[PATCH RTEMS 5/7] libfreebsd: Port OFW to RTEMS
G S Niteesh Babu niteesh.gs at gmail.com
Wed Jul 15 06:31:55 UTC 2020
The following files have been ported to RTEMS
1) openfirm.h
2) openfirm.c
3) ofw_fdt.c
 cpukit/include/dev/ofw/openfirm.h            |  16 ++
 cpukit/libfreebsd/freebsd/dev/ofw/ofw_fdt.c  | 149 ++++++++++++++++++-
 cpukit/libfreebsd/freebsd/dev/ofw/openfirm.c |  58 +++++++-
 3 files changed, 221 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/dev/ofw/openfirm.h b/cpukit/include/dev/ofw/openfirm.h
index 74a7075367..b9a1394fe6 100644
--- a/cpukit/include/dev/ofw/openfirm.h
+++ b/cpukit/include/dev/ofw/openfirm.h
@@ -63,7 +63,9 @@
 #define _DEV_OPENFIRM_H_
 #include <sys/types.h>
+#ifndef __rtems__
 #include <machine/_bus.h>
+#endif /* __rtems__ */
  * Prototypes for Open Firmware Interface Routines
@@ -73,7 +75,14 @@ typedef uint32_t	ihandle_t;
 typedef uint32_t	phandle_t;
 typedef uint32_t	pcell_t;
+#ifdef __rtems__
+#define _KERNEL		1
+typedef struct device	*device_t;
+typedef uint32_t	cell_t;
 #ifdef _KERNEL
+#ifndef __rtems__
 #include <sys/malloc.h>
 #include <machine/ofw_machdep.h>
@@ -86,8 +95,10 @@ MALLOC_DECLARE(M_OFWPROP);
 boolean_t	OF_install(char *name, int prio);
+#endif /* __rtems__*/
 int		OF_init(void *cookie);
+#ifndef __rtems__
  * Known Open Firmware interface names
@@ -100,6 +111,7 @@ int		OF_init(void *cookie);
 /* Generic functions */
 int		OF_test(const char *name);
 void		OF_printf(const char *fmt, ...);
 /* Device tree functions */
 phandle_t	OF_peer(phandle_t node);
@@ -152,15 +164,18 @@ device_t	OF_device_from_xref(phandle_t xref);
 phandle_t	OF_xref_from_device(device_t dev);
 int		OF_device_register_xref(phandle_t xref, device_t dev);
+#ifndef __rtems__
 /* Device I/O functions */
 ihandle_t	OF_open(const char *path);
 void		OF_close(ihandle_t instance);
 ssize_t		OF_read(ihandle_t instance, void *buf, size_t len);
 ssize_t		OF_write(ihandle_t instance, const void *buf, size_t len);
 int		OF_seek(ihandle_t instance, uint64_t where);
 phandle_t	OF_instance_to_package(ihandle_t instance);
 ssize_t		OF_instance_to_path(ihandle_t instance, char *buf, size_t len);
+#ifndef __rtems__
 int		OF_call_method(const char *method, ihandle_t instance,
 		    int nargs, int nreturns, ...);
@@ -183,5 +198,6 @@ int		OF_interpret(const char *cmd, int nreturns, ...);
 int		OF_decode_addr(phandle_t dev, int regno, bus_space_tag_t *ptag,
 		    bus_space_handle_t *phandle, bus_size_t *sz);
 #endif /* _KERNEL */
 #endif /* _DEV_OPENFIRM_H_ */
\ No newline at end of file
diff --git a/cpukit/libfreebsd/freebsd/dev/ofw/ofw_fdt.c b/cpukit/libfreebsd/freebsd/dev/ofw/ofw_fdt.c
index e4f72e8142..30d0d111c6 100644
--- a/cpukit/libfreebsd/freebsd/dev/ofw/ofw_fdt.c
+++ b/cpukit/libfreebsd/freebsd/dev/ofw/ofw_fdt.c
@@ -30,9 +30,12 @@
 #include <sys/cdefs.h>
+#ifndef __rtems__
 __FBSDID("$FreeBSD$");
 #include <sys/param.h>
+#ifndef __rtems__
 #include <sys/kernel.h>
 #include <sys/systm.h>
@@ -43,11 +46,24 @@ __FBSDID("$FreeBSD$");
 #include <dev/fdt/fdt_common.h>
 #include <dev/ofw/ofwvar.h>
 #include <dev/ofw/openfirm.h>
+#ifndef __rtems__
 #include <dev/ofw/ofw_bus_subr.h>
 #include "ofw_if.h"
+#ifdef __rtems__
+#include <rtems.h>
+#include <rtems/sysinit.h>
+#include <rtems/fatal.h>
+#include <rtems/bspIo.h>
+#include <rtems/fdt.h>
+#include <libfdt.h>
+#ifndef __rtems__
 #ifdef DEBUG
 #define debugf(fmt, args...) do { printf("%s(): ", __func__);	\
     printf(fmt,##args); } while (0)
@@ -63,6 +79,7 @@ __FBSDID("$FreeBSD$");
 #define FDT_MARVELL
 #endif
 #endif
 static int ofw_fdt_init(ofw_t, void *);
 static phandle_t ofw_fdt_peer(ofw_t, phandle_t);
@@ -78,6 +95,7 @@ static ssize_t ofw_fdt_canon(ofw_t, const char *, char *, size_t);
 static phandle_t ofw_fdt_finddevice(ofw_t, const char *);
 static ssize_t ofw_fdt_instance_to_path(ofw_t, ihandle_t, char *, size_t);
 static ssize_t ofw_fdt_package_to_path(ofw_t, phandle_t, char *, size_t);
+#ifndef __rtems__
 static int ofw_fdt_interpret(ofw_t, const char *, int, cell_t *);
 static ofw_method_t ofw_fdt_methods[] = {
@@ -104,9 +122,11 @@ static ofw_def_t ofw_fdt = {
 	0
 OFW_DEF(ofw_fdt);
 static void *fdtp = NULL;
+#ifndef __rtems__
 static int
 sysctl_handle_dtb(SYSCTL_HANDLER_ARGS)
@@ -127,6 +147,28 @@ sysctl_register_fdt_oid(void *arg)
 	    sysctl_handle_dtb, "", "Device Tree Blob");
 SYSINIT(dtb_oid, SI_SUB_KMEM, SI_ORDER_ANY, sysctl_register_fdt_oid, NULL);
+#else /* __rtems__ */
+static void
+ofw_init(void)
+	int rv;
+	const void *fdt;
+	fdt = bsp_fdt_get();
+	rv = ofw_fdt_init(NULL, (void *)fdt);
+	/* Fatal if invalid FDT is provided */
+	if (rv != 0) {
+		printk("Invalid FDT provided");
+		rtems_fatal_error_occurred(RTEMS_NOT_CONFIGURED);
+RTEMS_SYSINIT_ITEM(
+	ofw_init,
+	RTEMS_SYSINIT_BSP_START,
+	RTEMS_SYSINIT_ORDER_FIRST
 static int
 ofw_fdt_init(ofw_t ofw, void *data)
@@ -297,7 +339,11 @@ ofw_fdt_getprop(ofw_t ofw, phandle_t package, const char *propname, void *buf,
 	if (prop == NULL)
 		return (-1);
+#ifndef __rtems__
 	bcopy(prop, buf, min(len, buflen));
+	memcpy(buf, prop, MIN(len, buflen));
 	return (len);
@@ -407,6 +453,7 @@ ofw_fdt_package_to_path(ofw_t ofw, phandle_t package, char *buf, size_t len)
 	return (-1);
+#ifndef __rtems__
 #if defined(FDT_MARVELL)
 static int
 ofw_fdt_fixup(ofw_t ofw)
@@ -476,4 +523,104 @@ ofw_fdt_interpret(ofw_t ofw, const char *cmd, int nret, cell_t *retvals)
 #else
 	return (0);
 #endif
+#ifdef __rtems__
+int
+OFW_INIT(ofw_t ofw_obj, void *cookie)
+	return (ofw_fdt_init(ofw_obj, cookie));
+phandle_t
+OFW_PEER(ofw_t ofw_obj, phandle_t node)
+	return (ofw_fdt_peer(ofw_obj, node));
+phandle_t
+OFW_CHILD(ofw_t ofw_obj, phandle_t node)
+	return (ofw_fdt_child(ofw_obj, node));
+phandle_t
+OFW_PARENT(ofw_t ofw_obj, phandle_t node)
+	return (ofw_fdt_parent(ofw_obj, node));
+phandle_t
+OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance)
+	return (ofw_fdt_instance_to_package(ofw_obj, instance));
+ssize_t
+OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char *propname)
+	return (ofw_fdt_getproplen(ofw_obj, package, propname));
+ssize_t
+OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
+    void *buf, size_t buflen
+	return (ofw_fdt_getprop(ofw_obj, package, propname, buf, buflen));
+int
+OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev, char *buf,
+    size_t size)
+	return (ofw_fdt_nextprop(ofw_obj, package, prev, buf, size));
+int
+OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
+    const void *buf, size_t len)
+	return (ofw_fdt_setprop(ofw_obj, package, propname, buf, len));
+ssize_t
+OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t len)
+	return (ofw_fdt_canon(ofw_obj, device, buf, len));
+phandle_t
+OFW_FINDDEVICE(ofw_t ofw_obj, const char *device)
+	return (ofw_fdt_finddevice(ofw_obj, device));
+ssize_t
+OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char *buf,
+    size_t len)
+	return (ofw_fdt_instance_to_path(ofw_obj, instance, buf, len));
+ssize_t
+OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
+    size_t len)
+	return (ofw_fdt_package_to_path(ofw_obj, package, buf, len));
diff --git a/cpukit/libfreebsd/freebsd/dev/ofw/openfirm.c b/cpukit/libfreebsd/freebsd/dev/ofw/openfirm.c
index 50ebf2cf16..730d76e9ed 100644
--- a/cpukit/libfreebsd/freebsd/dev/ofw/openfirm.c
+++ b/cpukit/libfreebsd/freebsd/dev/ofw/openfirm.c
@@ -58,26 +58,37 @@
+#ifndef __rtems__
 #include "opt_platform.h"
+#ifndef __rtems__
 #include <sys/lock.h>
 #include <sys/mutex.h>
 #include <sys/queue.h>
 #include <sys/endian.h>
+#ifndef __rtems__
 #include <machine/stdarg.h>
 #include "ofw_if.h"
+#ifdef __rtems__
+#include <dev/ofw/openfirm.h>
+#include <rtems-freebsd-helper.h>
+#ifndef __rtems__
 static void OF_putchar(int c, void *arg);
 MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
@@ -85,7 +96,9 @@ MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
 static ihandle_t stdout;
 static ofw_def_t	*ofw_def_impl = NULL;
 static ofw_t		ofw_obj;
+#ifndef __rtems__
 static struct ofw_kobj	ofw_kernel_obj;
 static struct kobj_ops	ofw_kernel_kops;
@@ -224,14 +237,18 @@ OF_install(char *name, int prio)
 	return (FALSE);
 /* Initializer */
 int
+#ifndef __rtems__
 	phandle_t chosen;
 	int rv;
+#ifndef __rtems__
 	if (ofw_def_impl == NULL)
 		return (-1);
@@ -242,17 +259,21 @@ OF_init(void *cookie)
 	kobj_class_compile_static(ofw_def_impl, &ofw_kernel_kops);
 	kobj_init_static((kobj_t)ofw_obj, ofw_def_impl);
 	rv = OFW_INIT(ofw_obj, cookie);
+#ifndef __rtems__
 	if ((chosen = OF_finddevice("/chosen")) != -1)
 		if (OF_getencprop(chosen, "stdout", &stdout,
 		    sizeof(stdout)) == -1)
 			stdout = -1;
 	return (rv);
+#ifndef __rtems__
 static void
 OF_putchar(int c, void *arg __unused)
@@ -314,6 +335,7 @@ OF_interpret(const char *cmd, int nreturns, ...)
 	return (status);
@@ -324,8 +346,10 @@ phandle_t
+#ifndef __rtems__
 		return (0);
 	return (OFW_PEER(ofw_obj, node));
@@ -335,8 +359,10 @@ phandle_t
 OF_child(phandle_t node)
+#ifndef __rtems__
 		return (0);
 	return (OFW_CHILD(ofw_obj, node));
@@ -346,8 +372,10 @@ phandle_t
 OF_parent(phandle_t node)
+#ifndef __rtems__
 		return (0);
 	return (OFW_PARENT(ofw_obj, node));
@@ -357,8 +385,10 @@ phandle_t
+#ifndef __rtems__
 		return (-1);
 	return (OFW_INSTANCE_TO_PACKAGE(ofw_obj, instance));
@@ -368,8 +398,10 @@ ssize_t
 OF_getproplen(phandle_t package, const char *propname)
+#ifndef __rtems__
 		return (-1);
 	return (OFW_GETPROPLEN(ofw_obj, package, propname));
@@ -387,8 +419,10 @@ ssize_t
 OF_getprop(phandle_t package, const char *propname, void *buf, size_t buflen)
+#ifndef __rtems__
 		return (-1);
 	return (OFW_GETPROP(ofw_obj, package, propname, buf, buflen));
@@ -532,8 +566,10 @@ int
 OF_nextprop(phandle_t package, const char *previous, char *buf, size_t size)
+#ifndef __rtems__
 		return (-1);
 	return (OFW_NEXTPROP(ofw_obj, package, previous, buf, size));
@@ -543,8 +579,10 @@ int
 OF_setprop(phandle_t package, const char *propname, const void *buf, size_t len)
+#ifndef __rtems__
 		return (-1);
 	return (OFW_SETPROP(ofw_obj, package, propname, buf,len));
@@ -554,8 +592,10 @@ ssize_t
 OF_canon(const char *device, char *buf, size_t len)
+#ifndef __rtems__
 		return (-1);
 	return (OFW_CANON(ofw_obj, device, buf, len));
@@ -565,8 +605,10 @@ phandle_t
 OF_finddevice(const char *device)
+#ifndef __rtems__
 		return (-1);
 	return (OFW_FINDDEVICE(ofw_obj, device));
@@ -576,8 +618,10 @@ ssize_t
+#ifndef __rtems__
 		return (-1);
 	return (OFW_INSTANCE_TO_PATH(ofw_obj, instance, buf, len));
@@ -587,8 +631,10 @@ ssize_t
 OF_package_to_path(phandle_t package, char *buf, size_t len)
+#ifndef __rtems__
 		return (-1);
 	return (OFW_PACKAGE_TO_PATH(ofw_obj, package, buf, len));
@@ -626,14 +672,18 @@ OF_child_xref_phandle(phandle_t parent, phandle_t xref)
 phandle_t
 OF_node_from_xref(phandle_t xref)
+#ifndef __rtems__
 	struct xrefinfo *xi;
 	phandle_t node;
+#ifndef __rtems__
 	if (xref_init_done) {
 		if ((xi = xrefinfo_find(xref, FIND_BY_XREF)) == NULL)
 			return (xref);
 		return (xi->node);
 	if ((node = OF_child_xref_phandle(OF_peer(0), xref)) == -1)
 		return (xref);
@@ -643,14 +693,18 @@ OF_node_from_xref(phandle_t xref)
 phandle_t
 OF_xref_from_node(phandle_t node)
+#ifndef __rtems__
 	phandle_t xref;
+#ifndef __rtems__
 		if ((xi = xrefinfo_find(node, FIND_BY_NODE)) == NULL)
 			return (node);
 		return (xi->xref);
 	if (OF_getencprop(node, "phandle", &xref, sizeof(xref)) == -1 &&
 	    OF_getencprop(node, "ibm,phandle", &xref, sizeof(xref)) == -1 &&
@@ -659,6 +713,7 @@ OF_xref_from_node(phandle_t node)
 	return (xref);
+#ifndef __rtems__
 device_t
@@ -845,4 +900,5 @@ OF_exit()
 	for (;;)			/* just in case */
2.17.1
