[PATCH] Reflect removal of the epiphany target
Sebastian Huber
Fri Jul 3 05:34:24 UTC 2020
cpu-supplement/epiphany.rst | 89 ++-----------------------------------
user/bsps/bsps-epiphany.rst | 11 -----
user/bsps/index.rst | 1 -
3 files changed, 4 insertions(+), 97 deletions(-)
delete mode 100644 user/bsps/bsps-epiphany.rst
diff --git a/cpu-supplement/epiphany.rst b/cpu-supplement/epiphany.rst
index 7d39476..c2b2d86 100644
--- a/cpu-supplement/epiphany.rst
+++ b/cpu-supplement/epiphany.rst
@@ -1,91 +1,10 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2015 Hesham Almatary
-.. Copyright (C) 1988, 2002 On-Line Applications Research Corporation (OAR)
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
Epiphany Specific Information
-This chapter discusses the`Epiphany Architecture
-http://adapteva.com/docs/epiphany_sdk_ref.pdf dependencies in this port of
-RTEMS. Epiphany is a chip that can come with 16 and 64 cores, each of which can
-run RTEMS separately or they can work together to run a SMP RTEMS application.
-**Architecture Documents**
-For information on the Epiphany architecture refer to the *Epiphany
-Architecture Reference* http://adapteva.com/docs/epiphany_arch_ref.pdf.
-Calling Conventions
-Please refer to the *Epiphany SDK*
-http://adapteva.com/docs/epiphany_sdk_ref.pdf Appendix A: Application Binary
-Interface
-Floating Point Unit
-A floating point unit is currently not supported.
-Memory Model
-A flat 32-bit memory model is supported, no caches. Each core has its own 32
-KiB strictly ordered local memory along with an access to a shared 32 MiB
-external DRAM.
-Interrupt Processing
-Every Epiphany core has 10 exception types:
-- Reset
-- Software Exception
-- Data Page Fault
-- Timer 0
-- Timer 1
-- Message Interrupt
-- DMA0 Interrupt
-- DMA1 Interrupt
-- WANT Interrupt
-- User Interrupt
-Interrupt Levels
-There are only two levels: interrupts enabled and interrupts disabled.
-Interrupt Stack
-The Epiphany RTEMS port uses a dedicated software interrupt stack. The stack
-for interrupts is allocated during interrupt driver initialization. When an
-interrupt is entered, the _ISR_Handler routine is responsible for switching
-from the interrupted task stack to RTEMS software interrupt stack.
-Default Fatal Error Processing
-The default fatal error handler for this architecture performs the following
-actions:
-- disables operating system supported interrupts (IRQ),
-- places the error code in ``r0``, and
-- executes an infinite loop to simulate a halt processor instruction.
-Symmetric Multiprocessing
-SMP is not supported.
+Due to an unmaintained toolchain (internal errors in GCC, no FSF GDB
+integration) the Epiphany architecture was obsoleted in
+RTEMS 5.1 and removed in RTEMS 6.1.
diff --git a/user/bsps/bsps-epiphany.rst b/user/bsps/bsps-epiphany.rst
deleted file mode 100644
index 82b05e6..0000000
--- a/user/bsps/bsps-epiphany.rst
+++ /dev/null
@@ -1,11 +0,0 @@
-.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2018 embedded brains GmbH
-epiphany (Epiphany)
-epiphany_sim
-TODO.
diff --git a/user/bsps/index.rst b/user/bsps/index.rst
index 0c3b2f6..bf590e0 100644
--- a/user/bsps/index.rst
+++ b/user/bsps/index.rst
@@ -27,7 +27,6 @@ You can see the current BSP list in the RTEMS sources by asking RTEMS with:
bsps-aarch64
bsps-arm
bsps-bfin
- bsps-epiphany
bsps-i386
bsps-lm32
bsps-m68k
2.26.2
