[PATCH v2 0/1] Document the new build system
Fri Jul 10 13:47:53 UTC 2020
This patch set adds an updated documetation of the new build system.
You can have a look at the generated documents here:
https://ftp.rtems.org/pub/rtems/people/sebh/eng.pdf
This second version of the patch addesses some review comments from
Gedare Bloom.
Sebastian Huber (1):
  eng: Add build system chapter
 eng/build-system.rst     | 488 +++++++++++++++++++++++++++++++++++++++
 eng/index.rst            |   1 +
 images/eng/bld-bsp.dot   |  33 +++
 images/eng/bld-bsp.pdf   | Bin 0 -> 15044 bytes
 images/eng/bld-bsp.png   | Bin 0 -> 32435 bytes
 images/eng/bld-bsp2.dot  |  42 ++++
 images/eng/bld-bsp2.pdf  | Bin 0 -> 16314 bytes
 images/eng/bld-bsp2.png  | Bin 0 -> 33936 bytes
 images/eng/bld-deps.dot  |  59 +++++
 images/eng/bld-deps.pdf  | Bin 0 -> 18559 bytes
 images/eng/bld-deps.png  | Bin 0 -> 18098 bytes
 images/eng/bld-deps2.dot |  52 +++++
 images/eng/bld-deps2.pdf | Bin 0 -> 18241 bytes
 images/eng/bld-deps2.png | Bin 0 -> 40695 bytes
 14 files changed, 675 insertions(+)
 create mode 100644 eng/build-system.rst
 create mode 100644 images/eng/bld-bsp.dot
 create mode 100644 images/eng/bld-bsp.pdf
 create mode 100644 images/eng/bld-bsp.png
 create mode 100644 images/eng/bld-bsp2.dot
 create mode 100644 images/eng/bld-bsp2.pdf
 create mode 100644 images/eng/bld-bsp2.png
 create mode 100644 images/eng/bld-deps.dot
 create mode 100644 images/eng/bld-deps.pdf
 create mode 100644 images/eng/bld-deps.png
 create mode 100644 images/eng/bld-deps2.dot
 create mode 100644 images/eng/bld-deps2.pdf
 create mode 100644 images/eng/bld-deps2.png
2.26.2
