[PATCH 11/16] rtems: Remove rtems_context_fp
Mon Jul 13 06:51:57 UTC 2020
This type was deprecated in RTEMS 5.1.
Close #3590.
 cpukit/include/rtems/rtems/types.h | 7 -------
 1 file changed, 7 deletions(-)
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index 870d443dfe..cf748a0a5f 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -89,13 +89,6 @@ typedef Objects_Id       rtems_id;
 #define RTEMS_ID_NONE OBJECTS_ID_NONE
-#if (CPU_HARDWARE_FP == TRUE) || (CPU_SOFTWARE_FP == TRUE)
- * @brief Public name for task floating point context area.
-typedef Context_Control_fp         rtems_context_fp RTEMS_DEPRECATED;
-#endif
 #if (CPU_ISR_PASSES_FRAME_POINTER == TRUE)
  * @brief Defines the format of the interrupt stack frame as it appears to a
2.26.2
