[PATCH] removed SOFTFP fenv support from ARM
Sebastian Huber
Fri Jul 17 04:36:13 UTC 2020
I cannot apply this patch using the Newlib head:
Applying: removed SOFTFP fenv support from ARM
.git/rebase-apply/patch:826: trailing whitespace.
#else
.git/rebase-apply/patch:856: trailing whitespace.
.git/rebase-apply/patch:936: trailing whitespace.
error: patch failed: newlib/libm/machine/arm/fenv-vfp.c:1
error: newlib/libm/machine/arm/fenv-vfp.c: patch does not apply
error: patch failed: newlib/libm/machine/arm/fenv.c:43
error: newlib/libm/machine/arm/fenv.c: patch does not apply
Patch failed at 0001 removed SOFTFP fenv support from ARM
hint: Use 'git am --show-current-patch=diff' to see the failed patch
When you have resolved this problem, run "git am --continue".
If you prefer to skip this patch, run "git am --skip" instead.
To restore the original branch and stop patching, run "git am --abort".
