03:13 , Christian Mauderer <christian.mauderer at embedded-brains.de> wrote:
> Hello Peter,
> On 28/01/2020 22:37, dufault at hda.com wrote:
>>> On Jan 28, 2020, at 04:46 , Christian Mauderer <christian.mauderer at embedded-brains.de> wrote:
>>> Before our customers migrated to libbsd (to get some of the features
>>> there) the driver in legacy worked. But that is a few years back.
>>> Currently I only know of applications using the libbsd driver.
>> How are you linking the libbsd code?  Where do you run the code from?
> May I start with a counter-question? Are you using an evaluation board
> or some custom one? Which chip variant are you using? All projects that
> I have been involved used one of the bigger chips (SAME70 or SAMV71).
I put the BSP configuration in the original posting but I clipped it out, I tend to like to clip.  It's the SAMV71 "Xplained" Ultra.
>> The application I'm testing doesn't fit in the internal SRAM provided by the default "linkcmds" in the libbsd case, partly because libbsd is bigger and partly because when I build for "libbsd" it needs "libblock".
> That depends on the project. One project where I can give you quite open
> information is GRiSP. That project is an evaluation platform for using
> Erlang on RTEMS. We did most of the initial the RTEMS stuff for it. You
> can find the basic RTEMS software here:
> https://github.com/grisp/grisp-software
> In this project we have a bootloader in the internal flash with some
> stuff in an SDRAM. See the linker command file for that:
> https://github.com/grisp/grisp-software/blob/master/grisp-bootloader/linkcmds.bootloader
> The bootloader doesn't have network support (I removed quite some bits
> with the "slim-down.h" file) but it uses libbsd for the SD card. It then
> starts a bigger RTEMS application from the SD card. That application
> uses libbsd for USB and WLAN. The application uses linkcmds.sdram from
> RTEMS.
>> It fits if I use "linkcmds.sdram", but then I can't run it because the SDRAM must not be set up properly at reset, I guess I'd need to come up with something using "openocd" that will set up the SDRAM before starting the program.
>> I then tried putting just REGION_START in internal flash but it fails when it jump through a trampoline to "system_init_flash" which was still in the SDRAM.
>> Then I tried using "linkcmds.qspiflash" but the program didn't fit again since more space was required in the internal SRAM.
> We have another project where QSPI is used. I can't give you all details
> but some basic information are possible:
> This project starts a Bootloader from the internal flash. The bootloader
> would then start an application from QSPI XIP area. But it can also use
> libbsd for networking. The linkcmds for the bootloader look like follows:
> INCLUDE linkcmds.memory
> REGION_ALIAS ("REGION_START", INTFLASH);
> REGION_ALIAS ("REGION_VECTOR", INTSRAM);
> REGION_ALIAS ("REGION_TEXT", INTFLASH);
> REGION_ALIAS ("REGION_TEXT_LOAD", INTFLASH);
> REGION_ALIAS ("REGION_RODATA", INTFLASH);
> REGION_ALIAS ("REGION_RODATA_LOAD", INTFLASH);
> REGION_ALIAS ("REGION_DATA", SDRAM);
> REGION_ALIAS ("REGION_DATA_LOAD", INTFLASH);
> REGION_ALIAS ("REGION_FAST_TEXT", ITCM);
> REGION_ALIAS ("REGION_FAST_TEXT_LOAD", INTFLASH);
> REGION_ALIAS ("REGION_FAST_DATA", DTCM);
> REGION_ALIAS ("REGION_FAST_DATA_LOAD", INTFLASH);
> REGION_ALIAS ("REGION_BSS", SDRAM);
> REGION_ALIAS ("REGION_WORK", SDRAM);
> REGION_ALIAS ("REGION_STACK", SDRAM);
> REGION_ALIAS ("REGION_NOCACHE", NOCACHE);
> REGION_ALIAS ("REGION_NOCACHE_LOAD", INTFLASH);
> INCLUDE linkcmds.armv7m
> For the application that is put into QSPIFLASH it's the following:
> REGION_ALIAS ("REGION_START", QSPIFLASH);
> REGION_ALIAS ("REGION_TEXT", QSPIFLASH);
> REGION_ALIAS ("REGION_TEXT_LOAD", QSPIFLASH);
> REGION_ALIAS ("REGION_RODATA", QSPIFLASH);
> REGION_ALIAS ("REGION_RODATA_LOAD", QSPIFLASH);
> REGION_ALIAS ("REGION_DATA_LOAD", QSPIFLASH);
> REGION_ALIAS ("REGION_FAST_TEXT_LOAD", QSPIFLASH);
> REGION_ALIAS ("REGION_FAST_DATA_LOAD", QSPIFLASH);
> REGION_ALIAS ("REGION_NOCACHE_LOAD", SDRAM);
> I hope that helps.
> Best regards
> Christian
This will help a lot.
Is the bootloader for the second project the same as the one in "grisp" but not slimmed down?
Thanks.  I should have sent this to "-users", maybe I'll post a summary there when done.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
