[rtems-source-builder commit] moxie: Update to dtc 1.6.0
Joel Sherrill
joel at rtems.org
Thu Jul 2 16:41:32 UTC 2020
On Thu, Jul 2, 2020 at 11:25 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Jul 2, 2020 at 9:48 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 02/07/2020 09:56, Chris Johns wrote:
> > > On 2/7/20 4:15 am, Sebastian Huber wrote:
> > >> Module: rtems-source-builder
> > >> Branch: master
> > >> Commit: abe5d1b2fe9ec264d366b876c1387d7f85aaacd6
> > >> Changeset:
> http://git.rtems.org/rtems-source-builder/commit/?id=abe5d1b2fe9ec264d366b876c1387d7f85aaacd6
> > >> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> > >> Date: Wed Jul 1 20:13:47 2020 +0200
> > >> This fixes the build with a GCC 10 host compiler.
> > >> rtems/config/5/rtems-moxie.bset | 2 +-
> > > The rtems/config/5 bsp and other pieces need to be moved over to 6 and
> > > this tree removed. I do not think we should be maintaining 5 on the
> > > master branch. I will try and get to this soon.
> > Ok, this was a bit sloppy from my side. I already added RTEMS 6 and 7
> > tools. So, the RTEMS 5 tools can be removed from the master from my
> > point of view.
> Great. Do the released docs indicate to checkout the 5/ branch for RSB
> quick start? I'm not sure where to find the draft release docs for 5.
And the other repositories. There is a mated set of branches.
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200702/92aafbac/attachment.html>
