[PATCH] user: Mention replacements for removed APIs
Sebastian Huber
Tue Jul 14 07:37:50 UTC 2020
user/migration/v5-to-v6.rst | 51 +++++++++++++++++++++++++++++++++++++
1 file changed, 51 insertions(+)
diff --git a/user/migration/v5-to-v6.rst b/user/migration/v5-to-v6.rst
index 5997057..d4691ff 100644
--- a/user/migration/v5-to-v6.rst
+++ b/user/migration/v5-to-v6.rst
@@ -18,3 +18,54 @@ default. Code bases which never used this option before may observe now
multiple definition linker errors. For example, if global variables are
declared and defined in header files (usually a missing ``extern`` in the header
file).
+Replacements for Removed APIs
+* The ``rtems_iterate_over_all_threads()`` directive was removed. Use
+ ``rtems_task_iterate()`` instead.
+* The ``rtems_get_current_processor()`` directive was removed. Use
+ ``rtems_scheduler_get_processor()`` instead.
+* The ``rtems_get_processor_count()`` directive was removed. Use
+ ``rtems_scheduler_get_processor_maximum()`` instead.
+* The ``boolean`` type was removed. Use ``bool`` instead.
+* The ``single_precision`` type was removed. Use ``float`` instead.
+* The ``double_precision`` type was removed. Use ``double`` instead.
+* The ``proc_ptr`` type was removed. Use a proper function pointer type.
+* The ``rtems_context`` type was removed. If you need this type in your
+ applications, please ask on the :r:list:`devel`.
+* The ``rtems_context_fp`` type was removed. If you need this type in your
+* The ``rtems_extension`` type was removed. Use ``void`` instead.
+* The ``rtems_io_lookup_name()`` directive was removed. Use ``stat()`` instead.
+* The ``region_information_block`` type was removed. Use
+ ``Heap_Information_block`` instead.
+* The ``rtems_thread_cpu_usage_t`` type was removed. Use ``struct timespec``
+ instead.
+* The ``rtems_rate_monotonic_period_time_t`` type was removed. Use ``struct
+ timespec`` instead.
+* The ``_Copyright_Notice`` constant was removed from the API. Use
+ ``rtems_get_copyright_notice()`` instead.
+* The ``_RTEMS_version`` constant was removed from the API. Use
+ ``rtems_get_version_string()`` instead.
+* The ``RTEMS_MAXIMUM_NAME_LENGTH`` define was removed. Use
+ ``sizeof( rtems_name )`` instead.
+* The ``<rtems/system.h>`` header file was removed. Include ``<rtems.h>``
+ instead.
2.26.2
