[PATCH rtems 1/3] bsp/imx: Add a GPIO driver.
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Jul 17 05:54:43 UTC 2020
bsps/arm/imx/gpio/imx-gpio.c | 359 +++++++++++++++++++++++++++
bsps/arm/imx/headers.am | 1 +
bsps/arm/imx/include/bsp/imx-gpio.h | 196 +++++++++++++++
bsps/arm/imx/include/bsp/irq.h | 1 +
bsps/arm/imx/start/bspstart.c | 2 +-
bsps/include/bsp/fatal.h | 1 +
c/src/lib/libbsp/arm/imx/Makefile.am | 3 +
7 files changed, 562 insertions(+), 1 deletion(-)
create mode 100644 bsps/arm/imx/gpio/imx-gpio.c
create mode 100644 bsps/arm/imx/include/bsp/imx-gpio.h
diff --git a/bsps/arm/imx/gpio/imx-gpio.c b/bsps/arm/imx/gpio/imx-gpio.c
new file mode 100644
index 0000000000..552e1d5cc2
--- /dev/null
+++ b/bsps/arm/imx/gpio/imx-gpio.c
@@ -0,0 +1,359 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019-2020 embedded brains GmbH.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <assert.h>
+#include <bsp/fatal.h>
+#include <bsp/fdt.h>
+#include <bsp/imx-gpio.h>
+#include <libfdt.h>
+#include <rtems.h>
+#include <rtems/sysinit.h>
+#define IMX_GPIO_ALIAS_NAME "gpioX"
+ * i.MX6ULL has 5, i.MX7D has 7
+ * Be careful when changing this. The attach() does a simple ASCII conversion.
+#define IMX_MAX_GPIO_MODULES 7
+struct imx_gpio_regs {
+ uint32_t dr;
+ uint32_t gdir;
+ uint32_t psr;
+ uint32_t icr1;
+#define IMX_GPIO_ICR_LOW_LEVEL 0
+#define IMX_GPIO_ICR_HIGH_LEVEL 1
+#define IMX_GPIO_ICR_RISING_EDGE 2
+#define IMX_GPIO_ICR_FALLING_EDGE 3
+ uint32_t icr2;
+ uint32_t imr;
+ uint32_t isr;
+ uint32_t edge_sel;
+struct imx_gpio {
+ char name[sizeof(IMX_GPIO_ALIAS_NAME)];
+ struct imx_gpio_regs *regs;
+ rtems_interrupt_lock lock;
+/* The GPIO modules. These will be initialized based on the FDT alias table. */
+struct imx_gpio imx_gpio[IMX_MAX_GPIO_MODULES];
+const char *imx_gpio_get_name(struct imx_gpio *imx_gpio)
+ return imx_gpio->name;
+static void imx_gpio_attach(void)
+ size_t i;
+ const void *fdt;
+ fdt = bsp_fdt_get();
+ memset(imx_gpio, 0, sizeof(imx_gpio));
+ for (i = 0; i < IMX_MAX_GPIO_MODULES; ++i) {
+ const char *path;
+ int node;
+ const uint32_t *val;
+ uint32_t gpio_regs = 0;
+ int len;
+ memcpy(imx_gpio[i].name, IMX_GPIO_ALIAS_NAME, sizeof(IMX_GPIO_ALIAS_NAME));
+ imx_gpio[i].name[sizeof(IMX_GPIO_ALIAS_NAME)-2] = (char)('0' + i);
+ path = fdt_get_alias(fdt, imx_gpio[i].name);
+ if (path == NULL) {
+ continue;
+ node = fdt_path_offset(fdt, path);
+ if (node < 0) {
+ bsp_fatal(IMX_FATAL_GPIO_UNEXPECTED_FDT);
+ val = fdt_getprop(fdt, node, "reg", &len);
+ if (len > 0) {
+ gpio_regs = fdt32_to_cpu(val[0]);
+ } else {
+ imx_gpio[i].regs = (struct imx_gpio_regs *)gpio_regs;
+ rtems_interrupt_lock_initialize(&imx_gpio[i].lock, imx_gpio[i].name);
+struct imx_gpio *imx_gpio_get_by_index(unsigned idx)
+ if ((idx < IMX_MAX_GPIO_MODULES) && (imx_gpio[idx].regs != NULL)) {
+ return &imx_gpio[idx];
+ return NULL;
+struct imx_gpio *imx_gpio_get_by_register(void *regs)
+ size_t i;
+ if (imx_gpio[i].regs == regs) {
+ return &imx_gpio[i];
+ return NULL;
+static void imx_gpio_direction_input(struct imx_gpio_pin *pin)
+ rtems_interrupt_lock_context lock_context;
+ rtems_interrupt_lock_acquire(&pin->gpio->lock, &lock_context);
+ pin->gpio->regs->gdir &= ~pin->mask;
+ rtems_interrupt_lock_release(&pin->gpio->lock, &lock_context);
+static void imx_gpio_direction_output(struct imx_gpio_pin *pin)
+ pin->gpio->regs->gdir |= pin->mask;
+static void imx_gpio_set_interrupt_any_edge(struct imx_gpio_pin *pin)
+ pin->gpio->regs->edge_sel |= pin->mask;
+static void imx_gpio_set_interrupt_mode(struct imx_gpio_pin *pin, uint32_t mode)
+ size_t i;
+ for (i=0; i < 32; ++i) {
+ if ((pin->mask & (1u << i)) != 0) {
+ volatile uint32_t *icr;
+ size_t shift;
+ if (i < 16) {
+ icr = &pin->gpio->regs->icr1;
+ shift = 2 * i;
+ } else {
+ icr = &pin->gpio->regs->icr2;
+ shift = 2 * (i - 16);
+ *icr = (*icr & ~(3u << shift)) | (mode << shift);
+rtems_status_code imx_gpio_init_from_fdt_property (
+ struct imx_gpio_pin *pin,
+ int node_offset,
+ const char *property,
+ enum imx_gpio_mode mode,
+ size_t index
+ int len;
+ rtems_status_code sc = RTEMS_SUCCESSFUL;
+ const void *fdt;
+ uint32_t gpio_regs;
+ const unsigned pin_length_dwords = 3;
+ const unsigned pin_length_bytes = (pin_length_dwords * sizeof(uint32_t));
+ uint32_t gpio_phandle;
+ uint32_t pin_nr;
+ int cfgnode;
+ memset(pin, 0, sizeof(*pin));
+ val = fdt_getprop(fdt, node_offset, property, &len);
+ if (val == NULL || (len % pin_length_bytes != 0) ||
+ (index >= len / pin_length_bytes)) {
+ sc = RTEMS_UNSATISFIED;
+ if (sc == RTEMS_SUCCESSFUL) {
+ pin_nr = fdt32_to_cpu(val[1 + index * pin_length_dwords]);
+ gpio_phandle = fdt32_to_cpu(val[0 + index * pin_length_dwords]);
+ cfgnode = fdt_node_offset_by_phandle(fdt, gpio_phandle);
+ val = fdt_getprop(fdt, cfgnode, "reg", &len);
+ if (len > 0) {
+ } else {
+ pin->gpio = imx_gpio_get_by_register((void *)gpio_regs);
+ pin->mask = 1u << pin_nr;
+ pin->shift = pin_nr;
+ pin->mode = mode;
+ imx_gpio_init(pin);
+ return sc;
+rtems_vector_number imx_gpio_get_irq_of_node(
+ const void *fdt,
+ int node,
+ size_t index
+ uint32_t pin;
+ int parent;
+ size_t parent_index;
+ int len;
+ val = fdt_getprop(fdt, node, "interrupts", &len);
+ if (val == NULL || len < (int) ((index + 1) * 8)) {
+ return UINT32_MAX;
+ pin = fdt32_to_cpu(val[index * 2]);
+ if (pin < 16) {
+ parent_index = 0;
+ } else {
+ parent_index = 1;
+ val = fdt_getprop(fdt, node, "interrupt-parent", &len);
+ if (len != 4) {
+ parent = fdt_node_offset_by_phandle(fdt, fdt32_to_cpu(val[0]));
+ return imx_get_irq_of_node(fdt, parent, parent_index);
+void imx_gpio_init (struct imx_gpio_pin *pin)
+ switch (pin->mode) {
+ case (IMX_GPIO_MODE_INTERRUPT_LOW):
+ imx_gpio_direction_input(pin);
+ imx_gpio_set_interrupt_mode(pin, IMX_GPIO_ICR_LOW_LEVEL);
+ break;
+ case (IMX_GPIO_MODE_INTERRUPT_HIGH):
+ imx_gpio_set_interrupt_mode(pin, IMX_GPIO_ICR_HIGH_LEVEL);
+ break;
+ case (IMX_GPIO_MODE_INTERRUPT_RISING):
+ imx_gpio_set_interrupt_mode(pin, IMX_GPIO_ICR_RISING_EDGE);
+ break;
+ case (IMX_GPIO_MODE_INTERRUPT_FALLING):
+ imx_gpio_set_interrupt_mode(pin, IMX_GPIO_ICR_FALLING_EDGE);
+ break;
+ case (IMX_GPIO_MODE_INTERRUPT_ANY_EDGE):
+ imx_gpio_set_interrupt_any_edge(pin);
+ /* Interrupt mode isn't really relevant here. Just set it to get
+ * a defined behaviour in case of a bug. */
+ break;
+ case (IMX_GPIO_MODE_INPUT):
+ break;
+ case (IMX_GPIO_MODE_OUTPUT):
+ imx_gpio_direction_output(pin);
+ break;
+ default:
+ assert(false);
+ break;
+void imx_gpio_set_output(struct imx_gpio_pin *pin, uint32_t set)
+ set <<= pin->shift;
+ set &= pin->mask;
+ pin->gpio->regs->dr = (pin->gpio->regs->dr & ~pin->mask) | set;
+void imx_gpio_toggle_output(struct imx_gpio_pin *pin)
+ pin->gpio->regs->dr = (pin->gpio->regs->dr ^ pin->mask);
+uint32_t imx_gpio_get_input(struct imx_gpio_pin *pin)
+ return (pin->gpio->regs->dr & pin->mask) >> pin->shift;
+void imx_gpio_int_disable(struct imx_gpio_pin *pin)
+ pin->gpio->regs->imr &= ~pin->mask;
+void imx_gpio_int_enable(struct imx_gpio_pin *pin)
+ pin->gpio->regs->imr |= pin->mask;
+uint32_t imx_gpio_get_isr(struct imx_gpio_pin *pin)
+ return (pin->gpio->regs->isr & pin->mask) >> pin->shift;
+void imx_gpio_clear_isr(struct imx_gpio_pin *pin, uint32_t clr)
+ pin->gpio->regs->isr = (clr << pin->shift) & pin->mask;
+RTEMS_SYSINIT_ITEM(
+ imx_gpio_attach,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_FIRST
diff --git a/bsps/arm/imx/headers.am b/bsps/arm/imx/headers.am
index dd18164254..3a093b1698 100644
--- a/bsps/arm/imx/headers.am
+++ b/bsps/arm/imx/headers.am
@@ -19,4 +19,5 @@ include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/
include_bspdir = $(includedir)/bsp
include_bsp_HEADERS =
+include_bsp_HEADERS += ../../../../../../bsps/arm/imx/include/bsp/imx-gpio.h
include_bsp_HEADERS += ../../../../../../bsps/arm/imx/include/bsp/irq.h
diff --git a/bsps/arm/imx/include/bsp/imx-gpio.h b/bsps/arm/imx/include/bsp/imx-gpio.h
index 0000000000..dca2d0cfad
--- /dev/null
+++ b/bsps/arm/imx/include/bsp/imx-gpio.h
@@ -0,0 +1,196 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifndef BSP_IMX_GPIO_H
+#define BSP_IMX_GPIO_H
+#include <rtems.h>
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/** Hardware registers and locking mechanism for one hardware GPIO module. */
+struct imx_gpio;
+/** Mode of the pin. */
+enum imx_gpio_mode {
+ IMX_GPIO_MODE_OUTPUT,
+ IMX_GPIO_MODE_INPUT,
+ IMX_GPIO_MODE_INTERRUPT_LOW,
+ IMX_GPIO_MODE_INTERRUPT_HIGH,
+ IMX_GPIO_MODE_INTERRUPT_RISING,
+ IMX_GPIO_MODE_INTERRUPT_FALLING,
+ IMX_GPIO_MODE_INTERRUPT_ANY_EDGE,
+ * A i.MX GPIO pin or set of pins.
+ * Use this structures to handle pins in the application. You can either get
+ * them from an FDT entry (with @ref imx_gpio_init_from_fde_property) or fill
+ * them by hand.
+struct imx_gpio_pin {
+ /** Management structure for the GPIO. Get with @ref imx_gpio_get_by_index. */
+ volatile struct imx_gpio* gpio;
+ * Select the pins you want to handle with this mask. The mask is not
+ * influenced by the @a shift field.
+ uint32_t mask;
+ /** If set to something != 0: Shift the pins that many bits. */
+ unsigned int shift;
+ /** Whether the pin is an input, output, interrupt, ... */
+ enum imx_gpio_mode mode;
+ * Initialize a GPIO pin. Only necessary for manually filled imx_gpio
+ * structures.
+void imx_gpio_init (struct imx_gpio_pin *pin);
+ * Initialize a GPIO pin from a FDT property.
+ * If you have for example the following property in an FDT node:
+ * some-node {
+ * gpios = <&gpio5 1 GPIO_ACTIVE_LOW>, <&gpio4 22 GPIO_ACTIVE_LOW>;
+ * you can use the following to initialize the second GPIO:
+ * imx_gpio_init_from_fdt_property(&pin, node, "gpios",
+ * IMX_GPIO_INTERRUPT_LOW, 1);
+ * NOTE: The information from the third parameter in the FDT (GPIO_ACTIVE_LOW in
+ * the example) is currently ignored.
+rtems_status_code imx_gpio_init_from_fdt_property(
+ int node_offset,
+ size_t index);
+ * Return the RTEMS interrupt vector belonging to the GPIO interrupt of a given
+ * node. The node should look like follows:
+ * some-node {
+ * interrupt-parent = <&gpio4>;
+ * interrupts = <15 IRQ_TYPE_EDGE_BOTH>, <22 IRQ_TYPE_EDGE_BOTH>;
+ * To get the interrupt vector from the first GPIO in interrupts use
+ * imx_gpio_get_irq_of_node(fdt, node, 0);
+ * @returns the interrupt vector if successful.
+ * @returns BSP_INTERRUPT_VECTOR_INVALID on failure.
+ const void *fdt,
+ int node,
+ size_t index);
+ * Return the gpio management structure based on the GPIO index. The index is
+ * the one used in the FDT alias list. So index 0 is GPIO1 in the i.MX docs for
+ * most FDTs based on the Linux one.
+struct imx_gpio *imx_gpio_get_by_index(unsigned idx);
+ * Return the gpio management structure based on the GPIO registers.
+struct imx_gpio *imx_gpio_get_by_register(void *regs);
+ * Get the name of the gpio.
+const char *imx_gpio_get_name(struct imx_gpio *imx_gpio);
+ * Set the value of the output pin. @a set will be shifted and masked (in that
+ * order) based on the values of @a pin.
+void imx_gpio_set_output(struct imx_gpio_pin *pin, uint32_t set);
+ * Toggle the value of the output pin.
+void imx_gpio_toggle_output(struct imx_gpio_pin *pin);
+ * Get the value of the input pin. The input value will be masked and shifted
+ * (in that order) based on the values of @a pin.
+uint32_t imx_gpio_get_input(struct imx_gpio_pin *pin);
+ * Disable the interrupt of the given @a pin.
+void imx_gpio_int_disable(struct imx_gpio_pin *pin);
+ * Enable the interrupt of the given @a pin.
+void imx_gpio_int_enable(struct imx_gpio_pin *pin);
+ * Read the interrupt status register for the given @a pin.
+uint32_t imx_gpio_get_isr(struct imx_gpio_pin *pin);
+ * Clear the interrupt status register for the given @a pin.
+void imx_gpio_clear_isr(struct imx_gpio_pin *pin, uint32_t clr);
+ * Fast access macros for the GPIOs. Note that these assume a FDT based on the
+ * Linux FDTs.
+#define IMX_GPIO1 (imx_gpio_get_by_index(0))
+#define IMX_GPIO2 (imx_gpio_get_by_index(1))
+#define IMX_GPIO3 (imx_gpio_get_by_index(2))
+#define IMX_GPIO4 (imx_gpio_get_by_index(3))
+#define IMX_GPIO5 (imx_gpio_get_by_index(4))
+#define IMX_GPIO6 (imx_gpio_get_by_index(5))
+#define IMX_GPIO7 (imx_gpio_get_by_index(6))
+#ifdef __cplusplus
+#endif /* BSP_IMX_GPIO_H */
diff --git a/bsps/arm/imx/include/bsp/irq.h b/bsps/arm/imx/include/bsp/irq.h
index 73d2e69b30..78b48e1613 100644
--- a/bsps/arm/imx/include/bsp/irq.h
+++ b/bsps/arm/imx/include/bsp/irq.h
@@ -28,6 +28,7 @@ extern "C" {
#define BSP_INTERRUPT_VECTOR_MIN 0
#define BSP_INTERRUPT_VECTOR_MAX 159
+#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
#ifdef __cplusplus
diff --git a/bsps/arm/imx/start/bspstart.c b/bsps/arm/imx/start/bspstart.c
index 36f62993a6..5fb07bf60a 100644
--- a/bsps/arm/imx/start/bspstart.c
+++ b/bsps/arm/imx/start/bspstart.c
@@ -47,7 +47,7 @@ rtems_vector_number imx_get_irq_of_node(
if (val == NULL || len < (int) ((index + 1) * 12)) {
- return UINT32_MAX;
+ return BSP_INTERRUPT_VECTOR_INVALID;
return fdt32_to_cpu(val[index * 3 + 1]) + MAGIC_IRQ_OFFSET;
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
index 3f8e1eb591..f95290b890 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -138,6 +138,7 @@ typedef enum {
/* i.MX fatal codes */
IMX_FATAL_GENERIC_TIMER_FREQUENCY = BSP_FATAL_CODE_BLOCK(12),
+ IMX_FATAL_GPIO_UNEXPECTED_FDT,
/* RISC-V fatal codes */
RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE = BSP_FATAL_CODE_BLOCK(13),
diff --git a/c/src/lib/libbsp/arm/imx/Makefile.am b/c/src/lib/libbsp/arm/imx/Makefile.am
index 234995f406..f71508a077 100644
--- a/c/src/lib/libbsp/arm/imx/Makefile.am
+++ b/c/src/lib/libbsp/arm/imx/Makefile.am
@@ -64,6 +64,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-generic-t
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-v7ar-disable-data.S
+# GPIO
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/gpio/imx-gpio.c
# I2C
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/i2c/imx-i2c.c
2.26.2
