Requirement Document generator tool
Gedare Bloom
gedare at rtems.org
Fri Jan 31 18:44:38 UTC 2020
On Fri, Jan 31, 2020 at 12:39 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> On 30/01/2020 23:13, Chris Johns wrote:
> > On 30/1/20 8:35 pm, Christian Mauderer wrote:
> >> On 29/01/2020 23:48, Chris Johns wrote:
> >>> On 29/1/20 7:40 pm, Christian Mauderer wrote:
> >>>> On 28/01/2020 23:15, Chris Johns wrote:
> >>>>> On 28/1/20 10:22 pm, Christian Mauderer wrote:
> >>>>>> I'm quite indifferent which style we use
> >>>>> But you are arguing a position, such as ...
> >>>>>> but do you really think that it
> >>>>>> is a good idea to roll our own RTEMS-Python-style instead of using one
> >>>>>> of the big ones (like PEP8, Google or some other that might is a better
> >>>>>> fit for existing code). Rolling our own would lead to:
> >>>>>> 1. Long discussions about what is THE RIGHT STYLE (already started in
> >>>>>> this mail).
> >>>>>> 2. A lot of problems that there is no tool that formats or checks
> >>>>>> whether code is in THE RIGHT STYLE.
> >>>>>> 3. More discussions later because some other developer thinks that THE
> >>>>>> RIGHT STYLE is wrong.
> >>>> You are right that I argue against home-grown styles. I learned that
> >>>> style discussions are quite similar to religious discussions. Everyone
> >>>> beliefs that his style is the only right one. Using a big one makes it
> >>>> simpler to avoid discussions because a lot of people know it.
> >>> And yet you inherit issues a large organisation cannot correct because
> >>> historically a style is difficult to change and they are wedged. They need to be
> >>> reviewed and evaluated.
> >> That's why I originally thought of defining a style for _new_ code with
> >> an optional _slow_ migration if some existing code is touched. Of course
> >> the style should be compatible with the views how the old code should
> >> look in the future too.
> > I do not think this works as I pointed out earlier. We leave a libaility in the
> > old code that someone needs to clean up or we just ignore the rules for the old
> > code. Either are not great.
> I agree that it's not a great solution. But we have existing code. And
> like you said yourself: It's not a good idea to just blindly reformat
> it. And I assume even if it would be in the scope of some project, we
> wouldn't entirely trust a new developer to do it right because we don't
> know how careful he works.
> >> The patches were just for an estimate how much
> >> influence the suggested styles could have. I would never expect that any
> >> big patch with automated changes would be acceptable without a thorough
> >> review. I wouldn't accept that myself.
> > I understand this.
> >>>> Please don't get me wrong: I'm OK with another style too. The relevant
> >>>> result is that we have _one_ style in RTEMS that can be automatically
> >>>> checked.
> >>> I find it interesting this view is OK for Python and the tools and yet we do not
> >>> have automatic checking for the score's C. Or do we?
> >> It would be great if we would have automatic checking for C too. There
> >> are big projects that have something like that and it's really
> >> convenient. For example for Linux before you send a patch you can just
> >> run "./scripts/checkpatch.pl some.patch" and it will give you everything
> >> you should fix before sending it to the list. That removes at least one
> >> round of review.
> > My point is taking say Google C or C++ coding standard and applying it to the
> > score. I would prefer we wrote up the rules we have in place and check those.
> Ah OK. I missed your point. In that case: I'm a bit torn. I wouldn't say
> that it is always a bad idea to migrate to some adapted style rules if
> there are good reasons to drop the old ones (except from a revision
> control system view where such changes are always annoying). But please
> also note that the differences would be a lot bigger.
> I counted the lines in the files that I touched with the formatting tool:
> wc -l `find -name "*.py" | grep -v "patch-gdb-python" | grep -v "tftpy"
> | grep -v "asciidoc"`
> It's a total of 18193 lines. The patch touched about 3000 of them. So
> it's not a small part but it's not everything either. I assume that we
> can reduce it as soon as we worked out some rules and solutions for
> formats that can't be touched to the extend that these coding standards
> would.
> For RTEMS score and nearly every C coding style I know it would be more
> of 90 to 100 percent of the code due to the indentation style alone.
> >> But I think implementing that would be a lot bigger task than the one we
> >> are just discussing. One of the first problems would be finding a style
> >> checker that can produce _exactly_ the coding style that is defined for
> >> score.
> > Agreed.
> >> And also I'm happy to discuss approaches for something like that
> >> it would start to be of-topic for this thread. So if you want to discuss
> >> details about automatic style checking for score we should create an
> >> extra topic. Maybe we could even create a GSoC project for something
> >> like that?
> > That is a good idea. Would you like to raise a task ticket?
> I can do that. I think it could be a nice project. If it works we gain
> quite a value from it. If it doesn't work we don't lose anything.
+1 as a potential GSoC project. Please ping me with the ticket # so I
can review it.
It could also explore different ways to accommodate Python style
variations, perhaps to help define a "minimally divergent" rule set
that intersects current rtems python use with some well-known styles.
> >>>> That also will make patch review simpler because we as
> >>>> maintainers don't have to do the style review by hand.
> >>> This is often more about those coding than those reviewing.
> >> Sorry, I think I don't fully understand you here.
> > The reviewers often know the rules and can code to them, it is those writing the
> > code that do not and need the help. A formatter helps them.
> OK. I agree here. That's about the same that I said for the linux
> checkpatch.pl script. It's really convenient to avoid basic bugs.
> >>>>> I wrote the code, I know it and I need to maintain it. All I am asking is if
> >>>>> pre-qual wants rules then I suggest they find some common ground.
> >>>> I agree that it is a good idea to find something that is acceptable for all.
> >>>>> I wonder how libbsd.py goes with these rules. Also all the wscript files which
> >>>>> are also python and also the RSB would be covered.
> >>>> Most likely not well. But that's the problem: We already have a bunch of
> >>>> different styles. Let's try to agree on one before we get lots of extra
> >>>> code. A lot of pre-qualification code will be python. Therefore now is
> >>>> the best time.
> >>> You may know more than me about this. We have been given no information about
> >>> the project's plans or these tools and is becoming frustrating. Joel and I have
> >>> asked on a number occasions. The silence is testing our patience.
> >> I'm really sorry for that. Like I mentioned earlier I'm not really very
> >> good with the overview over this project too. I'll try to discuss this
> >> with Sebastian and Thomas as soon as Sebastian is back from vacation.
> > I understand you are not. I just want to make sure the whole project knows this
> > is important.
> >>> How about we put a python rules discussion on hold until the intentions of the
> >>> pre-qual project are presented publicly and in a manner we can all digest. I
> >>> have spent enough time and energy discussing this stuff and it is not clear to
> >>> me we are in a position to accept what is to be written.
> >> If you want to stop the discussion, I have to accept that. Please just
> >> answer with "this needs further discussion but not now" for all parts
> >> where you think we should stop right now.
> > I think you and I are close but neither of us are doing the work so I am not
> > sure where that leaves us.
> Thanks for your patience in this discussion.
> You are right. We can agree to something but it wouldn't necessarily
> mean that all others agree too. On the other hand it's an open
> discussion and we don't stop anyone from participating. If someone else
> suggests something different afterwards there are at least two of us
> that can argue into the same direction ;-)
> I assume that Sebastian will add some opinion too as soon as he is back
> from vacation next week.
> >> But please note that our current discussion is in my opinion more of a
> >> basic discussion that is only triggered by the pre-qualification
> >> efforts. It's not really relevant whether new tools are added by
> >> pre-qualification in the next year or for some other reasons in the next
> >> five or ten years. Our Python code base is growing and it will become
> >> harder to migrate to some common style with each added snipped of Python
> >> code.
> > This is all valid and I am not questioning the benefit.
> Good to hear. I started to feel bad for arguing so hard for something
> that isn't wanted.
> > I am concerned about the
> > amount of work this creates in the project not covered by the pre-qual team. If
> > this was a GSoC project I was mentoring I would make sure the student had access
> > to a Windows, Mac, FreeBSD and Linux box and I would design a series of steps
> > where each file is converted then tested and the results checked. It would be a
> > slow ad time consuming task but if automated it may work.
> I'm sure that it's no small task. But I think that it would be possible
> to break it down into smaller ones. There are changes where it is enough
> to take a quick look to tell: Yes that works. For example the additional
> new lines between functions like suggested by both discussed standards.
> I think these parts could be integrated without problems. But you are
> right that the rest of the changes are a bit of a challenge.
> >> To come back to your argument regarding C code: For score there is at
> >> least a defined coding style that could be used as a basis for automatic
> >> checks. We currently don't have a defined or recommended style for
> >> Python. So we will have a lot less uniform Python code base than we have
> >> in score in a few years.
> > For the "our" code of which I wrote most of it the style has moved a bit but not
> > much. It is not based on anything specific, it is more like C coding in python.
> > I do not claim to be an expert and it is clearly home grown.
> I know that a lot of code is from you and I didn't want to play that
> down. Most likely we have a lot of your style because you wrote the
> biggest parts. But I'm sure that there are quite some parts that don't
> follow that style too.
> Another part is: I know from myself that if there is no checker, I
> always tend to bend the rules a bit. And depending on the year it's more
> or less. So I wouldn't be able to extract fixed rules from my code that
> I could give to a formatter and have an output with really few changes.
> >>>> If I understood you correctly your main problem with both suggested ones
> >>>> (PEP8 and Google) is that multi line lists have been put together into
> >>>> one liners and dictionaries with aligned fields are not aligned anymore?
> >>> They cannot be touched ...
> >>> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/darwin.py#n41
> >>> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/freebsd.py#n50
> >>> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/linux.py#n54
> >>> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/linux.py#n104
> >>> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/options.py#n56
> >>> https://git.rtems.org/rtems-libbsd/tree/libbsd.py#n59
> >>> https://git.rtems.org/rtems-libbsd/tree/libbsd.py#n108
> >>> https://git.rtems.org/rtems-libbsd/tree/libbsd.py#n148
> >>> I could go on but I think this list should highlight the issue.
> >> I agree that the readability would suffer for cases like that. So we
> >> will have to find a solution for that.
> > Yes, a tricky problem to solve. I only extracted this from your post to
> > highlight the more difficult things to face.
> >>>> About correct?
> >>> The lack of space around the arguments is also a change that is silly and I do
> >>> not want changed.
> >> I think that is based on the "official" python style (which is PEP-0008):
> >> https://www.python.org/dev/peps/pep-0008/#whitespace-in-expressions-and-statements
> > Oh interesting, thanks. I had not made the connection that the pep8 format was
> > from here.
> I thought that it is well known that the PEPs are some kind of python
> standard. Shouldn't have assumed that.
> > The combining arg annotations with the default value makes me sigh, a rule
> > within a rule.
> > I could not see dict layouts in it.
> You are right. I didn't find them either. So maybe we are lucky that it
> depends on some formater options rather than style.
> Sebastian also mentioned that some formaters (for example "black") can
> have special comments to tell the formater to ignore a block of code (in
> case of "black" with "# fmt: on/off").
> "yapf" has a similar one that can even be used for small parts like
> array initializations:
> https://pypi.org/project/yapf/#why-does-yapf-destroy-my-awesome-formatting
> In the chapter "A Foolish Consistency is the Hobgoblin of Little Minds"
> PEP8 specially mentions that the style shouldn't be applied if it would
> be less readable. So switching the formater off for small parts would
> even be according to the style guide. Google don't expresses it that
> explicitly but the "Parting Words" suggest something similar.
> Please also note that PEP8 explicitely tells "Some other good reasons to
> ignore a particular guideline: [...] 3. Because the code in question
> predates the introduction of the guideline and there is no other reason
> to be modifying that code." So that style even suggests to not touch
> existing code if it isn't touched anyway due to another reason.
> >>> The biggest challenge who ever finally proposes these rules faces is the RSB. It
> >>> is very difficult to know if you have broken it. It has taken years to converge
> >>> to the level of stability we have. All changes in here would need a close review
> >>> and that something I am not excited about.
> >> I agree that all changes should be reviewed closely. Again: I'm in favor
> >> of finding something acceptable that can be used for new tools and then
> >> try to start a slow migration maybe even over years. Note that this is a
> >> purely personal preference and I don't have an idea whether it matches
> >> the targets of pre-qualification or not.
> > Are you volunteering to spend years making the change? So far it is just you and
> > me. ;)
> > I see for the existing python a series of options:
> > 1. Do not allow rules or changes to the formatting until all existing code has
> > been migrated, tested and accepted
> I'm not in favor of that. We should agree to a set of rules _before_
> changing any code. Otherwise: How would we know the direction for the
> changes.
> > 2. Allow a set of rules and all new code follows the rules and we ignore the
> > existing code
> > 3. Slowly migrate the existing code over testing each file and merging when tested
> I think my personal preference would be a combination of 2 and 3: Find a
> style that is acceptable for all of us and use it for new code. If
> bigger blocks of old code are touched: Migrate it to the new style.
> > 4. Covert all existing code and let everyone handle the fall out if there is any
> Maybe applying _some_ of the uncritical rules with only easily
> reviewable changes could be a good step to reduce the difference and
> improve the readability. But I agree that it mustn't be changes that
> compromise stability.
> > 5. Do nothing
> Not a good solution if the target is to get anything done.
> > 6. Something else?
> > None of these are ideal as someone is effected and some are not realistic.
> > Chris
> Best regards
> Christian
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
> devel mailing list
> devel at rtems.org
