[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma mritunjaysharma394 at gmail.com
Tue Jul 7 16:14:37 UTC 2020
[UPDATE]: I tried building EPICS with RTEMS5 for pc-386 and pc-386-qemu.
Everything worked fine while building the pc-386 with  RTEMS5.
After this when I entered epics-base and made the following change:
epics-base/os/CONFIG_SITE.Common.RTEMS
RTEMS_VERSION = 5
RTEMS_BASE = /home/mritunjay/development/rtems_dev/$(RTEMS_VERSION)
As an experiment, I ran the make and as expected got the following error
Error:
```...de/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include
        -c ../rtems_init.c
../rtems_init.c:21:10: fatal error: sys/termios.h: No such file or directory
 #include <sys/termios.h>
compilation terminated.
../../../../configure/RULES_BUILD:240: recipe for target 'rtems_init.o'
failed
make[4]: *** [rtems_init.o] Error 1
make[4]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS/O.RTEMS-pc386'
../../../configure/RULES_ARCHS:58: recipe for target 'install.RTEMS-pc386'
failed
make[3]: *** [install.RTEMS-pc386] Error 2
make[3]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS'
../../configure/RULES_DIRS:85: recipe for target 'RTEMS.install' failed
make[2]: *** [RTEMS.install] Error 2
make[2]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules/libcom'
../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory
'/home/mritunjay/development/EPICS/epics-base/modules'
configure/RULES_DIRS:85: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
I am trying to figure out the error and making the changes in code to debug
it.
However, I will appreciate if Heinz and everyone else can help me a little,
if they have an
idea of this error.
Thanks
Mritunjay
On Tue, Jul 7, 2020 at 7:30 PM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> On Tue, Jul 7, 2020 at 5:33 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Jul 6, 2020 at 5:49 PM Joel Sherrill <joel at rtems.org> wrote:
>> > On Mon, Jul 6, 2020, 6:14 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Mon, Jul 6, 2020 at 10:12 AM Mritunjay Sharma
>> >> <mritunjaysharma394 at gmail.com> wrote:
>> >> > Hello everyone,
>> >> > Thank you, Heinz, Gedare, Chris and Joel for your advice.
>> >> > If there are issues in making a buildset for 4.10
>> >> > then should I build EPICS with RTEMS 5 by hand first and note
>> >> > down the process and then proceed to make the buildset for it?
>> >> Yes.
>> > +1
>> > And by 5, we definitely mean the 5 branch for all rtems repo and the
>> similarly named one for libbsd.
>> Excellent point. We want to add support for easy build (and eventually
>> test) of EPICS+RTEMS starting with 5.1 and moving forward, which means
>> also doing it for RTEMS 6, Mritunjay.
>> Sounds good, I have begun building it hand by today for RTEMS 5 branch
> and later on continue the
> same for RTEMS6
> Thank you so much Gedare and Joel.
> Mritunjay
>> >> > Please suggest for the future steps.
>> >> > Thanks
>> >> > Mritunjay
>> >> > On Mon, Jul 6, 2020 at 5:38 AM Joel Sherrill <joel at rtems.org> wrote:
>> >> >> On Sun, Jul 5, 2020, 6:12 PM Chris Johns <chrisj at rtems.org> wrote:
>> >> >>> On 6/7/20 12:47 am, Heinz Junkes wrote:
>> >> >>> > Thank you, this is exactly where I was unsure.
>> >> >>> > @Chris: Can you give a recommendation here?
>> >> >>> > Danke Heinz
>> >> >>> > Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
>> >> >>> > Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
>> >> >>> > Faradayweg 4-6        | VC: 102220181216 at bjn.vc
>> >> >>> > D - 14195 Berlin        | E-Mail:
>> junkes at fhi-berlin.mpg.de
>> >> >>> >> On 5. Jul 2020, at 16:20, Gedare Bloom <gedare at rtems.org>
>> wrote:
>> >> >>> >> On Sat, Jul 4, 2020 at 1:18 PM Mritunjay Sharma
>> >> >>> >>> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <
>> junkes at fhi-berlin.mpg.de> wrote:
>> >> >>> >>>> Hello, Mritunjay,
>> >> >>> >>>> that's good news. Don't you want to try to develop a rsb-set
>> for exactly this combination of RTEMS4.10 and EPICS7?
>> >> >>> >>> Sure, I am ready to do this and then do it with RTEMS5 in the
>> same way. Please tell how to begin or some existing similar
>> >> >>> >>> work that can guide me how to proceed further in relation to
>> rsb-set for  RTEMS4.10 and EPICS7.
>> >> >>> >> I don't know if this is best. RSB didn't exist in 4.10. I
>> haven't
>> >> >>> >> looked to see how well the rtems-source-builder/4.10 would
>> support a
>> >> >>> >> package build. It should be discussed with Chris probably. A
>> couple of
>> >> >>> >> packages were added in the 4.11 branch.
>> >> >>> I would leave 4.10 and move on. It may work but these things can
>> expose issues
>> >> >>> that turn into distractions.
>> >> >>> Would making a script that does the build so we can document the
>> steps be worth
>> >> >>> while
>> >> >> Yes. Emphatically yes. We need to make sure we know how it is best
>> built by hand to automate it.
>> >> >> I firmly believe you should not attempt to automate something until
>> doing it manually is well understood and documented.
>> >> >> After you have this down for one BSP, we need to ask questions like:
>> >> >> + Is there any per BSP tailoring beyond the obviod architecture and
>> compilation settings?
>> >> >> + Any tweaks to settings users may want?
>> >> >> The manual process should include testing. The RSB is a great way
>> to automate and ease building but it doesn't address testing the packages
>> yet.
>> >> >> --joel
>> >> >>> Chris
>> >> >>> _______________________________________________
>> >> >>> devel mailing list
>> >> >>> devel at rtems.org
>> >> >>> http://lists.rtems.org/mailman/listinfo/devel
>> >> >> devel mailing list
>> >> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200707/040219af/attachment.html>
