Need help in understanding some of the existing code in RTEMS
Richi Dubey
richidubey at gmail.com
Fri Jul 17 08:22:10 UTC 2020
> > Scheduler_Node *nodes;
> > } Thread_Scheduler_control;
> > Why do we have a Scheduler_Node *nodes? What does it indicate? Since the
> pointer can point to a single value, why is it being called nodes?
> See cpukit/score/src/threadinitialize.c +153
Thank you for your help.
* @brief The scheduler nodes of this thread.
* Each thread has a scheduler node for each scheduler instance.
I went through the entire scheduler related code in threadinitialize.c and
I understood that the scheduler node which belongs to the scheduler that is
the home scheduler for a thread gets initialized with the thread's
priority, while other scheduler nodes gets initialized with the max
priority : for an idle thread case.
But why do we have a scheduler node for each scheduler instance? Is it
because the thread might migrate to a different processor to facilitate
helping and would need a node belonging to the scheduler instance which
owns the processor it is migrating to?
On Wed, Jul 15, 2020 at 10:12 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Jul 15, 2020 at 6:55 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Another quick question:
> > typedef struct {
> > #if defined(RTEMS_SMP)
> > Chain_Control Scheduler_nodes;
> > #endif
> > On Wed, Jul 15, 2020 at 5:57 PM Richi Dubey <richidubey at gmail.com>
> wrote:
> >> Hi,
> >> I had a small question. The scheduler struct inside percpu.h looks like:
> >> struct {
> >> * @brief The scheduler control of the scheduler owning this
> processor.
> >> * This pointer is NULL in case this processor is currently not
> used by a
> >> * scheduler instance.
> >> const struct _Scheduler_Control *control;
> >> * @brief The scheduler context of the scheduler owning this
> processor.
> used by a
> >> const struct Scheduler_Context *context;
> >> * @brief The idle thread for this processor in case it is online
> and
> >> * currently not used by a scheduler instance.
> >> struct _Thread_Control *idle_if_online_and_unused;
> >> } Scheduler;
> >> So, does this mean a CPU when active is always either executing an idle
> thread and is not being used by a scheduler (so has a thread attribute in
> the idle_if_online_and_unused), or is used by a scheduler and is executing
> a task ( which can not be an idle task)? Another equivalent question is do
> we have an idle scheduler node, like we have idle predefined threads that
> run on a CPU?
> Not exactly. What I understand is that:
> * When a processor is online (active), but not used by a scheduler,
> then it executes an idle task.
> * When a processor is online and used by a scheduler, it may be
> executing any task including an idle task.
> You can find the relevant code in
> cpukit/include/rtems/score/schedulersmpimpl.h
> The idle threads are specially handled when processors are
> added/removed from scheduler contexts. A scheduler keeps a chain of
> its idle threads:
> cpukit/include/rtems/score/schedulersmp.h +64
> >> Please let me know,
> >> Thanks.
> >> On Tue, Jul 14, 2020 at 8:28 PM Richi Dubey <richidubey at gmail.com>
> wrote:
> >>> I understand. Thank you.
> >>> On Tue, Jul 14, 2020 at 7:05 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >>>> On 14/07/2020 13:37, Richi Dubey wrote:
> >>>> > Here we remove the affine ready queue if it
> >>>> > exists from the chain of affine queues since now an affine
> thread is
> >>>> > scheduled on a processor.
> >>>> > Why are we removing the entire affine queue corresponding to a
> >>>> > CPU when a single node of the queue gets scheduled?
> >>>> Because the highest priority affine thread is now a schedule one.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200717/dd9f9035/attachment-0001.html>
