[PATCH 2/2] c-user: Canonicalize document internal references
Sebastian Huber
Tue Jul 7 11:06:14 UTC 2020
This helps to generate Doxygen markup from the application configuration
option specification items.
Update #3994.
c-user/config/classic-api.rst | 7 +--
c-user/config/general.rst | 6 +-
c-user/config/posix-api.rst | 11 ++--
c-user/config/scheduler-general.rst | 87 +++++++++++++----------------
4 files changed, 49 insertions(+), 62 deletions(-)
diff --git a/c-user/config/classic-api.rst b/c-user/config/classic-api.rst
index b72ad30..07c79b2 100644
--- a/c-user/config/classic-api.rst
+++ b/c-user/config/classic-api.rst
@@ -356,11 +356,8 @@ NOTES:
The calculations for the required memory in the RTEMS Workspace for tasks
assume that each task has a minimum stack size and has floating point
- support enabled. The configuration parameter
- ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify task stack requirements
- *ABOVE* the minimum size required. See :ref:`Reserve Task/Thread Stack
- Memory Above Minimum` for more information about
- ``CONFIGURE_EXTRA_TASK_STACKS``.
+ support enabled. The configuration option :ref:`CONFIGURE_EXTRA_TASK_STACKS` is used
+ to specify task stack requirements *above* the minimum size required.
The maximum number of POSIX threads is specified by
:ref:`CONFIGURE_MAXIMUM_POSIX_THREADS`.
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index 08f2a92..d495c7a 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -216,9 +216,9 @@ NOTES:
to perform the sequential system initialization before the multithreading
is started.
- The interrupt stacks are covered by the :ref:`stack checker
- <CONFIGURE_STACK_CHECKER_ENABLED>`. However, using a too small interrupt
- stack size may still result in undefined behaviour.
+ The interrupt stacks are covered by the stack checker, see
+ :ref:`CONFIGURE_STACK_CHECKER_ENABLED`. However, using a too small interrupt stack
+ size may still result in undefined behaviour.
In releases before RTEMS 5.1 the default value was
:ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE` instead of ``CPU_STACK_MINIMUM_SIZE``.
diff --git a/c-user/config/posix-api.rst b/c-user/config/posix-api.rst
index 23aeb62..7a683d4 100644
--- a/c-user/config/posix-api.rst
+++ b/c-user/config/posix-api.rst
@@ -330,13 +330,10 @@ NOTES:
This object class can be configured in unlimited allocation mode, see
:ref:`ConfigUnlimitedObjects`.
- This calculations for the required memory in the RTEMS Workspace for
- threads assume that each thread has a minimum stack size and has floating
- point support enabled. The configuration option
- :ref:`CONFIGURE_EXTRA_TASK_STACKS` is used to specify thread stack
- requirements **above** the minimum size required. See :ref:`Reserve
- Task/Thread Stack Memory Above Minimum` for more information about
+ This calculations for the required memory in the RTEMS Workspace for threads
+ assume that each thread has a minimum stack size and has floating point
+ to specify thread stack requirements **above** the minimum size required.
The maximum number of Classic API Tasks is specified by
:ref:`CONFIGURE_MAXIMUM_TASKS`.
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index c353f16..274a7cf 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -13,17 +13,18 @@ and only necessary in very specific circumstances. A normal application
configuration does not need any of the configuration options described in this
section.
-By default, the :ref:`Deterministic Priority Scheduler <SchedulerPriority>`
+By default, the :ref:`SchedulerPriority`
algorithm is used in uniprocessor configurations. In case SMP is enabled and
the configured maximum processors
(:ref:`CONFIGURE_MAXIMUM_PROCESSORS`) is greater
-than one, then the :ref:`Earliest Deadline First (EDF) SMP Scheduler
-<SchedulerSMPEDF>` is selected as the default scheduler algorithm.
+than one, then the
+:ref:`SchedulerSMPEDF`
+is selected as the default scheduler algorithm.
-For the :ref:`schedulers built into
-RTEMS <SchedulingConcepts>`, the configuration is straightforward. All that is
-required is to define the configuration option which specifies which scheduler
-you want for in your application.
+For the schedulers provided by RTEMS (see :ref:`SchedulingConcepts`), the
+configuration is straightforward. All that is required is to define the
+configuration option which specifies which scheduler you want for in your
+application.
The pluggable scheduler interface also enables the user to provide their own
scheduling algorithm. If you choose to do this, you must define multiple
@@ -183,16 +184,15 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
In case this configuration option is defined, then
- :ref:`Constant Bandwidth Server (CBS) Scheduler <SchedulerCBS>`
+ :ref:`SchedulerCBS`
algorithm is made available to the application.
NOTES:
This scheduler configuration option is an advanced configuration option.
Think twice before you use it.
- In case no explicit :ref:`clustered scheduler configuration
- <ConfigurationSchedulersClustered>` is present, then it is used as the
- scheduler for exactly one processor.
+ In case no explicit :ref:`ConfigurationSchedulersClustered`
+ is present, then it is used as the scheduler for exactly one processor.
.. index:: CONFIGURE_SCHEDULER_EDF
@@ -213,16 +213,15 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
- :ref:`Earliest Deadline First (EDF) Scheduler <SchedulerEDF>`
+ :ref:`SchedulerEDF`
NOTES:
.. index:: CONFIGURE_SCHEDULER_EDF_SMP
@@ -243,7 +242,7 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
- :ref:`Earliest Deadline First (EDF) SMP Scheduler <SchedulerSMPEDF>`
+ :ref:`SchedulerSMPEDF`
NOTES:
@@ -253,9 +252,8 @@ NOTES:
This scheduler algorithm is only available when RTEMS is built with SMP
support enabled.
- scheduler for up to 32 processors.
+ is present, then it is used as the scheduler for up to 32 processors.
This scheduler algorithm is the default in SMP configurations if
:ref:`CONFIGURE_MAXIMUM_PROCESSORS` is
@@ -277,21 +275,21 @@ OPTION TYPE:
DEFAULT VALUE:
The default value is
- * ``"MEDF"`` for the :ref:`EDF SMP Scheduler <SchedulerSMPEDF>`,
+ * ``"MEDF"`` for the :ref:`SchedulerSMPEDF`,
- * ``"MPA "`` for the :ref:`Arbitrary Processor Affinity Priority SMP Scheduler <SchedulerSMPPriorityAffinity>`,
+ * ``"MPA "`` for the :ref:`SchedulerSMPPriorityAffinity`,
- * ``"MPD "`` for the :ref:`Deterministic Priority SMP Scheduler <SchedulerSMPPriority>`,
+ * ``"MPD "`` for the :ref:`SchedulerSMPPriority`,
- * ``"MPS "`` for the :ref:`Simple Priority SMP Scheduler <SchedulerSMPPrioritySimple>`,
+ * ``"MPS "`` for the :ref:`SchedulerSMPPrioritySimple`,
- * ``"UCBS"`` for the :ref:`Uniprocessor CBS Scheduler <SchedulerCBS>`,
+ * ``"UCBS"`` for the :ref:`SchedulerCBS`,
- * ``"UEDF"`` for the :ref:`Uniprocessor EDF Scheduler <SchedulerEDF>`,
+ * ``"UEDF"`` for the :ref:`SchedulerEDF`,
- * ``"UPD "`` for the :ref:`Uniprocessor Deterministic Priority Scheduler <SchedulerPriority>`, and
+ * ``"UPD "`` for the :ref:`SchedulerPriority`, and
- * ``"UPS "`` for the :ref:`Uniprocessor Simple Priority Scheduler <SchedulerPrioritySimple>`.
+ * ``"UPS "`` for the :ref:`SchedulerPrioritySimple`.
VALUE CONSTRAINTS:
The value of this configuration option shall be a valid integer of type
@@ -328,16 +326,15 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
- :ref:`Deterministic Priority Scheduler <SchedulerPriority>`
+ :ref:`SchedulerPriority`
NOTES:
This scheduler algorithm is the default when
@@ -365,7 +362,7 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
- :ref:`Arbitrary Processor Affinity SMP Scheduler <SchedulerSMPPriorityAffinity>`
+ :ref:`SchedulerSMPPriorityAffinity`
NOTES:
@@ -375,9 +372,8 @@ NOTES:
support enabled.
The memory allocated for this scheduler depends on the
:ref:`CONFIGURE_MAXIMUM_PRIORITY` configuration option.
@@ -401,7 +397,7 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
- :ref:`Deterministic Priority SMP Scheduler <SchedulerSMPPriority>`
+ :ref:`SchedulerSMPPriority`
NOTES:
@@ -411,9 +407,8 @@ NOTES:
support enabled.
@@ -437,16 +432,15 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
- :ref:`Simple Priority Scheduler <SchedulerPrioritySimple>`
+ :ref:`SchedulerPrioritySimple`
NOTES:
.. index:: CONFIGURE_SCHEDULER_SIMPLE_SMP
@@ -467,7 +461,7 @@ DEFAULT CONFIGURATION:
DESCRIPTION:
- :ref:`Simple Priority SMP Scheduler <SchedulerSMPPrioritySimple>`
+ :ref:`SchedulerSMPPrioritySimple`
application.
@@ -478,9 +472,8 @@ NOTES:
support enabled.
.. index:: CONFIGURE_SCHEDULER_STRONG_APA
2.26.2
