[PATCH rtems-libbsd 1/7] gpioregulator: Remove.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jul 17 05:58:06 UTC 2020
Sorry: I accidentally set a reply address instead of having the patch
set as a reply to the intro mail for the first patch set. Please don't
use the reply to addres. It won't work.
On 17/07/2020 07:56, Christian Mauderer wrote:
> There is a bug in the #ifdef regarding FDT so this file hasn't been
> compiled. If that bug is solved, the driver doesn't work for some other
> reason.
> With the FDT-bug the driver hasn't been used by anyone. So just remove
> it again.
>  freebsd/sys/dev/gpio/gpioregulator.c | 352 ---------------------------
>  libbsd.py                            |   1 -
>  rtemsbsd/include/bsp/nexus-devices.h |   1 -
>  3 files changed, 354 deletions(-)
>  delete mode 100644 freebsd/sys/dev/gpio/gpioregulator.c
> diff --git a/freebsd/sys/dev/gpio/gpioregulator.c b/freebsd/sys/dev/gpio/gpioregulator.c
> deleted file mode 100644
> index 8ca35bfe..00000000
> --- a/freebsd/sys/dev/gpio/gpioregulator.c
> +++ /dev/null
> @@ -1,352 +0,0 @@
> -#include <machine/rtems-bsd-kernel-space.h>
> - * Copyright (c) 2016 Jared McNeill <jmcneill at invisible.ca>
> - * All rights reserved.
> - * Redistribution and use in source and binary forms, with or without
> - * modification, are permitted provided that the following conditions
> - * are met:
> - * 1. Redistributions of source code must retain the above copyright
> - *    notice, this list of conditions and the following disclaimer.
> - * 2. Redistributions in binary form must reproduce the above copyright
> - *    notice, this list of conditions and the following disclaimer in the
> - *    documentation and/or other materials provided with the distribution.
> - * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
> - * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
> - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
> - * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
> - * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
> - * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
> - * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
> - * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
> - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> - * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> - * SUCH DAMAGE.
> - * $FreeBSD$
> - * GPIO controlled regulators
> -#include <sys/cdefs.h>
> -__FBSDID("$FreeBSD$");
> -#include <sys/param.h>
> -#include <sys/systm.h>
> -#include <sys/bus.h>
> -#include <sys/rman.h>
> -#include <sys/kernel.h>
> -#include <sys/module.h>
> -#include <sys/gpio.h>
> -#if !defined(__rtems__) || defined(FDT)
> -#include <dev/ofw/ofw_bus.h>
> -#include <dev/ofw/ofw_bus_subr.h>
> -#include <dev/gpio/gpiobusvar.h>
> -#include <dev/extres/regulator/regulator.h>
> -#include <rtems/bsd/local/regdev_if.h>
> -struct gpioregulator_state {
> -	int			val;
> -	uint32_t		mask;
> -struct gpioregulator_init_def {
> -	struct regnode_init_def		reg_init_def;
> -	struct gpiobus_pin		*enable_pin;
> -	int				enable_pin_valid;
> -	int				startup_delay_us;
> -	int				nstates;
> -	struct gpioregulator_state	*states;
> -	int				npins;
> -	struct gpiobus_pin		**pins;
> -struct gpioregulator_reg_sc {
> -	struct regnode			*regnode;
> -	device_t			base_dev;
> -	struct regnode_std_param	*param;
> -	struct gpioregulator_init_def	*def;
> -struct gpioregulator_softc {
> -	device_t			dev;
> -	struct gpioregulator_reg_sc	*reg_sc;
> -	struct gpioregulator_init_def	init_def;
> -static int
> -gpioregulator_regnode_init(struct regnode *regnode)
> -	struct gpioregulator_reg_sc *sc;
> -	int error, n;
> -	sc = regnode_get_softc(regnode);
> -	if (sc->def->enable_pin_valid == 1) {
> -		error = gpio_pin_setflags(sc->def->enable_pin, GPIO_PIN_OUTPUT);
> -		if (error != 0)
> -			return (error);
> -	for (n = 0; n < sc->def->npins; n++) {
> -		error = gpio_pin_setflags(sc->def->pins[n], GPIO_PIN_OUTPUT);
> -		if (error != 0)
> -			return (error);
> -	return (0);
> -static int
> -gpioregulator_regnode_enable(struct regnode *regnode, bool enable, int *udelay)
> -	bool active;
> -	int error;
> -		active = enable;
> -		if (!sc->param->enable_active_high)
> -			active = !active;
> -		error = gpio_pin_set_active(sc->def->enable_pin, active);
> -		if (error != 0)
> -			return (error);
> -	*udelay = sc->def->startup_delay_us;
> -	return (0);
> -static int
> -gpioregulator_regnode_set_voltage(struct regnode *regnode, int min_uvolt,
> -    int max_uvolt, int *udelay)
> -	const struct gpioregulator_state *state;
> -	int error, n;
> -	state = NULL;
> -	for (n = 0; n < sc->def->nstates; n++) {
> -		if (sc->def->states[n].val >= min_uvolt &&
> -		    sc->def->states[n].val <= max_uvolt) {
> -			state = &sc->def->states[n];
> -			break;
> -	if (state == NULL)
> -		return (EINVAL);
> -		error = gpio_pin_set_active(sc->def->pins[n],
> -		    (state->mask >> n) & 1);
> -		if (error != 0)
> -			return (error);
> -	return (0);
> -static int
> -gpioregulator_regnode_get_voltage(struct regnode *regnode, int *uvolt)
> -	uint32_t mask;
> -	int error, n;
> -	bool active;
> -	mask = 0;
> -		error = gpio_pin_is_active(sc->def->pins[n], &active);
> -		if (error != 0)
> -			return (error);
> -		mask |= (active << n);
> -		if (sc->def->states[n].mask == mask) {
> -			*uvolt = sc->def->states[n].val;
> -			return (0);
> -	return (EIO);
> -static regnode_method_t gpioregulator_regnode_methods[] = {
> -	/* Regulator interface */
> -	REGNODEMETHOD(regnode_init,	gpioregulator_regnode_init),
> -	REGNODEMETHOD(regnode_enable,	gpioregulator_regnode_enable),
> -	REGNODEMETHOD(regnode_set_voltage, gpioregulator_regnode_set_voltage),
> -	REGNODEMETHOD(regnode_get_voltage, gpioregulator_regnode_get_voltage),
> -	REGNODEMETHOD_END
> -DEFINE_CLASS_1(gpioregulator_regnode, gpioregulator_regnode_class,
> -    gpioregulator_regnode_methods, sizeof(struct gpioregulator_reg_sc),
> -    regnode_class);
> -static int
> -gpioregulator_parse_fdt(struct gpioregulator_softc *sc)
> -	uint32_t *pstates, mask;
> -	phandle_t node;
> -	ssize_t len;
> -	int error, n;
> -	node = ofw_bus_get_node(sc->dev);
> -	pstates = NULL;
> -	mask = 0;
> -	error = regulator_parse_ofw_stdparam(sc->dev, node,
> -	    &sc->init_def.reg_init_def);
> -	if (error != 0)
> -		return (error);
> -	/* "states" property (required) */
> -	len = OF_getencprop_alloc_multi(node, "states", sizeof(*pstates),
> -	    (void **)&pstates);
> -	if (len < 2) {
> -		device_printf(sc->dev, "invalid 'states' property\n");
> -		error = EINVAL;
> -		goto done;
> -	sc->init_def.nstates = len / 2;
> -	sc->init_def.states = malloc(sc->init_def.nstates *
> -	    sizeof(*sc->init_def.states), M_DEVBUF, M_WAITOK);
> -	for (n = 0; n < sc->init_def.nstates; n++) {
> -		sc->init_def.states[n].val = pstates[n * 2 + 0];
> -		sc->init_def.states[n].mask = pstates[n * 2 + 1];
> -		mask |= sc->init_def.states[n].mask;
> -	/* "startup-delay-us" property (optional) */
> -	len = OF_getencprop(node, "startup-delay-us",
> -	    &sc->init_def.startup_delay_us,
> -	    sizeof(sc->init_def.startup_delay_us));
> -	if (len <= 0)
> -		sc->init_def.startup_delay_us = 0;
> -	/* "enable-gpio" property (optional) */
> -	error = gpio_pin_get_by_ofw_property(sc->dev, node, "enable-gpio",
> -	    &sc->init_def.enable_pin);
> -	if (error == 0)
> -		sc->init_def.enable_pin_valid = 1;
> -	/* "gpios" property */
> -	sc->init_def.npins = 32 - __builtin_clz(mask);
> -	sc->init_def.pins = malloc(sc->init_def.npins *
> -	    sizeof(sc->init_def.pins), M_DEVBUF, M_WAITOK | M_ZERO);
> -	for (n = 0; n < sc->init_def.npins; n++) {
> -		error = gpio_pin_get_by_ofw_idx(sc->dev, node, n,
> -		    &sc->init_def.pins[n]);
> -		if (error != 0) {
> -			device_printf(sc->dev, "cannot get pin %d\n", n);
> -			goto done;
> -done:
> -	if (error != 0) {
> -			if (sc->init_def.pins[n] != NULL)
> -				gpio_pin_release(sc->init_def.pins[n]);
> -		free(sc->init_def.states, M_DEVBUF);
> -		free(sc->init_def.pins, M_DEVBUF);
> -	OF_prop_free(pstates);
> -	return (error);
> -static int
> -gpioregulator_probe(device_t dev)
> -	if (!ofw_bus_is_compatible(dev, "regulator-gpio"))
> -		return (ENXIO);
> -	device_set_desc(dev, "GPIO controlled regulator");
> -	return (BUS_PROBE_GENERIC);
> -static int
> -gpioregulator_attach(device_t dev)
> -	struct gpioregulator_softc *sc;
> -	phandle_t node;
> -	int error;
> -	sc = device_get_softc(dev);
> -	sc->dev = dev;
> -	node = ofw_bus_get_node(dev);
> -	error = gpioregulator_parse_fdt(sc);
> -	if (error != 0) {
> -		device_printf(dev, "cannot parse parameters\n");
> -		return (ENXIO);
> -	sc->init_def.reg_init_def.id = 1;
> -	sc->init_def.reg_init_def.ofw_node = node;
> -	regnode = regnode_create(dev, &gpioregulator_regnode_class,
> -	if (regnode == NULL) {
> -		device_printf(dev, "cannot create regulator\n");
> -		return (ENXIO);
> -	sc->reg_sc = regnode_get_softc(regnode);
> -	sc->reg_sc->regnode = regnode;
> -	sc->reg_sc->base_dev = dev;
> -	sc->reg_sc->param = regnode_get_stdparam(regnode);
> -	sc->reg_sc->def = &sc->init_def;
> -	regnode_register(regnode);
> -	return (0);
> -static device_method_t gpioregulator_methods[] = {
> -	/* Device interface */
> -	DEVMETHOD(device_probe,		gpioregulator_probe),
> -	DEVMETHOD(device_attach,	gpioregulator_attach),
> -	/* Regdev interface */
> -	DEVMETHOD(regdev_map,		regdev_default_ofw_map),
> -	DEVMETHOD_END
> -static driver_t gpioregulator_driver = {
> -	"gpioregulator",
> -	gpioregulator_methods,
> -	sizeof(struct gpioregulator_softc),
> -static devclass_t gpioregulator_devclass;
> -EARLY_DRIVER_MODULE(gpioregulator, simplebus, gpioregulator_driver,
> -    gpioregulator_devclass, 0, 0, BUS_PASS_INTERRUPT + BUS_PASS_ORDER_LAST);
> -MODULE_VERSION(gpioregulator, 1);
> -#endif /* !__rtems__ || FDT */
> diff --git a/libbsd.py b/libbsd.py
> index 812674a6..aa940ab2 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -5232,7 +5232,6 @@ class regulator(builder.Module):
>                  'sys/dev/extres/regulator/regulator.c',
>                  'sys/dev/extres/regulator/regulator_bus.c',
>                  'sys/dev/extres/regulator/regulator_fixed.c',
> -                'sys/dev/gpio/gpioregulator.c',
>              mm.generator['source']()
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index f27d7a7e..89f78edf 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -151,7 +151,6 @@ SYSINIT_DRIVER_REFERENCE(sdhci_fsl, simplebus);
>  RTEMS_BSD_DRIVER_MMC;
>  SYSINIT_DRIVER_REFERENCE(ofw_regulator_bus, simplebus);
> -SYSINIT_DRIVER_REFERENCE(gpioregulator, simplebus);
>  #elif defined(LIBBSP_ARM_LPC24XX_BSP_H)
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
