[PATCH 14/16] rtems: Remove support for RTEMS_DEPRECATED_TYPES
Mon Jul 13 06:52:00 UTC 2020
Close #3584.
 cpukit/include/rtems/rtems/types.h    | 23 -----------------------
 cpukit/include/rtems/score/basedefs.h |  6 ------
 2 files changed, 29 deletions(-)
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index 994e097afa..e5dd1afc3b 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -44,29 +44,6 @@ extern "C" {
-#ifdef RTEMS_DEPRECATED_TYPES
- * @brief Single precision float type.
- * @deprecated Use @c float instead.
-typedef single_precision rtems_single RTEMS_DEPRECATED;
- * @brief Double precision float type.
- * @deprecated Use @c double instead.
-typedef double_precision rtems_double RTEMS_DEPRECATED;
- * @brief RTEMS boolean type.
- * @deprecated Use @c bool instead
-typedef boolean          rtems_boolean RTEMS_DEPRECATED;
-#endif
  * @brief Classic API @ref ClassicRTEMSSubSecObjectNames "object name" type.
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 01c773ffe9..95d5fc2999 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -549,12 +549,6 @@ extern void RTEMS_DEQUALIFY_types_not_compatible(void);
 #define RTEMS_XSTRING( _x ) RTEMS_STRING( _x )
 #ifndef ASM
-  #ifdef RTEMS_DEPRECATED_TYPES
-    typedef bool boolean RTEMS_DEPRECATED;
-    typedef float single_precision RTEMS_DEPRECATED;
-    typedef double double_precision RTEMS_DEPRECATED;
-  #endif
    * XXX: Eventually proc_ptr needs to disappear!!!
2.26.2
