[PATCH 0/3] [rtems-libbsd] Fix compilation for i386
Jan Sommer
jan.sommer at dlr.de
Fri Jan 31 17:26:46 UTC 2020
Hello,
I assembled a patch set which enabled building rtems-libbsd for
i386-based BSPs again (currently without dev_nic_e1000 enabled).
It's my first patch set for rtems-libbsd, but I tried to follow the contribute guidelines as close as possible
I also have a similar patchset for amd64 in preparation which I can finalize after this
one has been merged.
Best regards,
Jan
Jan Sommer (3):
i386: Add missing files from FreeBSD
i386: Add to build
i386: Port to RTEMS
freebsd/sbin/sysctl/sysctl.c | 10 +-
freebsd/sys/dev/pci/pci_pci.c | 2 +
freebsd/sys/i386/include/machine/bus.h | 6 +
freebsd/sys/i386/include/machine/cpufunc.h | 2 +
freebsd/sys/sys/mbuf.h | 2 +
.../sys/x86/include/machine/intr_machdep.h | 175 +++
freebsd/sys/x86/include/machine/legacyvar.h | 73 ++
freebsd/sys/x86/include/machine/metadata.h | 57 +
freebsd/sys/x86/pci/pci_bus.c | 4 +
freebsd/sys/{i386/i386 => x86/x86}/legacy.c | 72 +-
libbsd.py | 7 +-
rtemsbsd/include/machine/bus.h | 783 -----------
rtemsbsd/include/machine/clock.h | 3 +-
rtemsbsd/include/x86/bus.h | 1109 ++++++++++++++++
rtemsbsd/include/x86/legacyvar.h | 1 +
rtemsbsd/include/x86/metadata.h | 1 +
rtemsbsd/include/x86/specialreg.h | 1143 +++++++++++++++++
rtemsbsd/include/x86/x86_var.h | 145 +++
waf_libbsd.py | 2 +-
19 files changed, 2784 insertions(+), 813 deletions(-)
create mode 100644 freebsd/sys/i386/include/machine/bus.h
create mode 100644 freebsd/sys/x86/include/machine/intr_machdep.h
create mode 100644 freebsd/sys/x86/include/machine/legacyvar.h
create mode 100644 freebsd/sys/x86/include/machine/metadata.h
rename freebsd/sys/{i386/i386 => x86/x86}/legacy.c (89%)
delete mode 100644 rtemsbsd/include/machine/bus.h
create mode 100644 rtemsbsd/include/x86/bus.h
create mode 100644 rtemsbsd/include/x86/legacyvar.h
create mode 100644 rtemsbsd/include/x86/metadata.h
create mode 100644 rtemsbsd/include/x86/specialreg.h
create mode 100644 rtemsbsd/include/x86/x86_var.h
2.17.1
