[PATCH rtems 3/3] bsps/fdt: Make sure data is cache aligned.
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Jul 17 05:54:45 UTC 2020
The cache of the fdt blob is flushed after copy. Therefore it should be
aligned.
bsps/shared/start/bsp-fdt.c | 7 ++++---
1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/bsps/shared/start/bsp-fdt.c b/bsps/shared/start/bsp-fdt.c
index 7e8d8922a8..f55273e4ca 100644
--- a/bsps/shared/start/bsp-fdt.c
+++ b/bsps/shared/start/bsp-fdt.c
@@ -28,10 +28,10 @@
#endif
#ifdef BSP_FDT_BLOB_READ_ONLY
-static const uint32_t
+static const uint32_t CPU_STRUCTURE_ALIGNMENT
bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)] = { 0xdeadbeef };
#else
-static uint32_t
+static uint32_t CPU_STRUCTURE_ALIGNMENT
bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)];
#endif
@@ -48,6 +48,7 @@ void bsp_fdt_copy(const void *src)
if (s != d) {
size_t m = MIN(sizeof(bsp_fdt_blob), fdt_totalsize(src));
+ size_t aligned_size = ((m-1) | (CPU_CACHE_LINE_BYTES-1)) + 1;
size_t n = (m + sizeof(*d) - 1) / sizeof(*d);
size_t i;
@@ -55,7 +56,7 @@ void bsp_fdt_copy(const void *src)
d[i] = s[i];
- rtems_cache_flush_multiple_data_lines(d, m);
+ rtems_cache_flush_multiple_data_lines(d, aligned_size);
2.26.2
