NEW BUILD SYSTEM: Cannot build rtems-libbsd
Niteesh G. S. niteesh.gs at gmail.com
Wed Jul 8 07:22:22 UTC 2020
On Wed, Jul 8, 2020 at 12:11 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 08/07/2020 08:35, Niteesh G. S. wrote:
> > On Wed, Jul 8, 2020 at 11:52 AM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> >     On 08/07/2020 08:13, Sebastian Huber wrote:
> >     > On 08/07/2020 08:10, Niteesh G. S. wrote:
> >     >> On Tue, Jul 7, 2020 at 10:42 AM Sebastian Huber
> >     >> <sebastian.huber at embedded-brains.de
> >     <mailto:sebastian.huber at embedded-brains.de>
> >     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> >     >>     Hello,
> >     >>     the problem is that the new build system doesn't export
> >     optimization
> >     >>     flags such as -Wl,--gc-sections. The libbsd build should
> >     enable this
> >     >>     linker option unconditionally.
> >     >> Thank you. I got it fixed (temporarily) by modifying rtems.py.
> >     >> conf.env.CFLAGS    = cflags['cflags'] + ['-ffunction-sections'] +
> >     >> ['-fdata-sections']
> >     > This instructs the compiler to add data elements and functions into
> >     > separate sections. This is necessary so that the linker can carry
> out
> >     > the garbage collection.
> >     There is an unused function in libbsd that can't link because a
> function
> >     it calls isn't there. Till now the two flags had been provided by the
> >     BSP. It seems that now they are not provided anymore.
> >     The problematic function is m_unmappedtouio in uipc_mbuf.c. It tries
> to
> >     use PHYS_TO_VM_PAGE which isn't defined in libbsd. I think we should
> >     just remove m_unmappedtouio (with #ifndef __rtems__) on the longer
> term.
> >     But not having the -ffunction-sections and -fdata-sections most
> likely
> >     makes our binary bigger and maybe leads to other similar bugs.
> Therefore
> >     I suggested to add the CFLAGS first.
> >     >> As per Christian suggestions, I tried exporting CFLAGS with these
> GCC
> >     >> flags and then calling ./waf configure but they didn't work.
> >     > You have to add -Wl,--gc-sections to the linker flags.
> >     As far as I know Niteesh used that one too. I think for that one
> LDFLAGS
> >     worked as a workarround.
> > Yes, I did try exporting LDFLAGS too but they also didn't work out.
> > I tried the following:
> > 1) export LDFLAGS="-Wl,--gc-sections"
> > 2) ./waf configure --prefix=$RTEMS/6 --rtems-version=6
> > --rtems-bsps=arm/beagleboneblack --buildset=buildset/minimal.ini
> > I also tried running
> > 1) LDFLAGS="-Wl,--gc-sections" ./waf configure --prefix=$RTEMS/6
> > --rtems-version=6 --rtems-bsps=arm/beagleboneblack
> > Both of them didn't work out.
> Have the flags been ignored and not used or did that not fix the
> problem? I would assume the second. You should see the difference if you
> call "./waf -v" and take a look at one of the linker calls to generate
> the test applications.
Yes, it is the second case. The linker flags are being used but it doesn't
fix the problem.
I used the following commands to ensure this.
3) ./waf -j1 -v
On using the above commands I get the following output
['/home/niteesh/development/rtems/6/bin/arm-rtems6-gcc', '-qrtems',
'-B/home/niteesh/development/rtems/6/arm-rtems6/beagleboneblack/lib',
'-mcpu=cortex-a8', '-MMD', 'testsuite/arphole/test_main.c.45.o',
'-o/home/niteesh/development/rtems/rtems-libbsd/build/arm-rtems6-beagleboneblack-minimal/arphole.exe',
'-Wl,-Bstatic', '-L.', '-lbsd', '-Wl,-Bdynamic', '-lbsd', '-lm', '-lz',
'-lrtemstest',* '-Wl,--gc-sections'*]
I then tried unsetting the LDFLAGS
1) unset LDFLAGS
3) ./waf -j1 -v
Using the above commands give the following output
'-lrtemstest']
If this help,
With the LDFLAGS set already, ./waf configure doesn't mention that is
already defined
but when the CFLAGS are set, for eg: export CFLAGS="-ffunction-sections"
./waf configure mentions that CFLAGS is already been set
Pasting the ./waf configure output
Setting top to                           :
Setting out to                           :
Environment variable set                 : CFLAGS
RTEMS Version                            : 6
Architectures                            : arm-rtems6
Board Support Package (BSP)              : arm-rtems6-beagleboneblack
Show commands                            : no
Long commands                            : no
But it doesn't do the same for LDFLAGS
output of ./waf configure
Setting top to                           :
Setting out to                           :
RTEMS Version                            : 6
Show commands                            : no
Long commands                            : no
> > I might be wrong here but waf seems to add the "-Wl,--gc-sections"
> > flags if "--function-sections" flags are defined.
> > https://git.rtems.org/rtems_waf/tree/rtems.py#n389
> That's a bit odd. I don't think that I ever used that flag. But you are
> right: If CFLAGS contains the -function-section (only one -),
> "-Wl,--gc-sections" is added to the LDFLAGS here.
> >     Best regards
> >     Christian
> >     embedded brains GmbH
> >     Herr Christian Mauderer
> >     Dornierstr. 4
> >     D-82178 Puchheim
> >     Germany
> >     email: christian.mauderer at embedded-brains.de
> >     Phone: +49-89-18 94 741 - 18
> >     Fax:   +49-89-18 94 741 - 08
> >     PGP: Public key available on request.
> >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200708/0459eb84/attachment-0001.html>
