[PATCH rtems-littlevgl] Allow to pass custom lv_conf.h and lv_drv_conf.h.
Christian Mauderer oss at c-mauderer.de
Thu Jul 9 18:41:27 UTC 2020
Hello Vijay,
thanks for the review and the test.
On 09/07/2020 19:58, Vijay Kumar Banerjee wrote:
> Hi,
> Thanks for the patch, I tested the patch and it's building fine. I
> just had two questions which I have inlined below.
> On Thu, Jul 9, 2020 at 9:13 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>>  lv_conf.h => default_lv_conf.h         |  0
>>  lv_drv_conf.h => default_lv_drv_conf.h |  0
>>  lvgl.py                                | 19 ++++++++++++++++---
>>  wscript                                | 13 +++++++++++++
>>  4 files changed, 29 insertions(+), 3 deletions(-)
>>  rename lv_conf.h => default_lv_conf.h (100%)
>>  rename lv_drv_conf.h => default_lv_drv_conf.h (100%)
>> diff --git a/lv_conf.h b/default_lv_conf.h
>> similarity index 100%
>> rename from lv_conf.h
>> rename to default_lv_conf.h
>> diff --git a/lv_drv_conf.h b/default_lv_drv_conf.h
>> rename from lv_drv_conf.h
>> rename to default_lv_drv_conf.h
>> diff --git a/lvgl.py b/lvgl.py
>> index c154a5e..6d55db7 100644
>> --- a/lvgl.py
>> +++ b/lvgl.py
>> @@ -73,6 +73,17 @@ def build(bld):
>>      includes.append('.')
>>      include_paths = []
>> +    def write_stuff(stuff):
>> +        def stuff_writer(task):
>> +            task.outputs[0].write(stuff)
>> +        return stuff_writer
>> +    lv_conf_h='lv_conf.h'
>> +    lv_drv_conf_h='lv_drv_conf.h'
>> +    bld(rule=write_stuff(bld.env.LV_CONF), target=lv_conf_h)
>> +    bld(rule=write_stuff(bld.env.LV_DRV_CONF), target=lv_drv_conf_h)
>>      for source in sources:
>>          source_dir = os.path.dirname(source)
>>          if source_dir not in include_paths:
>> @@ -80,7 +91,7 @@ def build(bld):
>>      bld.stlib(target = 'lvgl',
>>                features = 'c',
>> -              cflags = ['-O2', '-g'],
>> +              cflags = ['-O2', '-g', '-DLV_CONF_INCLUDE_SIMPLE'],
>>                includes = includes,
>>                source = sources)
>> @@ -96,6 +107,8 @@ def build(bld):
>>      for include_path in include_paths:
>>          files = os.listdir(include_path)
>>          include_headers = [os.path.join(include_path, x) for x in files if (x[-2:] == '.h')]
>> -        bld.install_files(os.path.join("${PREFIX}/" , arch_inc_path, include_path),
>> +        bld.install_files(os.path.join("${PREFIX}", arch_inc_path, include_path),
>>                            include_headers)
>> -    bld.install_files('${PREFIX}/' + arch_lib_path, ["liblvgl.a"])
>> +    bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ["liblvgl.a"])
>> +    bld.install_files(os.path.join('${PREFIX}', arch_inc_path, include_path),
>> +        [lv_conf_h])
> Should lv_drv_conf_h be installed as well?
I haven't seen that it is used but I can install it too. I didn't test
all drivers.
>> diff --git a/wscript b/wscript
>> index ae91daa..0e1a51d 100644
>> --- a/wscript
>> +++ b/wscript
>> @@ -49,9 +49,22 @@ def options(opt):
>>                     dest = "drivers",
>>                     help = "Build without lv_drivers." +
>>                            "Useful for building without libbsd.")
>> +    opt.add_option("--lv-conf",
>> +                   default = "default_lv_conf.h",
>> +                   dest = "lv_conf",
>> +                   help = "Use a custom lv_conf.h instead of the default one.")
>> +    opt.add_option("--lv-drv-conf",
>> +                   default = "default_lv_drv_conf.h",
>> +                   dest = "lv_drv_conf",
>> +                   help = "Use a custom lv_drv_conf.h instead of the default one.")
>>  def configure(conf):
>>      conf.env.DRIVERS = conf.options.drivers
>> +    with open(conf.options.lv_conf, "rb") as lv_conf:
>> +        conf.env.LV_CONF = lv_conf.read()
>> +    with open(conf.options.lv_drv_conf, "rb") as lv_drv_conf:
>> +        conf.env.LV_DRV_CONF = lv_drv_conf.read()
>> +    conf.env.BUILDINCLUDE = 'build-include'
> It's not clear to me where is build-include being used. It builds fine
> without this line, should it be removed from the patch?
That is a part of a dead end during writing the patch. I missed to
remove it. Thanks for finding it.
Best regards
Christian
> Thanks for working on this feature, it was much needed.
> Best regards,
> Vijay
>>      rtems.configure(conf)
>>  def build(bld):
>> 2.26.2
> devel mailing list
> devel at rtems.org
