make error on 5 branch?
Gedare Bloom
gedare at rtems.org
Thu Jul 9 19:39:22 UTC 2020
It turns out there are some changes in my rtems.git/5 HEAD. I don't
know how they got there. Maybe just some leftover changes while
switching branches. curious, but I cleaned up the branch and things
are working.
I don't know if there's a way to make a warning appear for a dirty
tree. just something to keep an eye on I guess.
For those curious:
$ git status
modified: c/src/lib/libbsp/arm/acinclude.m4
modified: c/src/lib/libbsp/bfin/acinclude.m4
modified: c/src/lib/libbsp/epiphany/acinclude.m4
modified: c/src/lib/libbsp/i386/acinclude.m4
modified: c/src/lib/libbsp/lm32/acinclude.m4
modified: c/src/lib/libbsp/m68k/acinclude.m4
modified: c/src/lib/libbsp/mips/acinclude.m4
modified: c/src/lib/libbsp/moxie/acinclude.m4
modified: c/src/lib/libbsp/nios2/acinclude.m4
modified: c/src/lib/libbsp/no_cpu/acinclude.m4
modified: c/src/lib/libbsp/or1k/acinclude.m4
modified: c/src/lib/libbsp/powerpc/acinclude.m4
modified: c/src/lib/libbsp/riscv/acinclude.m4
modified: c/src/lib/libbsp/sh/acinclude.m4
modified: c/src/lib/libbsp/sparc/acinclude.m4
modified: c/src/lib/libbsp/sparc64/acinclude.m4
modified: c/src/lib/libbsp/v850/acinclude.m4
modified: c/src/lib/libbsp/x86_64/acinclude.m4
$ git diff c/src/lib/libbsp/sparc/acinclude.m4
diff --git a/c/src/lib/libbsp/sparc/acinclude.m4
b/c/src/lib/libbsp/sparc/acinclude.m4
index 4d40305601..296a6f7882 100644
--- a/c/src/lib/libbsp/sparc/acinclude.m4
+++ b/c/src/lib/libbsp/sparc/acinclude.m4
@@ -2,12 +2,6 @@
AC_DEFUN([RTEMS_CHECK_BSPDIR],
case "$1" in
- erc32 )
- AC_CONFIG_SUBDIRS([erc32]);;
- leon2 )
- AC_CONFIG_SUBDIRS([leon2]);;
- leon3 )
- AC_CONFIG_SUBDIRS([leon3]);;
AC_MSG_ERROR([Invalid BSP]);;
esac
On Thu, Jul 9, 2020 at 9:58 AM Gedare Bloom <gedare at rtems.org> wrote:
> I built/installed clean tools from rsb/5 and bootstrapped rtems/5 then:
> ../../rtems/configure --prefix=/home/gedare/development/rtems/5
> --target=sparc-rtems5 --enable-rtemsbsp=erc32 --enable-posix
> --enable-tests
> [...] looks ok
> make
> checking for RTEMS_BSP... erc32
> configure: error: Invalid BSP
> configure: error:
> ../../../../../../../../rtems/c/src/lib/libbsp/sparc/configure failed
> for lib/libbsp/sparc
> Makefile:731: recipe for target 'erc32' failed
> Can anyone reproduce?
