Need help in understanding some of the existing code in RTEMS
Richi Dubey
richidubey at gmail.com
Wed Jul 15 12:55:17 UTC 2020
Another quick question:
typedef struct {
#if defined(RTEMS_SMP)
Chain_Control Scheduler_nodes;
#endif
* @brief The scheduler nodes of this thread.
* Each thread has a scheduler node for each scheduler instance.
Scheduler_Node *nodes;
} Thread_Scheduler_control;
Why do we have a Scheduler_Node *nodes? What does it indicate? Since the
pointer can point to a single value, why is it being called nodes?
On Wed, Jul 15, 2020 at 5:57 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> I had a small question. The scheduler struct inside percpu.h looks like:
> struct {
> * @brief The scheduler control of the scheduler owning this
> processor.
> * This pointer is NULL in case this processor is currently not used
> by a
> * scheduler instance.
> const struct _Scheduler_Control *control;
> * @brief The scheduler context of the scheduler owning this
> processor.
> by a
> const struct Scheduler_Context *context;
> * @brief The idle thread for this processor in case it is online and
> * currently not used by a scheduler instance.
> struct _Thread_Control *idle_if_online_and_unused;
> } Scheduler;
> So, does this mean a CPU when active is always either executing an idle
> thread and is not being used by a scheduler (so has a thread attribute in
> the idle_if_online_and_unused), or is used by a scheduler and is executing
> a task ( which can not be an idle task)? Another equivalent question is do
> we have an idle scheduler node, like we have idle predefined threads that
> run on a CPU?
> Please let me know,
> Thanks.
> On Tue, Jul 14, 2020 at 8:28 PM Richi Dubey <richidubey at gmail.com> wrote:
>> I understand. Thank you.
>> On Tue, Jul 14, 2020 at 7:05 PM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> On 14/07/2020 13:37, Richi Dubey wrote:
>>> > Here we remove the affine ready queue if it
>>> > exists from the chain of affine queues since now an affine thread
>>> is
>>> > scheduled on a processor.
>>> > Why are we removing the entire affine queue corresponding to a
>>> > CPU when a single node of the queue gets scheduled?
>>> Because the highest priority affine thread is now a schedule one.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200715/39b1a9c6/attachment.html>
