[PATCH 01/16] rtems: Remove _RTEMS_version
Sebastian Huber
Mon Jul 13 06:51:47 UTC 2020
Move declaration and rename constant in _Version_String.
Close #3978.
bsps/shared/rtems-version.c | 2 +-
cpukit/include/rtems/score/copyrt.h | 5 +++++
cpukit/include/rtems/system.h | 6 ------
cpukit/sapi/src/getversionstring.c | 5 ++---
testsuites/sptests/spsize/size.c | 2 +-
5 files changed, 9 insertions(+), 11 deletions(-)
diff --git a/bsps/shared/rtems-version.c b/bsps/shared/rtems-version.c
index 99b98966e6..26f7a5731a 100644
--- a/bsps/shared/rtems-version.c
+++ b/bsps/shared/rtems-version.c
@@ -25,7 +25,7 @@
#error "Missing RTEMS_BSP"
#endif
-const char _RTEMS_version[] =
+const char _Version_String[] =
"rtems-" RTEMS_VERSION " (" CPU_NAME "/" CPU_MODEL_NAME "/"
RTEMS_XSTRING( RTEMS_BSP ) ")";
diff --git a/cpukit/include/rtems/score/copyrt.h b/cpukit/include/rtems/score/copyrt.h
index c7b00b4247..7addf4dbda 100644
--- a/cpukit/include/rtems/score/copyrt.h
+++ b/cpukit/include/rtems/score/copyrt.h
@@ -41,6 +41,11 @@ extern "C" {
extern const char _Copyright_Notice[];
+ * @brief The RTEMS version string.
+extern const char _Version_String[];
#ifdef __cplusplus
#endif
diff --git a/cpukit/include/rtems/system.h b/cpukit/include/rtems/system.h
index 032ac56a95..3a2dff9721 100644
--- a/cpukit/include/rtems/system.h
+++ b/cpukit/include/rtems/system.h
@@ -39,12 +39,6 @@ extern "C" {
#ifndef ASM
- * The use of this variable is deprecated, use rtems_get_version_string()
- * instead.
-extern RTEMS_DEPRECATED const char _RTEMS_version[];
* The following is the extern for the RTEMS copyright string.
diff --git a/cpukit/sapi/src/getversionstring.c b/cpukit/sapi/src/getversionstring.c
index f3fada9c48..4f29db0350 100644
--- a/cpukit/sapi/src/getversionstring.c
+++ b/cpukit/sapi/src/getversionstring.c
@@ -19,11 +19,10 @@
#include "config.h"
#endif
-#pragma GCC diagnostic ignored "-Wdeprecated-declarations"
+#include <rtems/score/copyrt.h>
const char *rtems_get_version_string(void)
- return _RTEMS_version;
+ return _Version_String;
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index d26e34f51d..ca6c3fc538 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -432,7 +432,7 @@ uninitialized += (sizeof _CPU_Interrupt_stack_low) +
initialized +=
/*copyrt.h*/ (strlen(_Copyright_Notice)+1) +
- (strlen(_RTEMS_version)+1);
+ (strlen(_Version_String)+1);
2.26.2
