[PATCH] Strict thread-stack isolation
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Jul 13 16:33:29 UTC 2020
- This is the complete set of changes for strict isolation of thread stacks.
- There needs to be a confiuration operation,(#if defined(USE_THREAD_STACK_PROTECTION) for simple configuration can be used)
- The stack attributes are allocated through malloc, this needs to be done through score unlimited objects.
 bsps/arm/headers.am                           |   1 +
 .../include/bsp/arm-cp15-set-ttb-entries.h    |   7 +
 .../shared/cp15/arm-cp15-set-ttb-entries.c    |   3 +
 bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c   |  72 +++++++++
 bsps/shared/start/stackalloc.c                |  20 ++-
 c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am  |   5 +-
 cpukit/Makefile.am                            |   1 +
 cpukit/headers.am                             |   2 +
 cpukit/include/rtems/score/memorymanagement.h |  22 +++
 cpukit/include/rtems/score/stackmanagement.h  |  49 ++++++
 cpukit/score/cpu/arm/cpu.c                    |   3 +
 cpukit/score/cpu/arm/cpu_asm.S                |  22 ++-
 .../score/cpu/arm/include/rtems/score/cpu.h   |  20 +++
 cpukit/score/src/stackmanagement.c            | 143 ++++++++++++++++++
 14 files changed, 365 insertions(+), 5 deletions(-)
 create mode 100644 bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h
 create mode 100644 bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
 create mode 100644 cpukit/include/rtems/score/memorymanagement.h
 create mode 100644 cpukit/include/rtems/score/stackmanagement.h
 create mode 100644 cpukit/score/src/stackmanagement.c
diff --git a/bsps/arm/headers.am b/bsps/arm/headers.am
index 3d2b09effa..b1e86f3385 100644
--- a/bsps/arm/headers.am
+++ b/bsps/arm/headers.am
@@ -15,6 +15,7 @@ include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-a9mpcore-clock.h
 include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-a9mpcore-irq.h
 include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-a9mpcore-regs.h
 include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-a9mpcore-start.h
+include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h
 include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-cp15-start.h
 include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-errata.h
 include_bsp_HEADERS += ../../../../../bsps/arm/include/bsp/arm-gic-irq.h
diff --git a/bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h b/bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h
new file mode 100644
index 0000000000..39170927da
--- /dev/null
+++ b/bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h
@@ -0,0 +1,7 @@
+#include<bsp/arm-cp15-start.h>
+uint32_t arm_cp15_set_translation_table_entries(
+  const void *begin,
+  const void *end,
+  uint32_t section_flags
\ No newline at end of file
diff --git a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
index 507277dca1..f5d0494167 100644
--- a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
+++ b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
@@ -14,6 +14,7 @@
 #include <libcpu/arm-cp15.h>
+#include <bsp/arm-cp15-set-ttb-entries.h>
 #include <bspopts.h>
@@ -30,6 +31,8 @@
  * ARM DDI 0406C.b (ID072512)
+#define ARM_MMU_USE_SMALL_PAGES
 static uint32_t set_translation_table_entries(
   const void *begin,
   const void *end,
diff --git a/bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c b/bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
index 0000000000..978e35b86c
--- /dev/null
+++ b/bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
@@ -0,0 +1,72 @@
+#include <bsp/arm-cp15-start.h>
+#include <rtems/score/memorymanagement.h>
+#include <libcpu/arm-cp15.h>
+#include <rtems.h>
+#ifdef USE_THREAD_STACK_PROTECTION
+  #define ARM_MMU_USE_SMALL_PAGES
+#endif
+void memory_entries_set(uintptr_t begin, size_t size, memory_flags flags)
+    uintptr_t end;
+    rtems_interrupt_level irq_level;
+    uint32_t access_flags;
+    end = begin + size;
+    access_flags = memory_translate_flags(flags);
+    rtems_interrupt_local_disable(irq_level);
+    arm_cp15_set_translation_table_entries(begin, end, access_flags);
+    rtems_interrupt_local_enable(irq_level);
+void memory_entries_unset(uintptr_t begin, size_t size)
+  uintptr_t end;
+  access_flags = memory_translate_flags(NO_ACCESS);
+uint32_t memory_translate_flags(memory_flags attr_flags)
+  uint32_t flags;
+  switch (attr_flags)
+  case READ_WRITE:
+     flags = ARMV7_MMU_READ_WRITE;
+  break;
+  case READ_WRITE_CACHED:
+    flags = ARMV7_MMU_DATA_READ_WRITE_CACHED;
+  break;
+  case READ_ONLY:
+    flags = ARMV7_MMU_READ_ONLY;
+  break;
+  case READ_ONLY_CACHED:
+    flags = ARMV7_MMU_READ_ONLY_CACHED;
+  break;
+  case NO_ACCESS:
+    flags = 0;
+  break;
+  default:
+     return -1;
+  break;
+  return flags;
diff --git a/bsps/shared/start/stackalloc.c b/bsps/shared/start/stackalloc.c
index f7cf7be0f1..2ce0d6573b 100644
--- a/bsps/shared/start/stackalloc.c
+++ b/bsps/shared/start/stackalloc.c
@@ -25,6 +25,7 @@
 #include <rtems/score/heapimpl.h>
+#include <rtems/score/stackmanagement.h>
 #include <bsp/linker-symbols.h>
@@ -42,7 +43,8 @@ void bsp_stack_allocate_init(size_t stack_space_size)
 void *bsp_stack_allocate(size_t size)
-  void *stack = NULL;
+ void *stack = NULL;
+ uintptr_t page_table_base;
   if (bsp_stack_heap.area_begin != 0) {
     stack = _Heap_Allocate(&bsp_stack_heap, size);
@@ -51,11 +53,23 @@ void *bsp_stack_allocate(size_t size)
   if (stack == NULL) {
     stack = _Workspace_Allocate(size);
+  This is a hard coded address, assigned just for the
+  purpose of consistency
+  page_table_base = (uintptr_t)0x1000;
+  The current way to allocate protected stack is to assign memory attributes
+  to the allocated memory and remove memory-entry of every other stack
+  prot_stack_allocate( (uintptr_t)stack, size, page_table_base );
+#endif
   return stack;
-void bsp_stack_free(void *stack)
+void bsp_stack_free(void *stack)
   bool ok = _Heap_Free(&bsp_stack_heap, stack);
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index cfd59475c2..490f99792e 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -74,6 +74,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/i2c/cadence-i2c.
 # Cache
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-l2c-310.c
+#MMU
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
 # Start hooks
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstarthooks.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstartmmu.c
@@ -85,4 +88,4 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstartmm
 include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
 include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
-include $(srcdir)/../../../../../../bsps/arm/xilinx-zynq/headers.am
+include $(srcdir)/../../../../../../bsps/arm/xilinx-zynq/headers.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 51f38c84c7..f3b373376b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -929,6 +929,7 @@ librtemscpu_a_SOURCES += score/src/schedulercbsgetserverid.c
 librtemscpu_a_SOURCES += score/src/schedulercbssetparameters.c
 librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
 librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
+librtemscpu_a_SOURCES += score/src/stackmanagement.c
 librtemscpu_a_SOURCES += score/src/stackallocator.c
 librtemscpu_a_SOURCES += score/src/pheapallocate.c
 librtemscpu_a_SOURCES += score/src/pheapextend.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index fcf679f09d..9388aa0c8c 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -352,6 +352,7 @@ include_rtems_score_HEADERS += include/rtems/score/isr.h
 include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
 include_rtems_score_HEADERS += include/rtems/score/isrlock.h
 include_rtems_score_HEADERS += include/rtems/score/memory.h
+include_rtems_score_HEADERS += include/rtems/score/memorymanagement.h
 include_rtems_score_HEADERS += include/rtems/score/mpci.h
 include_rtems_score_HEADERS += include/rtems/score/mpciimpl.h
 include_rtems_score_HEADERS += include/rtems/score/mppkt.h
@@ -405,6 +406,7 @@ include_rtems_score_HEADERS += include/rtems/score/smplockstats.h
 include_rtems_score_HEADERS += include/rtems/score/smplockticket.h
 include_rtems_score_HEADERS += include/rtems/score/stack.h
 include_rtems_score_HEADERS += include/rtems/score/stackimpl.h
+include_rtems_score_HEADERS += include/rtems/score/stackmanagement.h
 include_rtems_score_HEADERS += include/rtems/score/states.h
 include_rtems_score_HEADERS += include/rtems/score/statesimpl.h
 include_rtems_score_HEADERS += include/rtems/score/status.h
diff --git a/cpukit/include/rtems/score/memorymanagement.h b/cpukit/include/rtems/score/memorymanagement.h
index 0000000000..c712e7301a
--- /dev/null
+++ b/cpukit/include/rtems/score/memorymanagement.h
@@ -0,0 +1,22 @@
+#ifndef _RTEMS_SCORE_MEMORYMANAGEMENT_H
+#define _RTEMS_SCORE_MEMORYMANAGEMENT_H
+#include <stdlib.h>
+#include <stdint.h>
+typedef enum
+    READ_WRITE,
+    READ_WRITE_CACHED,
+    READ_ONLY,
+    READ_ONLY_CACHED,
+    NO_ACCESS
+} memory_flags;
+void memory_entries_set(uintptr_t begin_addr, size_t size, memory_flags flags);
+void memory_entries_unset(uintptr_t begin_addr, size_t size);
+uint32_t memory_translate_flags(memory_flags flags);
+#endif
diff --git a/cpukit/include/rtems/score/stackmanagement.h b/cpukit/include/rtems/score/stackmanagement.h
index 0000000000..53b6a23af0
--- /dev/null
+++ b/cpukit/include/rtems/score/stackmanagement.h
@@ -0,0 +1,49 @@
+#ifndef _RTEMS_SCORE_STACKMANAGEMENT_H
+#define _RTEMS_SCORE_STACKMANAGEMENT_H
+#if defined (ASM)
+#include <rtems/asm.h>
+#else
+#include <stdbool.h>
+#include <rtems/score/chainimpl.h>
+typedef struct stack_attr
+  Chain_Node    node;
+  uintptr_t        stack_address;
+  size_t        size;
+  uint32_t      page_table_base;
+  memory_flags  access_flags;
+}stack_attr;
+typedef struct stack_attr_shared
+  stack_attr    Base;
+  Chain_Control shared_node_control;
+}stack_attr_shared;
+typedef struct stack_attr_prot
+  stack_attr_shared  *shared_stacks;
+  stack_attr    Base;
+  bool          current_stack;
+} stack_attr_prot;
+void prot_stack_allocate(uintptr_t stack_address, size_t size, uintptr_t page_table_base);
+void prot_stack_share(stack_attr_shared *shared, stack_attr_prot prot_stack);
+stack_attr_prot *prot_stack_context_initialize(void);
+void prot_stack_context_switch(stack_attr_prot *stack_attr);
+void prot_stack_context_restore(stack_attr_prot *stack_attr);
+#endif
+#endif
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 07b9588afd..aa3626965a 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -97,6 +97,9 @@ void _CPU_Context_Initialize(
   (void) new_level;
+  #if defined (USE_THREAD_STACK_PROTECTION)
+  the_context->stack_attr = prot_stack_context_initialize();
+  #endif
   the_context->register_sp = (uint32_t) stack_area_begin + stack_area_size;
   the_context->register_lr = (uint32_t) entry_point;
   the_context->isr_dispatch_disable = 0;
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 66f8ba6032..0133746b82 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -36,7 +36,6 @@
 #ifdef ARM_MULTILIB_ARCH_V4
         .text
  *  void _CPU_Context_switch( run_context, heir_context )
  *  void _CPU_Context_restore( run_context, heir_context )
@@ -65,6 +64,16 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
 #endif
 	str	r3, [r0, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
+    mov r8, r0
+	mov r9, r1
+	mov r10, r2
+	ldr r0, [r0, #112]
+	bl  prot_stack_context_switch
+	mov r0, r8
+	mov r1, r9
+	mov r2, r10
+#endif
 #ifdef RTEMS_SMP
@@ -133,6 +142,17 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
 DEFINE_FUNCTION_ARM(_CPU_Context_restore)
         mov     r1, r0
+#if defined( USE_THREAD_STACK_PROTECTION )
+	mov r8, r0
+	mov r9, r1
+	mov r10, r2
+	ldr		r0, [r0, #ARM_STACK_PROT_ATTR_OFFSET]
+	bl      prot_stack_context_restore
+	ldr     lr, [r2]
+	mov r0, r8
+	mov r1, r9
+	mov r2, r10
+#endif
 	GET_SELF_CPU_CONTROL	r2
         b       .L_restore
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index b7b48a3ac3..fb91142f35 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -34,6 +34,7 @@
 #include <rtems/score/paravirt.h>
 #endif
 #include <rtems/score/arm.h>
  * @addtogroup RTEMSScoreCPUARM
@@ -157,6 +158,21 @@
 #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
   #define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
+  #ifdef ARM_MULITLIB_VFP
+    #define ARM_STACK_PROT_ATTR_OFFSET   112
+  #else
+    #define ARM_STACK_PROT_ATTR_OFFSET  48
+  #endif
+#endif
+  #if defined ARM_MULITLIB_VFP
+    #define ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET   112
+  #elif ARM_MULTILIB_HAS_THREAD_ID_REGISTER
+    #define ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET 48
+  #else
+    #define ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET 44
+  #endif
 #endif
 #ifdef ARM_MULTILIB_VFP
@@ -185,6 +201,7 @@
 #define ARM_VFP_CONTEXT_SIZE 264
 #ifndef ASM
 #ifdef __cplusplus
@@ -235,6 +252,9 @@ typedef struct {
 #ifdef RTEMS_SMP
   volatile bool is_executing;
 #endif
+stack_attr_prot *stack_attr;
+#endif
 } Context_Control;
 static inline void _ARM_Data_memory_barrier( void )
diff --git a/cpukit/score/src/stackmanagement.c b/cpukit/score/src/stackmanagement.c
index 0000000000..ae66099b14
--- /dev/null
+++ b/cpukit/score/src/stackmanagement.c
@@ -0,0 +1,143 @@
+#include <rtems/score/basedefs.h>
+Chain_Control prot_node_control = CHAIN_INITIALIZER_EMPTY(prot_node_control);
+Chain_Control *shared_node_control;
+static void prot_stack_prev_entry_remove(void)
+ Chain_Node *node;
+ stack_attr_prot *stack_attr;
+  if( _Chain_Is_empty(&prot_node_control) == true ) {
+      _Chain_Initialize_empty(&prot_node_control);
+     node = _Chain_First( &prot_node_control );
+     while(_Chain_Is_tail(&prot_node_control, node) == false) {
+        stack_attr = RTEMS_CONTAINER_OF(node,stack_attr_prot, Base.node);
+        if( stack_attr->current_stack == false ) {
+            memory_entries_unset(stack_attr->Base.stack_address, stack_attr->Base.size);
+         //   shared_stack_entry_remove(stack_attr->shared_stacks);
+        node =  _Chain_Immutable_next( node );
+Iterate to the end of the chain and mark all the 'currnet' stack as false
+Append the current stack attribute to the end of the chain
+static void prot_stack_chain_append (Chain_Control *control, stack_attr_prot *stack_append_attr)
+    Chain_Node *node;
+    stack_attr_prot *present_stacks_attr;
+    if(_Chain_Is_empty(&prot_node_control) == true ) {
+    _Chain_Initialize_one(&prot_node_control, &stack_append_attr->Base.node);
+    } else {
+        node = _Chain_First(&prot_node_control);
+        while(_Chain_Is_tail(&prot_node_control,node) == false) {
+            present_stacks_attr = RTEMS_CONTAINER_OF(node, stack_attr_prot, Base.node);
+            present_stacks_attr->current_stack = false;
+        _Chain_Append_unprotected(&prot_node_control, &stack_append_attr->Base.node);
+/*This field will be refactored and score objects will be used for dynamic allocation*/
+    stack_attr = malloc(sizeof(stack_attr_prot));
+    if(stack_attr != NULL) {
+    stack_attr->Base.stack_address = stack_address;
+    stack_attr->Base.size = size;
+    stack_attr->Base.page_table_base = page_table_base;
+    stack_attr->Base.access_flags = READ_WRITE_CACHED;
+    stack_attr->current_stack = true;
+    Add the attribute field to the end of the chain, remove the memory entries of
+    previously allocated stack and set the memory entry of the currnet stack.
+    prot_stack_chain_append(&prot_node_control, stack_attr );
+    prot_stack_prev_entry_remove();
+    memory_entries_set(stack_address, size, READ_WRITE_CACHED);
+    Chain_Node *node;
+    if(   _Chain_Is_empty(&prot_node_control) == false ) {
+        while( _Chain_Is_tail(&prot_node_control, node ) == false) {
+            stack_attr = RTEMS_CONTAINER_OF( node, stack_attr_prot, Base.node);
+            if(stack_attr->current_stack == true) {
+                return stack_attr;
+            } else {
+    void *stack_address;
+    size_t  size;
+    Chain_Node *node;
+    Chain_Control *shared_node_control;
+      Remove the stacks shared with the current stack by iterating the chain
+    if( stack_attr != NULL) {
+    stack_address = stack_attr->Base.stack_address;
+    size = stack_attr->Base.size;
+        memory_entries_unset(stack_address, size);
+        stack_attr->current_stack = false;
+    shared_node_control = &stack_attr->shared_stacks->shared_node_control;
+    size_t  size;
+    Chain_Node *node;
+    memory_flags flags;
2.17.1
