[PATCH] removed SOFTFP fenv support from ARM
Eshan Dhawan
eshandhawan51 at gmail.com
Fri Jul 17 12:15:45 UTC 2020
> On 17-Jul-2020, at 10:40 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 17/07/2020 01:23, Eshan dhawan wrote:
>> int fegetexcept(void)
>> - int __unmasked;
>> - __unmasked = 0;
>> #ifndef SOFTFP_ABI
> Do we need this extra define, can't we use
> #ifndef __SOFTFP__
> like in glibc?
“Paradoxically,the -mfloat-abi=softfp does not set the __SOFTFP___ macro, since it selects real floating point instructions using the soft-float ABI at function-call interfaces.”
So SOFTFP_ABI is defined. :)
You can read more here :
https://wiki.debian.org/ArmEabiPort#:~:text=__VFP_FP__%20means%20that,and%20is%20always%20little%2Dendian
Under “ GCC preprocessor macros for floating point ”
-Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200717/b6d9c1c5/attachment.html>
