rtems-tester lock failure
Wed Jan 29 17:14:58 UTC 2020
Hi
I have seen similar failures before but Chris and I discussed it was likely
related to Python 2. Using Python 3, I am getting the following error:
+ /home/joel/rtems-work/rtems-tools//tester/rtems-test
--rtems-tools=/home/joel/rtems-work/tools/5 --rtems-bsp=leon3-sis
--log=run.log .
RTEMS Testing - Tester, 5 (4cb2ddc568b1)
[  2/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: linpack.exe
[  1/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: dhrystone.exe
[  6/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: fsdosfsformat01.exe
[  7/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: fsdosfsname01.exe
[  3/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: whetstone.exe
[  5/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: fsclose01.exe
[  8/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: fsdosfsname02.exe
[  4/594] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/leon3: fsbdpart01.exe
error: invalid test state:
./sparc-rtems5/c/leon3/testsuites/fstests/fsbdpart01.exe: EXPECTED_PASS
Exception ignored in: <module 'threading' from
'/opt/rh/rh-python36/root/usr/lib64/python3.6/threading.py'>
Traceback (most recent call last):
  File "/opt/rh/rh-python36/root/usr/lib64/python3.6/threading.py", line
1294, in _shutdown
    t.join()
1056, in join
    self._wait_for_tstate_lock()
1072, in _wait_for_tstate_lock
    elif lock.acquire(block, timeout):
Hopefully someone can reproduce this.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200129/d524522c/attachment.html>
