[PATCH] Fix for Beaglebone BSP PWM bug
James Fitzsimons
james.fitzsimons at gmail.com
Sun Jul 5 10:43:21 UTC 2020
Hi all,
I hope that patch is ok, that was my first time using git send-email.
This patch fixes a bug in the Beaglebone BSP where the register offsets for
the PWM outputs on header pins P9_14 and P9_16 are incorrectly calculated.
I'm about to start work on adding the QEP driver to the beaglebone BSP. Is
this list where should I ask questions on BSP changes (coding style, API
design etc), or should I do that on the users list?
Many thanks,
James Fitzsimons
On Sun, 5 Jul 2020 at 22:41, James Fitzsimons <james.fitzsimons at gmail.com>
wrote:
> Fixed incorrect register offset values for EHRPWM1A on P9_14
> and EHRPWM1B on P9_16
> bsps/arm/beagle/pwm/pwm.c | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/bsps/arm/beagle/pwm/pwm.c b/bsps/arm/beagle/pwm/pwm.c
> index 0bc5d125bf..9a346995aa 100644
> --- a/bsps/arm/beagle/pwm/pwm.c
> +++ b/bsps/arm/beagle/pwm/pwm.c
> @@ -102,9 +102,9 @@ bool beagle_pwm_pinmux_setup(bbb_pwm_pin_t pin_no,
> BBB_PWMSS pwm_id)
> } else if (pin_no == BBB_P8_36_1A) {
> REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(10)) =
> BBB_MUXMODE(BBB_P8_36_MUX_PWM);
> } else if (pin_no == BBB_P9_14_1A) {
> - REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(2)) =
> BBB_MUXMODE(BBB_P9_14_MUX_PWM);
> + REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(18)) =
> } else if (pin_no == BBB_P9_16_1B) {
> - REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(3)) =
> BBB_MUXMODE(BBB_P9_16_MUX_PWM);
> + REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(19)) =
> } else {
> is_valid = false;
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200705/141781a7/attachment.html>
