[PATCH v2] Strict thread-stack isolation
Utkarsh Rai
utkarsh.rai60 at gmail.com
Thu Jul 16 11:34:35 UTC 2020
- This is the complete set of changes for strict isolation of thread stacks.
- There needs to be a confiuration operation,(#if defined(USE_THREAD_STACK_PROTECTION) for simple configuration can be used)
- The stack attributes are allocated through malloc, this needs to be done through score unlimited objects.
Mechanism for thread-stack isolation
- Whenever a stack is allocated we assign READ_WRITE memory attributes to the memory region, the stack attribute structure is appended to a chain for tracking
- On each context switch, the executing stack is marked as 'not-current' and we unset its memory attributes. The heir stack is marked as 'current'
- On context restore we set the memory attributes of the heir stack and iterate thorugh the chain to check for any other 'current' stack and unset its memory
attribute (This requires some refinement, so that we don't have to iterate over the chain).
.../include/bsp/arm-cp15-set-ttb-entries.h | 0
bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c | 79 ++++++++
bsps/shared/start/stackalloc.c | 16 ++
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 5 +-
cpukit/Makefile.am | 1 +
cpukit/headers.am | 2 +
cpukit/include/rtems/score/memorymanagement.h | 89 +++++++++
cpukit/include/rtems/score/stackprotection.h | 149 ++++++++++++++
cpukit/score/cpu/arm/cpu.c | 4 +
cpukit/score/cpu/arm/cpu_asm.S | 43 +++-
.../score/cpu/arm/include/rtems/score/cpu.h | 18 ++
cpukit/score/src/stackprotection.c | 185 ++++++++++++++++++
12 files changed, 589 insertions(+), 2 deletions(-)
create mode 100644 bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h
create mode 100644 bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
create mode 100644 cpukit/include/rtems/score/memorymanagement.h
create mode 100644 cpukit/include/rtems/score/stackprotection.h
create mode 100644 cpukit/score/src/stackprotection.c
diff --git a/bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h b/bsps/arm/include/bsp/arm-cp15-set-ttb-entries.h
new file mode 100644
index 0000000000..e69de29bb2
diff --git a/bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c b/bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
index 0000000000..0c82f113a9
--- /dev/null
+++ b/bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
@@ -0,0 +1,79 @@
+#include <bsp/arm-cp15-start.h>
+#include <rtems/score/memorymanagement.h>
+#include <libcpu/arm-cp15.h>
+#include <rtems.h>
+#ifdef USE_THREAD_STACK_PROTECTION
+ #define ARM_MMU_USE_SMALL_PAGES
+#endif
+void Memorymanagement_Set_entries(uintptr_t begin, size_t size, Memorymanagement_flags flags)
+ uintptr_t end;
+ rtems_interrupt_level irq_level;
+ uint32_t access_flags;
+ end = begin + size;
+ access_flags = Memorymanagement_Translate_flags(flags);
+ * The ARM reference manual instructs to disable all the interrupts before
+ * setting up page table entries.
+ rtems_interrupt_disable(irq_level);
+ arm_cp15_set_translation_table_entries(begin, end, access_flags);
+ rtems_interrupt_enable(irq_level);
+void Memorymanagement_Unset_entries(uintptr_t begin, size_t size)
+ uintptr_t end;
+ access_flags = Memorymanagement_Translate_flags(NO_ACCESS);
+uint32_t Memorymanagement_Translate_flags(Memorymanagement_flags attr_flags)
+ uint32_t flags;
+ switch (attr_flags)
+ case READ_WRITE:
+ flags = ARMV7_MMU_READ_WRITE;
+ break;
+ case READ_WRITE_CACHED:
+ flags = ARMV7_MMU_DATA_READ_WRITE_CACHED;
+ break;
+ case READ_ONLY:
+ flags = ARMV7_MMU_READ_ONLY;
+ break;
+ case READ_ONLY_CACHED:
+ flags = ARMV7_MMU_READ_ONLY_CACHED;
+ break;
+ case NO_ACCESS:
+ flags = 0;
+ break;
+ default:
+ return 0;
+ break;
+ return flags;
\ No newline at end of file
diff --git a/bsps/shared/start/stackalloc.c b/bsps/shared/start/stackalloc.c
index f7cf7be0f1..ea8028c8db 100644
--- a/bsps/shared/start/stackalloc.c
+++ b/bsps/shared/start/stackalloc.c
@@ -25,6 +25,7 @@
#include <rtems/score/heapimpl.h>
+#include <rtems/score/stackprotection.h>
#include <bsp/linker-symbols.h>
@@ -43,6 +44,7 @@ void bsp_stack_allocate_init(size_t stack_space_size)
void *bsp_stack_allocate(size_t size)
void *stack = NULL;
+ uintptr_t page_table_base;
if (bsp_stack_heap.area_begin != 0) {
stack = _Heap_Allocate(&bsp_stack_heap, size);
@@ -52,6 +54,20 @@ void *bsp_stack_allocate(size_t size)
stack = _Workspace_Allocate(size);
+ * Although we are not performing page table switching, still we assign a value
+ * to avoid compiler warniing.
+ page_table_base = (uintptr_t)0x1000;
+ * The current way to get protected stack is to assign memory attributes
+ * to the allocated memory.
+ _Stackprotection_Allocate_attr( (uintptr_t)stack, size, page_table_base );
+#endif
return stack;
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index cfd59475c2..490f99792e 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -74,6 +74,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/i2c/cadence-i2c.
# Cache
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-l2c-310.c
+#MMU
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/mmu/bsp-set-mmu-attr.c
# Start hooks
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstarthooks.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstartmmu.c
@@ -85,4 +88,4 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstartmm
include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
-include $(srcdir)/../../../../../../bsps/arm/xilinx-zynq/headers.am
+include $(srcdir)/../../../../../../bsps/arm/xilinx-zynq/headers.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 51f38c84c7..83f9bfb3ef 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -929,6 +929,7 @@ librtemscpu_a_SOURCES += score/src/schedulercbsgetserverid.c
librtemscpu_a_SOURCES += score/src/schedulercbssetparameters.c
librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
+librtemscpu_a_SOURCES += score/src/stackprotection.c
librtemscpu_a_SOURCES += score/src/stackallocator.c
librtemscpu_a_SOURCES += score/src/pheapallocate.c
librtemscpu_a_SOURCES += score/src/pheapextend.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index fcf679f09d..2f16c71d9c 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -352,6 +352,7 @@ include_rtems_score_HEADERS += include/rtems/score/isr.h
include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
include_rtems_score_HEADERS += include/rtems/score/isrlock.h
include_rtems_score_HEADERS += include/rtems/score/memory.h
+include_rtems_score_HEADERS += include/rtems/score/memorymanagement.h
include_rtems_score_HEADERS += include/rtems/score/mpci.h
include_rtems_score_HEADERS += include/rtems/score/mpciimpl.h
include_rtems_score_HEADERS += include/rtems/score/mppkt.h
@@ -405,6 +406,7 @@ include_rtems_score_HEADERS += include/rtems/score/smplockstats.h
include_rtems_score_HEADERS += include/rtems/score/smplockticket.h
include_rtems_score_HEADERS += include/rtems/score/stack.h
include_rtems_score_HEADERS += include/rtems/score/stackimpl.h
+include_rtems_score_HEADERS += include/rtems/score/stackprotection.h
include_rtems_score_HEADERS += include/rtems/score/states.h
include_rtems_score_HEADERS += include/rtems/score/statesimpl.h
include_rtems_score_HEADERS += include/rtems/score/status.h
diff --git a/cpukit/include/rtems/score/memorymanagement.h b/cpukit/include/rtems/score/memorymanagement.h
index 0000000000..2a5490c680
--- /dev/null
+++ b/cpukit/include/rtems/score/memorymanagement.h
@@ -0,0 +1,89 @@
+ * @file
+ * @ingroup RTEMSScoreMemorymanagement
+ * @brief This file provodes APIs for high-level memory management
+ * Copyright (C) 2020 Utkarsh Rai
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_SCORE_MEMORYMANAGEMENT_H
+#define _RTEMS_SCORE_MEMORYMANAGEMENT_H
+#include <rtems/score/basedefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/** This defines the various high-level memory access flags.*/
+typedef enum
+ READ_WRITE,
+ READ_WRITE_CACHED,
+ READ_ONLY,
+ READ_ONLY_CACHED,
+ NO_ACCESS
+} Memorymanagement_flags;
+ * @brief Define the memory access permission for the specified memory region
+ * @param begin_addr Begining of the memory region
+ * @param size Size of the memory region
+ * @param flag Memory access flag
+void Memorymanagement_Set_entries(uintptr_t begin_addr, size_t size, Memorymanagement_flags flag);
+ * @brief Unset the memory access permission for the specified memory region
+ * This operation implcitly sets the specified memory region with 'NO_ACCESS'
+ * flag.
+void Memorymanagement_Unset_entries(uintptr_t begin_addr, size_t size);
+ * @brief Translate the high-level flags to BSP-specifc MMU flags.
+ * @param attr_flags High-level memory access flags.
+ * @retval flag BSP-specifc MMU flag
+uint32_t Memorymanagement_Translate_flags(Memorymanagement_flags attr_flags);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/include/rtems/score/stackprotection.h b/cpukit/include/rtems/score/stackprotection.h
index 0000000000..91e3f6daba
--- /dev/null
+++ b/cpukit/include/rtems/score/stackprotection.h
@@ -0,0 +1,149 @@
+ * @file
+ * @ingroup RTEMSScoreStackprotection
+ * @brief Stackprotection API
+ * This include file provides the API for the management of protected thread-
+ * stacks
+ * COPYRIGHT (c) 2020 Utkarsh Rai.
+ * are met:
+#ifndef _RTEMS_SCORE_STACKPROTECTION_H
+#define _RTEMS_SCORE_STACKPROTECTION_H
+#if defined ( ASM )
+#include <rtems/asm.h>
+#else
+ #include <rtems/score/basedefs.h>
+ #include <rtems/score/memorymanagement.h>
+ #include <rtems/score/chainimpl.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+#if !defined ( ASM )
+ * The following defines the attributes of a protected stack
+typedef struct
+ /** This is the node to the chain for tracking each allocated/shared stack */
+ Chain_Node node;
+ /** This is the stack address */
+ uintptr_t stack_address;
+ /** This is the stack size */
+ size_t size;
+ /** This is the pointer to the page table base */
+ /**Memory flag for the alllocated/shared stack */
+ Memorymanagement_flags access_flags;
+} Stackprotection_Attr;
+ * The following defines the control block of a shared stack
+typedef struct
+ /** This is the attribute of a shared stack*/
+ Stackprotection_Attr Base;
+} Stackprotection_Shared_stack;
+ * The following defines the control block of an allocated stack
+typedef struct
+ /** This is the attribute of an allocated stack*/
+ /** This is the pointer to the attributes of a stack shared with the stack
+ * in question
+ Stackprotection_Shared_stack *shared_stacks;
+ /**This marks if the stack in question belongs to an executing thread*/
+ bool current_stack;
+} Stackprotection_The_stack;
+ * @brief Allocate the attributes of the stack in question.
+ * @param freechain The stack address.
+ * @param size Size of the stack.
+ * @param page_table_base Pointer to the start of a page table
+void _Stackprotection_Allocate_attr(uintptr_t stack_address, size_t size, uintptr_t page_table_base);
+ * @brief Share a stack with another stack.
+ * @param shared_stack The stack to be shared
+ * @param target_stack The stack with which to share
+void _Stackprotection_Share_stack(Stackprotection_The_stack *shared_stack, Stackprotection_The_stack* target_stack);
+ * @brief Initialize the context of a thread with the control block of a
+ * protected stack
+ * @retval the_stack The protected stack
+Stackprotection_The_stack *_Stackprotection_Context_initialize(void);
+ * @brief Swap out the executing protected stack from the page table during
+ * context switch
+ * The current method of switching the protected stack is to mark the switched
+ * out stack as 'NO ACCESS'
+ * @param excuting_stack Control block of the executing stack
+void _Stackprotection_Context_switch(Stackprotection_The_stack *executing_stack, Stackprotection_The_stack *heir_stack);
+ * @brief Swap the restored protected stack in the page table during context
+ * restoration
+ * We set the entries of the restored stack and mark all the remainig stacks as
+ * 'NO-ACCESS'.
+ * @param Control block of the restored stack
+void _Stackprotection_Context_restore(Stackprotection_The_stack *restored_stack);
+#endif /* !defined ( ASM ) */
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 07b9588afd..cbb62d45e5 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -28,6 +28,7 @@
#include <rtems/score/cpu.h>
#include <rtems/score/tls.h>
@@ -97,6 +98,9 @@ void _CPU_Context_Initialize(
(void) new_level;
+ #if defined (USE_THREAD_STACK_PROTECTION)
+ the_context->the_stack = _Stackprotection_Context_initialize();
+ #endif
the_context->register_sp = (uint32_t) stack_area_begin + stack_area_size;
the_context->register_lr = (uint32_t) entry_point;
the_context->isr_dispatch_disable = 0;
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 66f8ba6032..d4d98af5b2 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -66,6 +66,27 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
str r3, [r0, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
+#if defined ( USE_THREAD_STACK_PROTECTION )
+ * Save the registers modifed during function call
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+ * Load the parameters to be passed
+ ldr r0, [r0, #ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET]
+ ldr r1, [r1, #ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET]
+ bl _Stackprotection_Context_switch
+ * Restore the saved registers
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+#endif
#ifdef RTEMS_SMP
* The executing thread no longer executes on this processor. Switch
@@ -132,7 +153,27 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
DEFINE_FUNCTION_ARM(_CPU_Context_restore)
- mov r1, r0
+ mov r1, r0
+#if defined( USE_THREAD_STACK_PROTECTION )
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+#endif
GET_SELF_CPU_CONTROL r2
b .L_restore
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index b7b48a3ac3..df13fed258 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -34,6 +34,7 @@
#include <rtems/score/paravirt.h>
#endif
#include <rtems/score/arm.h>
* @addtogroup RTEMSScoreCPUARM
@@ -157,6 +158,21 @@
#ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
#define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
+ #ifdef ARM_MULITLIB_VFP
+ #define ARM_STACK_PROT_ATTR_OFFSET 112
+ #else
+ #define ARM_STACK_PROT_ATTR_OFFSET 48
+ #endif
+#endif
+ #if defined ARM_MULITLIB_VFP
+ #define ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET 112
+ #elif ARM_MULTILIB_HAS_THREAD_ID_REGISTER
+ #define ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET 48
+ #else
+ #define ARM_CONTEXT_CONTROL_STACK_ATTR_OFFSET 44
+ #endif
#endif
#ifdef ARM_MULTILIB_VFP
@@ -185,6 +201,7 @@
#define ARM_VFP_CONTEXT_SIZE 264
#ifndef ASM
#ifdef __cplusplus
@@ -235,6 +252,7 @@ typedef struct {
#ifdef RTEMS_SMP
volatile bool is_executing;
#endif
+Stackprotection_The_stack *the_stack;
} Context_Control;
static inline void _ARM_Data_memory_barrier( void )
diff --git a/cpukit/score/src/stackprotection.c b/cpukit/score/src/stackprotection.c
index 0000000000..7f7c3fd6e5
--- /dev/null
+++ b/cpukit/score/src/stackprotection.c
@@ -0,0 +1,185 @@
+ * @file
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+Chain_Control _Stackprotection_node_control = CHAIN_INITIALIZER_EMPTY(_Stackprotection_node_control);
+static void _Stackprotection_Remove_prev_entry(void)
+ Chain_Node *node;
+ Stackprotection_The_stack *prot_stack;
+ if( _Chain_Is_empty(&_Stackprotection_node_control) == true ) {
+ _Chain_Initialize_empty(&_Stackprotection_node_control);
+ node = _Chain_First( &_Stackprotection_node_control );
+ while(_Chain_Is_tail(&_Stackprotection_node_control, node) == false) {
+ prot_stack = RTEMS_CONTAINER_OF(node,Stackprotection_The_stack, Base.node);
+ if( prot_stack->current_stack == false ) {
+ Memorymanagement_Unset_entries(prot_stack->Base.stack_address, prot_stack->Base.size);
+ node = _Chain_Immutable_next( node );
+Iterate to the end of the chain and mark all the 'currnet' stack as false
+Append the current stack attribute to the end of the chain
+static void _Stackprotection_Append_chain (Chain_Control *control, Stackprotection_The_stack *stack_append_attr)
+ Chain_Node *node;
+ Stackprotection_The_stack *present_stacks_attr;
+ if(_Chain_Is_empty(&_Stackprotection_node_control) == true ) {
+ _Chain_Initialize_one(&_Stackprotection_node_control, &stack_append_attr->Base.node);
+ } else {
+ _Chain_Append_unprotected(&_Stackprotection_node_control, &stack_append_attr->Base.node);
+/*This field will be refactored and score objects will be used for dynamic allocation*/
+ prot_stack = malloc(sizeof(Stackprotection_The_stack));
+ if(prot_stack != NULL) {
+ prot_stack->Base.stack_address = stack_address;
+ prot_stack->Base.size = size;
+ prot_stack->Base.page_table_base = page_table_base;
+ prot_stack->Base.access_flags = READ_WRITE_CACHED;
+ prot_stack->current_stack = true;
+ Add the attribute field to the end of the chain, remove the memory entries of
+ previously allocated stack and set the memory entry of the currnet stack.
+ _Stackprotection_Append_chain(&_Stackprotection_node_control, prot_stack );
+ Memorymanagement_Set_entries(stack_address, size, READ_WRITE_CACHED);
+ Chain_Node *node;
+ if( _Chain_Is_empty(&_Stackprotection_node_control) == false ) {
+ while( _Chain_Is_tail(&_Stackprotection_node_control, node ) == false) {
+ prot_stack = RTEMS_CONTAINER_OF( node, Stackprotection_The_stack, Base.node);
+ if(prot_stack->current_stack == true) {
+ return prot_stack;
+ } else {
+ void *stack_address;
+ size_t size;
+ Chain_Node *node;
+ Chain_Control *shared_node_control;
+ Remove the stacks shared with the current stack by iterating the chain
+ if( executing_stack != NULL) {
+ stack_address = executing_stack->Base.stack_address;
+ size = executing_stack->Base.size;
+ if(executing_stack->current_stack == true) {
+ executing_stack->current_stack = false;
+ Memorymanagement_Unset_entries(stack_address, size);
+ _Stackprotection_Context_restore(heir_stack);
+void _Stackprotection_Context_restore(Stackprotection_The_stack *heir_stack)
+ size_t size;
+ Chain_Node *node;
+ Memorymanagement_flags flags;
+ if(heir_stack != NULL) {
+ heir_stack->current_stack = true;
+ stack_address = heir_stack->Base.stack_address;
+ size = heir_stack->Base.size;
+ flags = heir_stack->Base.access_flags;
+ Memorymanagement_Set_entries(stack_address, size, flags);
+ node = _Chain_First(&_Stackprotection_node_control);
+ /** Iterate through the chain and unset memory entries of all the
+ * previous thread-stacks
+ while(_Chain_Is_tail(&_Stackprotection_node_control,node) == false) {
+ present_stacks_attr = RTEMS_CONTAINER_OF(node, Stackprotection_The_stack, Base.node);
+ if(present_stacks_attr->current_stack == true && present_stacks_attr != heir_stack)
+ present_stacks_attr->current_stack = false;
+ Memorymanagement_Unset_entries(present_stacks_attr->Base.stack_address, present_stacks_attr->Base.size);
2.17.1
