[PATCH] common: Remove probably superfluous import
Sebastian Huber
Wed Jul 8 04:33:30 UTC 2020
On 08/07/2020 03:11, Chris Johns wrote:
> On 7/7/20 3:29 pm, Sebastian Huber wrote:
>> The purpose of this import is unclear.
>> This import caused the following error with Sphinx 3.0:
>> Extension error:
>> Could not import extension rtemsdomain (exception: cannot import name 'l_')
>> common/rtemsdomain.py | 1 -
>> 1 file changed, 1 deletion(-)
>> diff --git a/common/rtemsdomain.py b/common/rtemsdomain.py
>> index 49d0728..9b092a3 100644
>> --- a/common/rtemsdomain.py
>> +++ b/common/rtemsdomain.py
>> @@ -3,7 +3,6 @@ from docutils.parsers.rst import directives
>> from sphinx import addnodes
>> from sphinx.roles import XRefRole
>> -from sphinx.locale import l_, _
> Is this backwards compatible?
It seems to work also with Sphinx 2.4. I didn't find uses of "l_" and
"_" in the file.
