[PATCH v1 1/1] bsps/pc386: Fix IPI for non-consecutive APICIDs
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Wed Jul 8 06:55:25 UTC 2020
Hello,
Could someone please push this patch to the branches 5 and master?
Or do I need a ticket for the 5 branch first?
Cheers,
   Jan
> -----Original Message-----
> From: Sommer, Jan
> Sent: Friday, July 3, 2020 2:32 PM
> To: devel at rtems.org
> Cc: Sommer, Jan
> Subject: [PATCH v1 1/1] bsps/pc386: Fix IPI for non-consecutive APICIDs
> - properly use the cpu <-> apic maps for IPIs
>  bsps/i386/pc386/start/smp-imps.c | 16 ++++++++++------
>  1 file changed, 10 insertions(+), 6 deletions(-)
> diff --git a/bsps/i386/pc386/start/smp-imps.c b/bsps/i386/pc386/start/smp-
> imps.c
> index 0985b8f08f..763ac0afc7 100644
> --- a/bsps/i386/pc386/start/smp-imps.c
> +++ b/bsps/i386/pc386/start/smp-imps.c
> @@ -226,9 +226,11 @@ get_checksum(unsigned start, int length)
>  int
>  send_ipi(unsigned int dst, unsigned int v)
> -  int to, send_status;
> +  int to, send_status, apicid;
> -  IMPS_LAPIC_WRITE(LAPIC_ICR+0x10, (dst << 24));
> +  apicid = imps_cpu_apic_map[dst];
> +  IMPS_LAPIC_WRITE(LAPIC_ICR+0x10, (apicid << 24));
>    IMPS_LAPIC_WRITE(LAPIC_ICR, v);
>    /* Wait for send to finish */
> @@ -251,9 +253,11 @@ static int
>  boot_cpu(imps_processor *proc)
>    int apicid = proc->apic_id, success = 1;
> +  int cpuid;
>    unsigned bootaddr;
>    unsigned bios_reset_vector = PHYS_TO_VIRTUAL(BIOS_RESET_VECTOR);
> +  cpuid = imps_apic_cpu_map[apicid];
>     * Copy boot code for secondary CPUs here.  Find it in between
>     * "patch_code_start" and "patch_code_end" symbols.  The other CPUs
> @@ -276,7 +280,7 @@ boot_cpu(imps_processor *proc)
>    /* Pass start function, stack region and gdtdescr to AP
>     * see startAP.S for location */
>    reset[1] = (uint32_t)secondary_cpu_initialize;
> -  reset[2] = (uint32_t)_Per_CPU_Get_by_index(apicid)-
> >interrupt_stack_high;
> +  reset[2] = (uint32_t)_Per_CPU_Get_by_index(cpuid)-
>    memcpy(
>    	(char*) &reset[3],
>    	&gdtdesc,
> @@ -295,13 +299,13 @@ boot_cpu(imps_processor *proc)
>    /* assert INIT IPI */
>    send_ipi(
> -    apicid,
> +    cpuid,
>      LAPIC_ICR_TM_LEVEL | LAPIC_ICR_LEVELASSERT | LAPIC_ICR_DM_INIT
>    UDELAY(10000);
>    /* de-assert INIT IPI */
> -  send_ipi(apicid, LAPIC_ICR_TM_LEVEL | LAPIC_ICR_DM_INIT);
> +  send_ipi(cpuid, LAPIC_ICR_TM_LEVEL | LAPIC_ICR_DM_INIT);
>    UDELAY(10000);
> @@ -312,7 +316,7 @@ boot_cpu(imps_processor *proc)
>    if (proc->apic_ver >= APIC_VER_NEW) {
>      int i;
>      for (i = 1; i <= 2; i++) {
> -      send_ipi(apicid, LAPIC_ICR_DM_SIPI | ((bootaddr >> 12) & 0xFF));
> +      send_ipi(cpuid, LAPIC_ICR_DM_SIPI | ((bootaddr >> 12) & 0xFF));
>        UDELAY(1000);
> 2.17.1
