[PATCH v3] Changed ARM fenv support similar to X86_64
    Sebastian Huber
    Sat Jul 18 15:59:25 UTC 2020
On 18/07/2020 17:39, Eshan Dhawan wrote:
>>>> Why is x86_64mentioned in the commit message? On the mailing list it was discussed to use RISC-V as the model. Please improve the commit message in general. It should reflect all the problems discussed on the mailing list and how the commit addresses the issues.
>>> The files follow the similar file structure as x86_64. So I added X86
>> Which file did you use as a template?
> The softfp Implementation is taken from riscv but has stub implementation
Ok, good and why did you mention the x86_64? The arm implementation
looks pretty much like the riscv one except that all functions are in a
single file.
