[PATCH] Fix for Beaglebone BSP PWM bug
Christian Mauderer
oss at c-mauderer.de
Sat Jul 11 18:27:22 UTC 2020
Hello Fitzsimons,
sorry for the late review and thanks Chris for poking me.
I have some troubles understanding the patch and the current code:
== Regarding your patch:
There is no pin GPMC_AD(18) or GPMC_AD(19). That offset will lead you to
the pins GPMC_A8 and GPMC_A9. The correct macros to use would be
AM335X_CONF_GPMC_A8 and AM335X_CONF_GPMC_A9. But that's only a style topic.
What's a bit odd is that GPMC_A8 seems to be connected to the LED USR3
on the BBB. Reasonable output for a PWM. But GPMC_A9 is a HDMI_INT,
which seems a bit odd.
== Regarding the old pins
The old pins on the other hand (GPMC_AD2 and AD3) are connected to
MMC1_DAT2 and 3 which is on P8 pin 5 and 6. That sounds a lot more
reasonable. But the pins are definitively not what the pin_no suggests.
== What (maybe) should be the correct one
P9_14 and P9_16 are EHRPWM1A and EHRPWM1B on the beagle schematic. These
are GPMC_AD8 and GPMC_AD9. These pins have a PWM function as an
alternative function. So I would expect that you have to use these.
It's really hard to find a documentation from TI for the pinmux but I
found a list:
https://git.ti.com/cgit/sitara-dss-files/am335x-dss-files/tree/padconf/am335x-pinmux.data
Can you please double check the registers used in your patch?
Best regards
Christian
On 05/07/2020 12:39, James Fitzsimons wrote:
> Fixed incorrect register offset values for EHRPWM1A on P9_14
> and EHRPWM1B on P9_16
> bsps/arm/beagle/pwm/pwm.c | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/bsps/arm/beagle/pwm/pwm.c b/bsps/arm/beagle/pwm/pwm.c
> index 0bc5d125bf..9a346995aa 100644
> --- a/bsps/arm/beagle/pwm/pwm.c
> +++ b/bsps/arm/beagle/pwm/pwm.c
> @@ -102,9 +102,9 @@ bool beagle_pwm_pinmux_setup(bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id)
> } else if (pin_no == BBB_P8_36_1A) {
> REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_LCD_DATA(10)) = BBB_MUXMODE(BBB_P8_36_MUX_PWM);
> } else if (pin_no == BBB_P9_14_1A) {
> - REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(2)) = BBB_MUXMODE(BBB_P9_14_MUX_PWM);
> + REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(18)) = BBB_MUXMODE(BBB_P9_14_MUX_PWM);
> } else if (pin_no == BBB_P9_16_1B) {
> - REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(3)) = BBB_MUXMODE(BBB_P9_16_MUX_PWM);
> + REG(AM335X_PADCONF_BASE + BBB_CONTROL_CONF_GPMC_AD(19)) = BBB_MUXMODE(BBB_P9_16_MUX_PWM);
> } else {
> is_valid = false;
