[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma mritunjaysharma394 at gmail.com
Thu Jul 2 18:29:48 UTC 2020
I guess the problem can be with my using 'sudo' here
but without using sudo and directly using 'make install',
the process stops all the more early with the following error:
"Making install in make
make[1]: Entering directory
'/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/make'
make[2]: Entering directory
make[2]: Nothing to be done for 'install-exec-am'.
 /bin/mkdir -p '/home/development/rtems_dev/rtems-4.10.2/make'
 /usr/bin/install -c -m 644 ../../make/main.cfg ../../make/leaf.cfg
/usr/bin/install: cannot remove
'/home/development/rtems_dev/rtems-4.10.2/make/main.cfg': Permission denied
'/home/development/rtems_dev/rtems-4.10.2/make/leaf.cfg': Permission denied
Makefile:265: recipe for target 'install-dist_rtems_makeDATA' failed
make[2]: *** [install-dist_rtems_makeDATA] Error 1
make[2]: Leaving directory
Makefile:379: recipe for target 'install-am' failed
make[1]: *** [install-am] Error 2
make[1]: Leaving directory
Makefile:304: recipe for target 'install-recursive' failed
make: *** [install-recursive] Error 1"
On Thu, Jul 2, 2020 at 11:47 PM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Hello Heinz and everyone,
> Thank you so much, using RTEMS RSB for 4.10 really helped me a lot and
> saved a lot of time.
> Though in all this it was a good learning experience for how to build the
> compiler
> tools manually too :-)
> The make was successful this time and the previous error was resolved but
> after the make while using 'sudo make install', I have got another error as
> following:
> " ...( cd
> '/home/development/rtems_dev/rtems-4.10.2/i386-rtems4.10/pc386/lib' &&
> i386-rtems4.10-ranlib libsapi.a )
> /bin/bash: line 5: i386-rtems4.10-ranlib: command not found
> Makefile:366: recipe for target 'install-project_libLIBRARIES' failed
> make[5]: *** [install-project_libLIBRARIES] Error 127
> make[5]: Leaving directory
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c/pc386/cpukit/sapi'
> Makefile:952: recipe for target 'install-am' failed
> make[4]: *** [install-am] Error 2
> make[4]: Leaving directory
> Makefile:785: recipe for target 'install-recursive' failed
> make[3]: *** [install-recursive] Error 1
> make[3]: Leaving directory
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c/pc386/cpukit'
> Makefile:425: recipe for target 'install-recursive' failed
> make[2]: *** [install-recursive] Error 1
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c/pc386'
> Makefile:286: recipe for target 'install-recursive' failed
> make[1]: *** [install-recursive] Error 1
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c'
> I am trying to figure out on what can be the reason behind this, it will
> be kind of
> you all to guide help this fix.
> Thanks,
> Mritunjay
> On Thu, Jul 2, 2020 at 9:59 AM Heinz Junkes <junkes at fhi-berlin.mpg.de>
> wrote:
>> Hello, Mritunjay,
>> why not use the RTEMS Resource builder for 4.10 ?
>> Heinz
>> > On 1. Jul 2020, at 20:03, Mritunjay Sharma <
>> > Hi Gedare,
>> > Thank you so much, since I had the experience of RSB toolchain till
>> now,
>> > I forgot to build the RTEMS compiler toolchain.
>> > Today's update is also this that I spent the day figuring out how
>> > to build it manually and got some really amazing blogs
>> > which have helped me (though they were a bit difficult to find because
>> most pages have been
>> > relocated).
>> > Sharing the resources which I have used today and that are helping me
>> build RTEMS compiler toolchain for 4.10.
>> http://heshamelmatary.blogspot.com/2014/06/howto-build-rtems-tool-chain-for.html
>> https://docs.rtems.org/releases/4.5.0/rtemsdoc-4.5.0/share/rtemsdoc/html/started/started00040.html
>> > https://ftp.rtems.org/pub/rtems/releases/4.10/tools/
>> > I am now applying patches for gdb, gcc, binutils and most
>> > probably hope that the build will be successful.
>> > As suggested by Heinz, I am improving the blog as well and will post
>> the updated and better
>> > version of blog by Friday.
>> > Thanks,
>> > Mritunjay
>> > On Wed, Jul 1, 2020 at 9:25 AM Gedare Bloom <gedare at rtems.org> wrote:
>> > On Tue, Jun 30, 2020 at 9:42 PM Mritunjay Sharma
>> > <mritunjaysharma394 at gmail.com> wrote:
>> > > Hi Gedare,
>> > > Thank you for the quick response, I tried using
>> --target=i386-rtems4.10, which again
>> > > gave me the same error.
>> > Did you build an RTEMS compiler toolchain for 4.10? and install it to
>> > a prefix in your $PATH?
>> > > "checking for RTEMS_CPU_MODEL... i386_fp
>> > > checking for RTEMS_BSP_FAMILY... pc386
>> > > checking for CPU_CFLAGS... (cached) -mtune=i386
>> > > checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>> > > checking for style of include used by make... GNU
>> > > checking for i386-rtems4.10-gcc... no
>> > > configure: error: no acceptable cc found in $PATH
>> > > Makefile:712: recipe for target 'pc386' failed
>> > > make[2]: *** [pc386] Error 1
>> '/home/mritunjay/development/rtems-4.10.2/pc-386/i386-rtems4.10/c'
>> > > Makefile:257: recipe for target 'all-recursive' failed
>> > > make[1]: *** [all-recursive] Error 1
>> > > Makefile:275: recipe for target 'all-recursive' failed
>> > > make: *** [all-recursive] Error 1"
>> > > Mritunjay
>> > > On Wed, Jul 1, 2020 at 3:48 AM Gedare Bloom <gedare at rtems.org> wrote:
>> > >>  Use --target=i386-rtems4.10 instead of  --target=i386-rtems
>> > >> Does this work with 4.10.3/4.10 HEAD?
>> > >> On Tue, Jun 30, 2020 at 3:54 PM Mritunjay Sharma
>> > >> > Hello everyone,
>> > >> > I followed the documentation here
>> https://docs.rtems.org/releases/rtemsdocs-4.10.2/share/rtems/pdf/started.pdf
>> and
>> > >> > started building RTEMS (4.10.2) for target architecture: i386 and
>> BSP: pc386. The configure seemed to be fine
>> > >> > after entering the following command:
>> > >> > "../configure --target=i386-rtems --disable-posix --enable-cxx
>> --enable-rtemsbsp=pc386 --enable-tests=samples
>> --prefix=/home/development/rtems-4.10.2"
>> > >> > However, the make failed with the following error: checking for
>> i386-rtems-gcc... no
>> > >> > "configure: error: no acceptable cc found in $PATH
>> '/home/mritunjay/development/rtems-4.10.2/pc386/i386-rtems/c'
>> > >> > I checked that gcc is already installed in /usr/bin/gcc.
>> > >> > So I am not able to figure out what exactly is causing the error.
>> > >> > Please help to figure out what is causing this and how it can be
>> resolved.
>> > >> > I have attached the config log as well.
>> > >> > Thanks
>> > >> > Mritunjay
>> > >> > On Wed, Jul 1, 2020 at 12:27 AM Mritunjay Sharma <
>> > >> >> I mistakenly forgot to cc my other mentors.
>> > >> >> This is what I responded :
>> > >> >>> Hello Heinz,
>> > >> >>> Pardon the mistake I did in haste,
>> > >> >>> as I advised by you I am now building it for RTEMS 4.10 and then
>> I will
>> > >> >>> be reporting here shortly as the build completes.
>> > >> >>> Thanks
>> > >> >>> Mritunjay.
>> > >> >> I am shortly sending the email for the progress I made after
>> working on above.
>> > >> >> Thanks
>> > >> >> Mritunjay
>> > >> >> On Wed, Jul 1, 2020 at 12:11 AM Heinz Junkes <
>> junkes at fhi-berlin.mpg.de> wrote:
>> > >> >>> Hello, Mritunjay,
>> > >> >>> the epics-base version in github does not work with RTEMS5 It
>> needs my extensions for this.
>> > >> >>> Therefore I suggested that you first build epics7 for e.g. RTEMS
>> 4.10.
>> > >> >>> Then the easiest way is to build epics7 for RTEMS-pc386-qemu.
>> This is fully supported.
>> > >> >>> So you learn how to build EPics and then you can develop a first
>> rsb-set for it.
>> > >> >>> If this works, we will work on RTEMS5 and xilinx-Zynq.
>> > >> >>> Heinz
>> > >> >>> > On 30. Jun 2020, at 20:10, Mritunjay Sharma <
>> > >> >>> > Hello everyone,
>> > >> >>> > While yesterday, I completed the blog for the progress
>> > >> >>> > till date, today I started the coding part.
>> > >> >>> > The tutorial that Heinz sent me yesterday guided
>> > >> >>> > me to make the following changes:
>> > >> >>> > 1) epics-base/configure/CONFIG_SITE:
>> > >> >>> > # Which target architectures to cross-compile for.
>> > >> >>> > #  Definitions in configure/os/CONFIG_SITE.<host>.Common
>> > >> >>> > #  may override this setting.
>> > >> >>> > -CROSS_COMPILER_TARGET_ARCHS=
>> > >> >>> > - #CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32
>> > >> >>> > + CROSS_COMPILER_TARGET_ARCHS=pc386
>> > >> >>> > +#CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu
>> > >> >>> > I did not use xilinx_zynq_a9_qemu for now because I could
>> > >> >>> > not locate CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>> > >> >>> > as of now in epics-base/configure/os.
>> > >> >>> > 2) configure/os/CONFIG_SITE.Common.RTEMS :
>> > >> >>> > # Where to find RTEMS
>> > >> >>> > # APS:
>> > >> >>> > -RTEMS_VERSION = 4.10.2
>> > >> >>> > -RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
>> > >> >>> > #RTEMS_VERSION = 4.10.2
>> > >> >>> > #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
>> > >> >>> > +# FHI:
>> > >> >>> > +RTEMS_SERIES = 5
>> > >> >>> > +RTEMS_VERSION = 5
>> > >> >>> > +RTEMS_BASE = /home/mritunjay/development/rtems/5
>> > >> >>> > I thought to straightaway move with building it with RTEMS 5
>> > >> >>> > because I have done it earlier for beatnik.
>> > >> >>> > After this as an experiment, I tried the make command which,
>> > >> >>> > as expected, generated the following error:
>> > >> >>> > "make[4]: *** No rule to make target
>> '../O.Common/osiFileName.h', needed by 'inc'.  Stop.
>> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/src/O.pc386'
>> > >> >>> > ../../../configure/RULES_ARCHS:58: recipe for target
>> 'install.pc386' failed
>> > >> >>> > make[3]: *** [install.pc386] Error 2
>> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/src'
>> > >> >>> > ../../configure/RULES_DIRS:85: recipe for target 'src.install'
>> failed
>> > >> >>> > make[2]: *** [src.install] Error 2
>> '/home/mritunjay/development/EPICS/epics-base/modules/libcom'
>> > >> >>> > ../configure/RULES_DIRS:85: recipe for target 'libcom.install'
>> failed
>> > >> >>> > make[1]: *** [libcom.install] Error 2
>> '/home/mritunjay/development/EPICS/epics-base/modules'
>> > >> >>> > configure/RULES_DIRS:85: recipe for target 'modules.install'
>> failed
>> > >> >>> > make: *** [modules.install] Error 2
>> > >> >>> > I then re-visited to what I did with beatnik and made the
>> following changes to
>> > >> >>> > start with adding support for RTEMS 5:
>> > >> >>> > diff --git a/configure/CONFIG_COMMON b/configure/CONFIG_COMMON
>> > >> >>> > index 6c0e11e0d..d56802968 100644
>> > >> >>> > --- a/configure/CONFIG_COMMON
>> > >> >>> > +++ b/configure/CONFIG_COMMON
>> > >> >>> > @@ -142,9 +142,10 @@ BUILDLIB_SUFFIX =
>> $(BUILDLIB_SUFFIX_$(SHARED_LIBRARIES))
>> > >> >>> >  # vpath directories
>> > >> >>> >  POSIX_YES = os/posix
>> > >> >>> > +OS_IMPL_DIRS = $(if $(OS_API),os/$(OS_CLASS)-$(OS_API),)
>> os/$(OS_CLASS)
>> > >> >>> >  GENERIC_SRC_DIRS = .. $(SRC_DIRS)
>> > >> >>> >  OS_SRC_DIRS += . $(foreach dir, .. $(SRC_DIRS), \
>> > >> >>> > -       $(addprefix $(dir)/, os/$(OS_CLASS) $(POSIX_$(POSIX))
>> os/default ))
>> > >> >>> > +       $(addprefix $(dir)/, $(OS_IMPL_DIRS) $(POSIX_$(POSIX))
>> os/default ))
>> > >> >>> >  CMPLR_SRC_DIRS += . $(foreach dir, .. $(SRC_DIRS), \
>> > >> >>> >         $(addprefix $(dir)/, compiler/$(CMPLR_CLASS)
>> compiler/default ))
>> > >> >>> >  ALL_SRC_DIRS = $(CMPLR_SRC_DIRS) $(OS_SRC_DIRS)
>> $(GENERIC_SRC_DIRS)
>> > >> >>> > diff --git a/configure/CONFIG_SITE b/configure/CONFIG_SITE
>> > >> >>> > index 09b4c1525..f3aa4b3f7 100644
>> > >> >>> > --- a/configure/CONFIG_SITE
>> > >> >>> > +++ b/configure/CONFIG_SITE
>> > >> >>> > @@ -161,7 +161,7 @@ USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
>> > >> >>> >  # Site version number, if set will append '-' and this string
>> to the
>> > >> >>> >  #  EPICS version number string that is reported by many tools.
>> > >> >>> > -EPICS_SITE_VERSION =
>> > >> >>> > +EPICS_SITE_VERSION =
>> > >> >>> >  # For GNU compiler, use pipes rather than temporary files for
>> > >> >>> >  #  communication between the various stages of compilation.
>> > >> >>> > diff --git a/configure/os/CONFIG.Common.RTEMS
>> b/configure/os/CONFIG.Common.RTEMS
>> > >> >>> > index 8425e6ef9..929510d61 100644
>> > >> >>> > --- a/configure/os/CONFIG.Common.RTEMS
>> > >> >>> > +++ b/configure/os/CONFIG.Common.RTEMS
>> > >> >>> > @@ -94,16 +94,28 @@ MODEXT=.obj
>> > >> >>> >  # operating system class (include/os/<os_class>)
>> > >> >>> >  OS_CLASS = RTEMS
>> > >> >>> > +# operating system API (src/os/<os_class>-<os-api>)
>> > >> >>> > +OS_API_4.7 = kernel
>> > >> >>> > +OS_API_4.8 = kernel
>> > >> >>> > +OS_API_4.9 = kernel
>> > >> >>> > +OS_API_4.10 = kernel
>> > >> >>> > +OS_API = $(firstword $(OS_API_$(RTEMS_SERIES)) posix)
>> > >> >>> >  # Operating system flags
>> > >> >>> > -OP_SYS_LDLIBS += -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
>> > >> >>> > -OP_SYS_LDFLAGS += $(CPU_CFLAGS) -u Init \
>> > >> >>> > +OP_SYS_LDLIBS += -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
>> > >> >>> > +# newest Rtems > 2019 needs this -ltftpfs
>> > >> >>> > +OP_SYS_LDFLAGS_posix += -u POSIX_Init
>> > >> >>> > +OP_SYS_LDFLAGS_kernel += $(CPU_CFLAGS) -u Init \
>> > >> >>> >                   $(PROJECT_RELEASE)/lib/no-dpmem.rel \
>> > >> >>> >                   $(PROJECT_RELEASE)/lib/no-mp.rel \
>> > >> >>> >                   $(PROJECT_RELEASE)/lib/no-part.rel \
>> > >> >>> >                   $(PROJECT_RELEASE)/lib/no-signal.rel \
>> > >> >>> >                   $(PROJECT_RELEASE)/lib/no-rtmon.rel
>> > >> >>> > +OP_SYS_LDFLAGS += $(CPU_FLAGS) $(OP_SYS_LDFLAGS_$(OS_API))
>> > >> >>> >  MOD_SYS_LDFLAGS += $(CPU_CFLAGS) -Wl,-r -nostdlib
>> > >> >>> >  # Do not link against libraries which are part of the Generic
>> Image
>> > >> >>> > diff --git a/modules/libcom/RTEMS/Makefile
>> b/modules/libcom/RTEMS/Makefile
>> > >> >>> > index b46889db1..cb1a63b97 100644
>> > >> >>> > --- a/modules/libcom/RTEMS/Makefile
>> > >> >>> > +++ b/modules/libcom/RTEMS/Makefile
>> > >> >>> > @@ -11,6 +11,9 @@ TOP = ../../..
>> > >> >>> >  include $(TOP)/configure/CONFIG
>> > >> >>> >  include $(TOP)/configure/CONFIG_LIBCOM_VERSION
>> > >> >>> > +#for checking
>> > >> >>> > +SRC_DIRS += ../$(OS_API)
>> > >> >>> >  PERL_SCRIPTS += epicsMakeMemFs.pl
>> > >> >>> >  INC += epicsRtemsInitHooks.h
>> > >> >>> > (END)
>> > >> >>> > I will start with further changes tomorrow. Please find the
>> changes pushed
>> > >> >>> > here:
>> https://github.com/epics-base/epics-base/compare/7.0...mritunjaysharma394:GSoC_pc-386
>> > >> >>> > I will be pleased to have the feedback and if I am on the
>> correct course now.
>> > >> >>> > I will also like to inform that I have filled the GSoC Phase 1
>> Evaluation form and I
>> > >> >>> > will request all my mentors to please feel free to fill the
>> form before the deadline
>> > >> >>> > and I hope that from now I will not disappoint with my
>> progress.
>> > >> >>> > It is my bad that I still have not  been able to reach out to
>> one more
>> > >> >>> > mentor Pavel Pisa. Please if possible share the email id of
>> Pavel and cc
>> > >> >>> > Pavel in the replies to the email so that Pavel s aware of the
>> progress and I
>> > >> >>> > can apologise for my inability to connect with Pavel earlier.
>> > >> >>> > Thanks,
>> > >> >>> > Mritunjay.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200702/ececbbba/attachment-0001.html>
