[PATCH 0/2] Add new Xen BSP target using GICv3 driver
Joel Sherrill
joel at rtems.org
Thu Jan 30 15:14:35 UTC 2020
On Thu, Jan 30, 2020, 9:10 AM Jeff Kubascik <jeff.kubascik at dornerworks.com>
wrote:
> On 1/28/2020 12:02 PM, Joel Sherrill wrote:
> > I have merged all of Jeff's patches. Please check that they work as
> merged
> > and do not introduce warnings.
> > Thanks.
> > --joel
> > On Thu, Jan 23, 2020 at 10:04 AM Jeff Kubascik <
> > <mailto:jeff.kubascik at dornerworks.com>> wrote:
> > This patch set renames the "xen_virtual" target to "xen_gicv2", and
> adds a new
> > "xen_gicv3" target that uses the GICv3 driver. This is the only
> hardware
> > dependency I have identified that a RTEMS virtual machine has with
> Xen on ARMv8.
> > The "xen_gicv3" target has been confirmed to work with Xen and ARMv8
> QEMU. This
> > required 3 patches to QEMU, which have been submitted to QEMU devel.
> As of now,
> > all 3 patches were accepted into master.
> > Jeff Kubascik (2):
> > bsp/xen: Rename xen_virtual target to xen_gicv2
> > bsp/xen: Add xen_gicv3 target
> > .../xen/config/{xen_virtual.cfg => xen_gicv2.cfg} | 2 +-
> > bsps/arm/xen/config/xen_gicv3.cfg | 14
> > bsps/arm/xen/include/bsp.h | 10 ++++++++++
> > bsps/arm/xen/start/bspstartmmu.c | 14
> > c/src/lib/libbsp/arm/xen/Makefile.am | 5 +++++
> > c/src/lib/libbsp/arm/xen/configure.ac <http://configure.ac>
> > 10 ++++++++++
> > 6 files changed, 54 insertions(+), 1 deletion(-)
> > rename bsps/arm/xen/config/{xen_virtual.cfg => xen_gicv2.cfg} (82%)
> > create mode 100644 bsps/arm/xen/config/xen_gicv3.cfg
> > 2.17.1
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> Thanks Joel! I've tested the build using your rtems repo and the xen_gicv3
> build
> still works. I've also compared the build output before/after the changes
> could
> not identify any new warnings.
Thanks for the feedback!
> Sincerely,
> Jeff Kubascik
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200130/3b851c3b/attachment.html>
