[PATCH 05/16] rtems: Remove deprecated rtems_io_lookup_name()
    Sebastian Huber
    Mon Jul 13 06:51:51 UTC 2020
Close #3420.
 cpukit/include/rtems/io.h      | 17 +----------------
 cpukit/libfs/src/imfs/ioman.c  | 21 ---------------------
 testsuites/sptests/sp21/init.c | 21 ---------------------
 3 files changed, 1 insertion(+), 58 deletions(-)
diff --git a/cpukit/include/rtems/io.h b/cpukit/include/rtems/io.h
index 972a0aa431..f4066b647a 100644
--- a/cpukit/include/rtems/io.h
+++ b/cpukit/include/rtems/io.h
@@ -4,7 +4,7 @@
  * @brief Classic Input/Output Manager API
  * This file emulates the old Classic RTEMS IO manager directives
- * which register and lookup names using the in-memory filesystem.
+ * which register names using the in-memory filesystem.
@@ -231,21 +231,6 @@ rtems_status_code rtems_io_control(
-typedef struct {
-    const char               *device_name;
-    size_t                    device_name_length;
-    rtems_device_major_number major;
-    rtems_device_minor_number minor;
-} rtems_driver_name_t;
- * @deprecated Use stat() instead.
-rtems_status_code rtems_io_lookup_name(
-    const char           *name,
-    rtems_driver_name_t  *device_info
-) RTEMS_DEPRECATED;
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/libfs/src/imfs/ioman.c b/cpukit/libfs/src/imfs/ioman.c
index 59b93e400c..55fb1728b5 100644
--- a/cpukit/libfs/src/imfs/ioman.c
+++ b/cpukit/libfs/src/imfs/ioman.c
@@ -45,24 +45,3 @@ rtems_status_code rtems_io_register_name(
   return RTEMS_SUCCESSFUL;
-  const char           *name,
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
-  struct stat st;
-  int rv = stat( name, &st );
-  if ( rv == 0 && S_ISCHR( st.st_mode ) ) {
-    device_info->device_name = name;
-    device_info->device_name_length = strlen( name );
-    device_info->major = rtems_filesystem_dev_major_t( st.st_rdev );
-    device_info->minor = rtems_filesystem_dev_minor_t( st.st_rdev );
-  } else {
-    sc = RTEMS_UNSATISFIED;
-  return sc;
diff --git a/testsuites/sptests/sp21/init.c b/testsuites/sptests/sp21/init.c
index f44f2ba851..bd0ae2b6a1 100644
--- a/testsuites/sptests/sp21/init.c
+++ b/testsuites/sptests/sp21/init.c
@@ -21,7 +21,6 @@ const char rtems_test_name[] = "SP 21";
 /* forward declarations to avoid warnings */
 rtems_task Init(rtems_task_argument argument);
 void do_test_io_manager(void);
-void do_test_io_lookup_name(void);
 void do_test_zero_driver(void);
 #define PRIurtems_device_major_number PRIu32
@@ -193,24 +192,6 @@ void do_test_io_manager(void)
   puts( "rtems_io_unregister_driver - RTEMS_SUCCESSFUL" );
-  rtems_status_code    sc;
-  rtems_driver_name_t  info;
-  puts( "rtems_io_lookup_name( \"\", &info ) - RTEMS_UNSATISFIED" );
-  sc = rtems_io_lookup_name( "", &info );
-  fatal_directive_status( sc, RTEMS_UNSATISFIED, "lookup empty string" );
-  puts( "rtems_io_lookup_name( \"/dev\", &info ) - RTEMS_UNSATISFIED" );
-  sc = rtems_io_lookup_name( "/dev", &info );
-  puts( "rtems_io_lookup_name( \"/dev/null\", &info ) - RTEMS_SUCCESSFUL" );
-  sc = rtems_io_lookup_name( "/dev/null", &info );
-  directive_failed( sc, "lookup /dev/null" );
@@ -258,8 +239,6 @@ rtems_task Init(
   do_test_io_manager();
-  do_test_io_lookup_name();
   do_test_zero_driver();
   TEST_END();
2.26.2
