[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Fri Jul 3 15:17:12 UTC 2020
Hello Heinz and everyone,
Thank you so much, with this email, I will try to clear all the things, and
what is the status for now.
First. let me tell you the current status: Vijay helped me last night in an
offlist discussion to clear the confusions which
I was having (I will mention them below) due to which I was able to build
and install RTEMS 4.10 for pc386 successfully.
With that, all my previous errors were resolved. Below is the detail of all
the steps, I followed.
Let me tell that my development environment was earlier set up for RTEMS5.
For building EPICS with RTEMS,
I thought it will be right to first build RTEMS 4.10 for pc386.
In order to do that, I made the directory
i) $HOME/development/rtems_dev
ii) I extracted rtems-4.10.2 from here
https://ftp.rtems.org/pub/rtems/releases/4.10/4.10.2/
iii)I created another directory rtems_dev/src
iv)Inside src, I cloned rsb and moved to 4.10 branch.
v) After performing checks, I entered to rsb/rtems and used this command:
'../source-builder/sb-set-builder
--prefix=/home/mritunjay/development/rtems_dev/rtems-4.10.2 4.10/rtems-i386'
Even though the build completed successfully, this was the point where I
made the error. I used the RTEMS source as the prefix which
was causing all the problems.
vi) After the discussion with Vijay and getting cleared, I deleted
everything except the RTEMS RSB and restarted the process with prefix and
source
different this time and rebuilt the compiler tools using RSB.
vii) Now the directory structure under $HOME/development/rtems_dev/ looked
like:
| rtems-4.10.2
| 4.10
| src/rsb
| kernel/pc386
I also used this command: "export
PATH=$HOME/development/rtems_dev/4.10/bin:$PATH"
vi) Then I went to rtems_dev/rtems-4.10.2 and used this command:
"./bootstrap -c &&
$HOME/development/rtems_dev/src/rsb/source-builder/sb-bootstrap"
vi) After this I went
insid directory $HOME/development/rtems_dev/kernel/pc-386
vii) Inside pc-386, I used the following command:
''$HOME/development/rtems_dev/rtems-4.10.2/configure
--target=i386-rtems4.10 --disable-posix --enable-rtemsbsp=pc386
--enable-tests=samples --prefix=/home/development/rtems_dev/rtems-4.10.2
--enable-cxx"
viii) Then I entered the make command which ran successfully and the make
install was also successful.
So all the errors were resolved and I moved on to build EPICS now for RTEMS
4.10.
'''export
RTEMS_MAKEFILE_PATH=$HOME/development/rtems_dev/4.10/i386-rtems4.10/pc386''
Location of epics-base in my system is as follows:
"$HOME/development/EPICS/epics-base"
After this, I followed the tutorial you sent to build EPICS for rterms-4.10
for pc-386 which is:
> Very roughly:
> git clone —recursive epics-base
> in epics-base/configure/CONFIG_SITE
> set
> CROSS_COMPILER_TARGET_ARCHS=
What I entered:
CROSS_COMPILER_TARGET_ARCHS= RTEMS-pc386
> e.g. RTEMS-pc386
> or RTEMS-xilinx_zynq_a9_qemu
> in epics-base/configure/os there must be a file for the target used,
> e.g.
> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
> or
> CONFIG.Common.RTEMS-pc386
Checked. CONFIG.Common.RTEMS-pc386 was there
> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
> where to find RTEMS:
> # Where to find RTEMS
> # APS:
> #RTEMS_VERSION = 4.10.2
> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
In my system, I entered this:
#APS
RTEMS_BASE = /home/mritunjay/development/rtems_dev/$(RTEMS_VERSION)
I followed the above instructions and used the 'make' command.
While the earlier errors are resolved, The latest error that I have
encountered is this after using make command.:
".......Info':
/home/mritunjay/development/EPICS/epics-base/modules/libcom/src/O.RTEMS-pc386/../osi/os/RTEMS/osdThread.c:747:
undefined reference to `pthread_getschedparam'
collect2: ld returned 1 exit status
../../../../configure/RULES_BUILD:212: recipe for target
'libComTestHarness' failed
make[4]: *** [libComTestHarness] Error 1
make[4]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules/libcom/test/O.RTEMS-pc386'
../../../configure/RULES_ARCHS:58: recipe for target 'install.RTEMS-pc386'
failed
make[3]: *** [install.RTEMS-pc386] Error 2
make[3]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules/libcom/test'
../../configure/RULES_DIRS:85: recipe for target 'test.install' failed
make[2]: *** [test.install] Error 2
make[2]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules/libcom'
../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules'
configure/RULES_DIRS:85: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2"
I hope this time I was explicit in writing what I did and what error I am
facing as of now. It would be kind
of you to guide where I am going wrong.
Thanks,
Mritunjay
On Fri, Jul 3, 2020 at 9:03 AM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> Hello, Mritunjay,
> unfortunately i still miss a transcript in which the things you do are
> listed in detail.
> Then we could really help you better.
> Heinz
> > On 3. Jul 2020, at 04:14, Chris Johns <chrisj at rtems.org> wrote:
> > On 3/7/20 9:01 am, Mritunjay Sharma wrote:
> >> Thank you so much Gedare, I think the problem was with confusion
> related to
> >> prefix and source being the same which created a lot of problems.
> >> I just had an offlist discussion with Vijay and he has cleared all my
> doubts and
> >> the mistakes I was making. The problem as of now seems to be resolved.
> > Vijay, thanks for helping and Mritunjay thank you for letting us know.
> > Chris
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200703/2a52dcd8/attachment.html>
