[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Jul 2 20:52:18 UTC 2020
On Fri, Jul 3, 2020 at 1:59 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Fri, Jul 3, 2020 at 1:41 AM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> > On Fri, Jul 3, 2020 at 12:21 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> On Fri, Jul 3, 2020 at 12:15 AM Mritunjay Sharma
> >> > On Fri, Jul 3, 2020 at 12:10 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> >> On Fri, Jul 3, 2020 at 12:00 AM Mritunjay Sharma
> >> >> > I guess the problem can be with my using 'sudo' here
> >> >> > but without using sudo and directly using 'make install',
> >> >> > the process stops all the more early with the following error:
> >> >> Please try `sudo chmod +x $HOME/development/rtems_dev/rtems-4.10.2/`
> >> > Thank you so much, I tried this but again got the earlier error.
> >> I should have written it explicitly, sorry for the confusion.
> >> After doing chmod, you have to run `make install` without sudo. The
> >> error you're facing with sudo is because the PATH variable for the
> >> root user does not include the rtems toolchain bin directory hence
> >> it's returning "command not found".
> >> In the next try you got "permission denied" errors because there's no
> >> executing permission for the tools directory. By doing chmod, you
> >> added the execute permission (+x) and now you can run make without
> >> sudo.
> >> Best regards,
> >> Vijay
> > Thank you so much for this really nice explanation. As explained by you,
> I tried again by first doing
> > 'sudo chmod +x $HOME/development/rtems_dev/rtems-4.10.2/' and then using
> 'make install' without 'sudo',
> > however, I am still getting the 'permission denied error'.
> Seems like you were not able to delete either. You'll have to add
> write permission as well
> `chmod +w /YOUR_FOLDER`
> > Do I need to have rebuild the tools as well using RSB and then try again?
> No, that won't be needed. You probably built all the tools as a
> superuser, that's why the permissions are restrictive, chmod will fix
> that.
I tried 'sudo chmod +w /home/development/rtems_dev/rtems-4.10.2/ ' but
unfortunately the 'permission denied' error
still remains after using 'make install' :(
Thanks,
Mritunjay
> >> >> > "Making install in make
> >> >> > make[1]: Entering directory
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/make'
> >> >> > make[2]: Entering directory
> >> >> > make[2]: Nothing to be done for 'install-exec-am'.
> >> >> > /bin/mkdir -p '/home/development/rtems_dev/rtems-4.10.2/make'
> >> >> > /usr/bin/install -c -m 644 ../../make/main.cfg
> ../../make/leaf.cfg '/home/development/rtems_dev/rtems-4.10.2/make'
> >> >> > /usr/bin/install: cannot remove
> '/home/development/rtems_dev/rtems-4.10.2/make/main.cfg': Permission denied
> '/home/development/rtems_dev/rtems-4.10.2/make/leaf.cfg': Permission denied
> >> >> > Makefile:265: recipe for target 'install-dist_rtems_makeDATA'
> failed
> >> >> > make[2]: *** [install-dist_rtems_makeDATA] Error 1
> >> >> > make[2]: Leaving directory
> >> >> > Makefile:379: recipe for target 'install-am' failed
> >> >> > make[1]: *** [install-am] Error 2
> >> >> > make[1]: Leaving directory
> >> >> > Makefile:304: recipe for target 'install-recursive' failed
> >> >> > make: *** [install-recursive] Error 1"
> >> >> > On Thu, Jul 2, 2020 at 11:47 PM Mritunjay Sharma <
> >> >> >> Hello Heinz and everyone,
> >> >> >> Thank you so much, using RTEMS RSB for 4.10 really helped me a
> lot and saved a lot of time.
> >> >> >> Though in all this it was a good learning experience for how to
> build the compiler
> >> >> >> tools manually too :-)
> >> >> >> The make was successful this time and the previous error was
> resolved but after the make while using 'sudo make install', I have got
> another error as following:
> >> >> >> " ...( cd
> '/home/development/rtems_dev/rtems-4.10.2/i386-rtems4.10/pc386/lib' &&
> i386-rtems4.10-ranlib libsapi.a )
> >> >> >> /bin/bash: line 5: i386-rtems4.10-ranlib: command not found
> >> >> >> Makefile:366: recipe for target 'install-project_libLIBRARIES'
> failed
> >> >> >> make[5]: *** [install-project_libLIBRARIES] Error 127
> >> >> >> make[5]: Leaving directory
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c/pc386/cpukit/sapi'
> >> >> >> Makefile:952: recipe for target 'install-am' failed
> >> >> >> make[4]: *** [install-am] Error 2
> >> >> >> make[4]: Leaving directory
> >> >> >> Makefile:785: recipe for target 'install-recursive' failed
> >> >> >> make[3]: *** [install-recursive] Error 1
> >> >> >> make[3]: Leaving directory
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c/pc386/cpukit'
> >> >> >> Makefile:425: recipe for target 'install-recursive' failed
> >> >> >> make[2]: *** [install-recursive] Error 1
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c/pc386'
> >> >> >> Makefile:286: recipe for target 'install-recursive' failed
> >> >> >> make[1]: *** [install-recursive] Error 1
> '/home/mritunjay/development/rtems_dev/rtems-4.10.2/pc-386/i386-rtems4.10/c'
> >> >> >> I am trying to figure out on what can be the reason behind this,
> it will be kind of
> >> >> >> you all to guide help this fix.
> >> >> >> Thanks,
> >> >> >> Mritunjay
> >> >> >> On Thu, Jul 2, 2020 at 9:59 AM Heinz Junkes <
> junkes at fhi-berlin.mpg.de> wrote:
> >> >> >>> Hello, Mritunjay,
> >> >> >>> why not use the RTEMS Resource builder for 4.10 ?
> >> >> >>> Heinz
> >> >> >>> > On 1. Jul 2020, at 20:03, Mritunjay Sharma <
> >> >> >>> > Hi Gedare,
> >> >> >>> > Thank you so much, since I had the experience of RSB toolchain
> till now,
> >> >> >>> > I forgot to build the RTEMS compiler toolchain.
> >> >> >>> > Today's update is also this that I spent the day figuring out
> how
> >> >> >>> > to build it manually and got some really amazing blogs
> >> >> >>> > which have helped me (though they were a bit difficult to find
> because most pages have been
> >> >> >>> > relocated).
> >> >> >>> > Sharing the resources which I have used today and that are
> helping me build RTEMS compiler toolchain for 4.10.
> http://heshamelmatary.blogspot.com/2014/06/howto-build-rtems-tool-chain-for.html
> https://docs.rtems.org/releases/4.5.0/rtemsdoc-4.5.0/share/rtemsdoc/html/started/started00040.html
> >> >> >>> > https://ftp.rtems.org/pub/rtems/releases/4.10/tools/
> >> >> >>> > I am now applying patches for gdb, gcc, binutils and most
> >> >> >>> > probably hope that the build will be successful.
> >> >> >>> > As suggested by Heinz, I am improving the blog as well and
> will post the updated and better
> >> >> >>> > version of blog by Friday.
> >> >> >>> > Thanks,
> >> >> >>> > Mritunjay
> >> >> >>> > On Wed, Jul 1, 2020 at 9:25 AM Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >> >>> > On Tue, Jun 30, 2020 at 9:42 PM Mritunjay Sharma
> >> >> >>> > > Hi Gedare,
> >> >> >>> > > Thank you for the quick response, I tried using
> --target=i386-rtems4.10, which again
> >> >> >>> > > gave me the same error.
> >> >> >>> > Did you build an RTEMS compiler toolchain for 4.10? and
> install it to
> >> >> >>> > a prefix in your $PATH?
> >> >> >>> > > "checking for RTEMS_CPU_MODEL... i386_fp
> >> >> >>> > > checking for RTEMS_BSP_FAMILY... pc386
> >> >> >>> > > checking for CPU_CFLAGS... (cached) -mtune=i386
> >> >> >>> > > checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
> >> >> >>> > > checking for style of include used by make... GNU
> >> >> >>> > > checking for i386-rtems4.10-gcc... no
> >> >> >>> > > configure: error: no acceptable cc found in $PATH
> >> >> >>> > > Makefile:712: recipe for target 'pc386' failed
> >> >> >>> > > make[2]: *** [pc386] Error 1
> '/home/mritunjay/development/rtems-4.10.2/pc-386/i386-rtems4.10/c'
> >> >> >>> > > Makefile:257: recipe for target 'all-recursive' failed
> >> >> >>> > > make[1]: *** [all-recursive] Error 1
> >> >> >>> > > Makefile:275: recipe for target 'all-recursive' failed
> >> >> >>> > > make: *** [all-recursive] Error 1"
> >> >> >>> > > Mritunjay
> >> >> >>> > > On Wed, Jul 1, 2020 at 3:48 AM Gedare Bloom <
> gedare at rtems.org> wrote:
> >> >> >>> > >> Use --target=i386-rtems4.10 instead of --target=i386-rtems
> >> >> >>> > >> Does this work with 4.10.3/4.10 HEAD?
> >> >> >>> > >> On Tue, Jun 30, 2020 at 3:54 PM Mritunjay Sharma
> >> >> >>> > >> > Hello everyone,
> >> >> >>> > >> > I followed the documentation here
> https://docs.rtems.org/releases/rtemsdocs-4.10.2/share/rtems/pdf/started.pdf
> and
> >> >> >>> > >> > started building RTEMS (4.10.2) for target architecture:
> i386 and BSP: pc386. The configure seemed to be fine
> >> >> >>> > >> > after entering the following command:
> >> >> >>> > >> > "../configure --target=i386-rtems --disable-posix
> --enable-cxx --enable-rtemsbsp=pc386 --enable-tests=samples
> --prefix=/home/development/rtems-4.10.2"
> >> >> >>> > >> > However, the make failed with the following error:
> checking for i386-rtems-gcc... no
> >> >> >>> > >> > "configure: error: no acceptable cc found in $PATH
> '/home/mritunjay/development/rtems-4.10.2/pc386/i386-rtems/c'
> >> >> >>> > >> > I checked that gcc is already installed in /usr/bin/gcc.
> >> >> >>> > >> > So I am not able to figure out what exactly is causing
> the error.
> >> >> >>> > >> > Please help to figure out what is causing this and how it
> can be resolved.
> >> >> >>> > >> > I have attached the config log as well.
> >> >> >>> > >> > Thanks
> >> >> >>> > >> > Mritunjay
> >> >> >>> > >> > On Wed, Jul 1, 2020 at 12:27 AM Mritunjay Sharma <
> >> >> >>> > >> >> I mistakenly forgot to cc my other mentors.
> >> >> >>> > >> >> This is what I responded :
> >> >> >>> > >> >>> Hello Heinz,
> >> >> >>> > >> >>> Pardon the mistake I did in haste,
> >> >> >>> > >> >>> as I advised by you I am now building it for RTEMS 4.10
> and then I will
> >> >> >>> > >> >>> be reporting here shortly as the build completes.
> >> >> >>> > >> >>> Thanks
> >> >> >>> > >> >>> Mritunjay.
> >> >> >>> > >> >> I am shortly sending the email for the progress I made
> after working on above.
> >> >> >>> > >> >> Thanks
> >> >> >>> > >> >> Mritunjay
> >> >> >>> > >> >> On Wed, Jul 1, 2020 at 12:11 AM Heinz Junkes <
> >> >> >>> > >> >>> Hello, Mritunjay,
> >> >> >>> > >> >>> the epics-base version in github does not work with
> RTEMS5 It needs my extensions for this.
> >> >> >>> > >> >>> Therefore I suggested that you first build epics7 for
> e.g. RTEMS 4.10.
> >> >> >>> > >> >>> Then the easiest way is to build epics7 for
> RTEMS-pc386-qemu. This is fully supported.
> >> >> >>> > >> >>> So you learn how to build EPics and then you can
> develop a first rsb-set for it.
> >> >> >>> > >> >>> If this works, we will work on RTEMS5 and xilinx-Zynq.
> >> >> >>> > >> >>> Heinz
> >> >> >>> > >> >>> > On 30. Jun 2020, at 20:10, Mritunjay Sharma <
> >> >> >>> > >> >>> > Hello everyone,
> >> >> >>> > >> >>> > While yesterday, I completed the blog for the progress
> >> >> >>> > >> >>> > till date, today I started the coding part.
> >> >> >>> > >> >>> > The tutorial that Heinz sent me yesterday guided
> >> >> >>> > >> >>> > me to make the following changes:
> >> >> >>> > >> >>> > 1) epics-base/configure/CONFIG_SITE:
> >> >> >>> > >> >>> > # Which target architectures to cross-compile for.
> >> >> >>> > >> >>> > # Definitions in
> configure/os/CONFIG_SITE.<host>.Common
> >> >> >>> > >> >>> > # may override this setting.
> >> >> >>> > >> >>> > -CROSS_COMPILER_TARGET_ARCHS=
> >> >> >>> > >> >>> > - #CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32
> >> >> >>> > >> >>> > + CROSS_COMPILER_TARGET_ARCHS=pc386
> +#CROSS_COMPILER_TARGET_ARCHS=RTEMS-xilinx_zynq_a9_qemu
> >> >> >>> > >> >>> > I did not use xilinx_zynq_a9_qemu for now because I
> could
> >> >> >>> > >> >>> > not locate CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
> >> >> >>> > >> >>> > as of now in epics-base/configure/os.
> >> >> >>> > >> >>> > 2) configure/os/CONFIG_SITE.Common.RTEMS :
> >> >> >>> > >> >>> > # Where to find RTEMS
> >> >> >>> > >> >>> > # APS:
> >> >> >>> > >> >>> > -RTEMS_VERSION = 4.10.2
> >> >> >>> > >> >>> > -RTEMS_BASE =
> /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
> >> >> >>> > >> >>> > #RTEMS_VERSION = 4.10.2
> >> >> >>> > >> >>> > #RTEMS_BASE =
> >> >> >>> > >> >>> > +# FHI:
> >> >> >>> > >> >>> > +RTEMS_SERIES = 5
> >> >> >>> > >> >>> > +RTEMS_VERSION = 5
> >> >> >>> > >> >>> > +RTEMS_BASE = /home/mritunjay/development/rtems/5
> >> >> >>> > >> >>> > I thought to straightaway move with building it with
> RTEMS 5
> >> >> >>> > >> >>> > because I have done it earlier for beatnik.
> >> >> >>> > >> >>> > After this as an experiment, I tried the make command
> which,
> >> >> >>> > >> >>> > as expected, generated the following error:
> >> >> >>> > >> >>> > "make[4]: *** No rule to make target
> '../O.Common/osiFileName.h', needed by 'inc'. Stop.
> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/src/O.pc386'
> >> >> >>> > >> >>> > ../../../configure/RULES_ARCHS:58: recipe for target
> 'install.pc386' failed
> >> >> >>> > >> >>> > make[3]: *** [install.pc386] Error 2
> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/src'
> >> >> >>> > >> >>> > ../../configure/RULES_DIRS:85: recipe for target
> 'src.install' failed
> >> >> >>> > >> >>> > make[2]: *** [src.install] Error 2
> '/home/mritunjay/development/EPICS/epics-base/modules/libcom'
> 'libcom.install' failed
> >> >> >>> > >> >>> > make[1]: *** [libcom.install] Error 2
> '/home/mritunjay/development/EPICS/epics-base/modules'
> 'modules.install' failed
> >> >> >>> > >> >>> > make: *** [modules.install] Error 2
> >> >> >>> > >> >>> > I then re-visited to what I did with beatnik and made
> the following changes to
> >> >> >>> > >> >>> > start with adding support for RTEMS 5:
> >> >> >>> > >> >>> > diff --git a/configure/CONFIG_COMMON
> b/configure/CONFIG_COMMON
> >> >> >>> > >> >>> > index 6c0e11e0d..d56802968 100644
> >> >> >>> > >> >>> > --- a/configure/CONFIG_COMMON
> >> >> >>> > >> >>> > +++ b/configure/CONFIG_COMMON
> >> >> >>> > >> >>> > @@ -142,9 +142,10 @@ BUILDLIB_SUFFIX =
> $(BUILDLIB_SUFFIX_$(SHARED_LIBRARIES))
> >> >> >>> > >> >>> > # vpath directories
> >> >> >>> > >> >>> > POSIX_YES = os/posix
> >> >> >>> > >> >>> > +OS_IMPL_DIRS = $(if
> $(OS_API),os/$(OS_CLASS)-$(OS_API),) os/$(OS_CLASS)
> >> >> >>> > >> >>> > GENERIC_SRC_DIRS = .. $(SRC_DIRS)
> >> >> >>> > >> >>> > OS_SRC_DIRS += . $(foreach dir, .. $(SRC_DIRS), \
> >> >> >>> > >> >>> > - $(addprefix $(dir)/, os/$(OS_CLASS)
> $(POSIX_$(POSIX)) os/default ))
> >> >> >>> > >> >>> > + $(addprefix $(dir)/, $(OS_IMPL_DIRS)
> >> >> >>> > >> >>> > CMPLR_SRC_DIRS += . $(foreach dir, .. $(SRC_DIRS), \
> >> >> >>> > >> >>> > $(addprefix $(dir)/, compiler/$(CMPLR_CLASS)
> compiler/default ))
> >> >> >>> > >> >>> > ALL_SRC_DIRS = $(CMPLR_SRC_DIRS) $(OS_SRC_DIRS)
> $(GENERIC_SRC_DIRS)
> >> >> >>> > >> >>> > diff --git a/configure/CONFIG_SITE
> b/configure/CONFIG_SITE
> >> >> >>> > >> >>> > index 09b4c1525..f3aa4b3f7 100644
> >> >> >>> > >> >>> > --- a/configure/CONFIG_SITE
> >> >> >>> > >> >>> > +++ b/configure/CONFIG_SITE
> >> >> >>> > >> >>> > @@ -161,7 +161,7 @@
> USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
> >> >> >>> > >> >>> > # Site version number, if set will append '-' and
> this string to the
> >> >> >>> > >> >>> > # EPICS version number string that is reported by
> many tools.
> >> >> >>> > >> >>> > -EPICS_SITE_VERSION =
> >> >> >>> > >> >>> > +EPICS_SITE_VERSION =
> >> >> >>> > >> >>> > # For GNU compiler, use pipes rather than temporary
> files for
> >> >> >>> > >> >>> > # communication between the various stages of
> compilation.
> >> >> >>> > >> >>> > diff --git a/configure/os/CONFIG.Common.RTEMS
> b/configure/os/CONFIG.Common.RTEMS
> >> >> >>> > >> >>> > index 8425e6ef9..929510d61 100644
> >> >> >>> > >> >>> > --- a/configure/os/CONFIG.Common.RTEMS
> >> >> >>> > >> >>> > +++ b/configure/os/CONFIG.Common.RTEMS
> >> >> >>> > >> >>> > @@ -94,16 +94,28 @@ MODEXT=.obj
> >> >> >>> > >> >>> > # operating system class (include/os/<os_class>)
> >> >> >>> > >> >>> > OS_CLASS = RTEMS
> >> >> >>> > >> >>> > +# operating system API (src/os/<os_class>-<os-api>)
> >> >> >>> > >> >>> > +OS_API_4.7 = kernel
> >> >> >>> > >> >>> > +OS_API_4.8 = kernel
> >> >> >>> > >> >>> > +OS_API_4.9 = kernel
> >> >> >>> > >> >>> > +OS_API_4.10 = kernel
> >> >> >>> > >> >>> > +OS_API = $(firstword $(OS_API_$(RTEMS_SERIES)) posix)
> >> >> >>> > >> >>> > # Operating system flags
> >> >> >>> > >> >>> > -OP_SYS_LDLIBS += -lrtemsCom -lc -lrtemscpu -lCom
> -lnfs -lm
> >> >> >>> > >> >>> > -OP_SYS_LDFLAGS += $(CPU_CFLAGS) -u Init \
> >> >> >>> > >> >>> > +OP_SYS_LDLIBS += -lrtemsCom -lc -lrtemscpu -lCom
> -lnfs -lm
> >> >> >>> > >> >>> > +# newest Rtems > 2019 needs this -ltftpfs
> >> >> >>> > >> >>> > +OP_SYS_LDFLAGS_posix += -u POSIX_Init
> >> >> >>> > >> >>> > +OP_SYS_LDFLAGS_kernel += $(CPU_CFLAGS) -u Init \
> >> >> >>> > >> >>> > $(PROJECT_RELEASE)/lib/no-dpmem.rel
> >> >> >>> > >> >>> > $(PROJECT_RELEASE)/lib/no-mp.rel \
> >> >> >>> > >> >>> > $(PROJECT_RELEASE)/lib/no-part.rel \
> $(PROJECT_RELEASE)/lib/no-signal.rel \
> >> >> >>> > >> >>> > $(PROJECT_RELEASE)/lib/no-rtmon.rel
> >> >> >>> > >> >>> > +OP_SYS_LDFLAGS += $(CPU_FLAGS)
> $(OP_SYS_LDFLAGS_$(OS_API))
> >> >> >>> > >> >>> > MOD_SYS_LDFLAGS += $(CPU_CFLAGS) -Wl,-r -nostdlib
> >> >> >>> > >> >>> > # Do not link against libraries which are part of
> the Generic Image
> >> >> >>> > >> >>> > diff --git a/modules/libcom/RTEMS/Makefile
> b/modules/libcom/RTEMS/Makefile
> >> >> >>> > >> >>> > index b46889db1..cb1a63b97 100644
> >> >> >>> > >> >>> > --- a/modules/libcom/RTEMS/Makefile
> >> >> >>> > >> >>> > +++ b/modules/libcom/RTEMS/Makefile
> >> >> >>> > >> >>> > @@ -11,6 +11,9 @@ TOP = ../../..
> >> >> >>> > >> >>> > include $(TOP)/configure/CONFIG
> >> >> >>> > >> >>> > include $(TOP)/configure/CONFIG_LIBCOM_VERSION
> >> >> >>> > >> >>> > +#for checking
> >> >> >>> > >> >>> > +SRC_DIRS += ../$(OS_API)
> >> >> >>> > >> >>> > PERL_SCRIPTS += epicsMakeMemFs.pl
> >> >> >>> > >> >>> > INC += epicsRtemsInitHooks.h
> >> >> >>> > >> >>> > (END)
> >> >> >>> > >> >>> > I will start with further changes tomorrow. Please
> find the changes pushed
> >> >> >>> > >> >>> > here:
> https://github.com/epics-base/epics-base/compare/7.0...mritunjaysharma394:GSoC_pc-386
> >> >> >>> > >> >>> > I will be pleased to have the feedback and if I am on
> the correct course now.
> >> >> >>> > >> >>> > I will also like to inform that I have filled the
> GSoC Phase 1 Evaluation form and I
> >> >> >>> > >> >>> > will request all my mentors to please feel free to
> fill the form before the deadline
> >> >> >>> > >> >>> > and I hope that from now I will not disappoint with
> my progress.
> >> >> >>> > >> >>> > It is my bad that I still have not been able to
> reach out to one more
> >> >> >>> > >> >>> > mentor Pavel Pisa. Please if possible share the email
> id of Pavel and cc
> >> >> >>> > >> >>> > Pavel in the replies to the email so that Pavel s
> aware of the progress and I
> >> >> >>> > >> >>> > can apologise for my inability to connect with Pavel
> earlier.
> >> >> >>> > >> >>> > Thanks,
> >> >> >>> > >> >>> > Mritunjay.
> >> >> > _______________________________________________
> >> >> > devel mailing list
> >> >> > devel at rtems.org
> >> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200703/dbb2e36f/attachment-0001.html>
