[GSoC 2020]: Weekly thread update
Heinz Junkes junkes at fhi-berlin.mpg.de
Sat Jul 18 17:15:40 UTC 2020
Mritunjay,
can you try to use the commit 3afec267ab08568ea454789e562450b00feea5c0
Dated 25.9. 2019
From Heinz
> On 17.07.2020, at 20:23, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>> On Fri, Jul 17, 2020 at 12:53 PM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>> You are right. I was not aware of that the dhcpcd stuff is already included into the source of the epicsPlayground repo. Will have a look into it.
>> Heinz
>> FHI, Heinz Junkes
> Thank you so much, Heinz! It will be kind of you to advice for now to how to proceed ahead like whether we have to either
> use and build the old legacy stack using `--enable-networking` or the libbsd stack?
> Also, should I start writing the recipe for RSB based on the existing notes of how the process went for building
> EPICS7 for RTEMS5 for pc-386?
> Also, I have written another blog on what I learnt recently (using mutt). Here's the link:
> https://medium.com/@mritunjaysharma394/how-to-set-up-mutt-text-based-mail-client-with-gmail-993ae40b0003
> I also learnt about Networking Drivers from https://docs.rtems.org/branches/master/bsp-howto/networking.html.
> Thanks,
> Mritunjay.
>>> On 15. Jul 2020, at 22:05, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>>> Apologies as I mistakenly sent this as a private mail.
>>> I missed to tag Chris, Gedare and RTEMS Devel and that's why sending this again on what
>>> I responded.
>>>> On Wed, Jul 15, 2020 at 10:35 PM Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>>>>> On Wed, Jul 15, 2020 at 7:48 PM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>>>>> Hello, Mritunjay,
>>>>> I'm afraid I've lost track of the situation. I am also still on holiday in Norway for 2 weeks and
>>>>> I don't always have perfect internet access.
>>> This:->
>>>> I am extremely sorry to disturb you on a holiday. I will try to bring back to you where we currently are:
>>>> As advised by you I already have Built EPICS 7 with RTEMS 4.10 and tested it as well.
>>>> I was doing the same for EPICS7 with RTEMS5 for pc-386. I apologise that I forgot to update the thread that the suggestion
>>>> presented by Gedare to change to  `#include <rtems/bsd.h>` from existing `#include <rtems/bsd/bsd.h>` helped me
>>>> fixed the error mentioned in the start of the thread ("../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such file or directory
>>>>  #include <rtems/bsd/bsd.h>").
>>>> I used the 'make' command again then inside `epics-base` (Downloaded from your GitHub's playground) and then got the
>>>> following error:
>>>> `../posix/rtems_init.c:39:10: fatal error: rtems/dhcpcd.h: No such file or directory
>>>>  #include <rtems/dhcpcd.h>
>>>> I discussed this with Gedare on the IRC channel and we concluded that it is there because we have to either
>>>> use and build the old legacy stack using `--enable-networking` or the libbsd stack.
>>>> I would like your advice on what should work here and how to approach doing each of these builds?
>>>> Also, I again apologise that I am disturbing you on a holiday. Please enjoy and take care!
>>>> Thanks
>>>> Mritunjay
>>>>> Where can I find your blog. I only found something from June 9th. What is the current location of the blog?
>>> This:->
>>>> I have made another blog which as of now deals with building BSPs and I have to update the draft of another one
>>>> which will further demonstrate on how to Build EPICS.
>>>> The link to the blog is:  https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>>>>> I'm afraid you've made a mess of things here.
>>> This:-
>>>> I am sorry if I have and I accept that I am a beginner but am really enjoying the learning I am making this summer.
>>>> Thank you so much for the support everyone in helping me grow and learn.
>>>> Thanks
>>>> Mritunjay
>>>>> In the "official" epics repo, you can read
>>>>> https://github.com/epics-base/epics-base/blob/7.0/modules/libcom/RTEMS/rtems_init.c :
>>>>> #include <rtems/stackchk.h>
>>>>> #include <rtems/rtems_bsdnet.h>
>>>>> #include <rtems/imfs.h>
>>>>> #include <librtemsNfs.h>
>>>>> #include <bsp.h>
>>>>> Here the definition of the legacy stack will be included
>>>>> Viele Grüße
>>>>> Heinz Junkes
>>>>> Experience directly varies with equipment ruined.
>>>>> > On 15. Jul 2020, at 05:57, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>>>>> > On Wed, Jul 15, 2020 at 5:33 AM Chris Johns <chrisj at rtems.org> wrote:
>>>>> > On 15/7/20 4:30 am, Mritunjay Sharma wrote:
>>>>> > > Hello everyone,
>>>>> > > Pardon my mistake for that long thread. From now on the daily updates will be
>>>>> > > given on a thread that will end every week.
>>>>> > Thank you :)
>>>>> > > 1) I studied about https://github.com/RTEMS/rtems-libbsd
>>>>> > > 2) Tried to fix the error that I reported yesterday:
>>>>> > Why cut the compile command line used to build this file out of the message? The
>>>>> > compiler command is important because it lets us see what paths are being used
>>>>> > and I think there may be a problem with them.
>>>>> > I cannot duplicate this because I am not sure what the sequence of commands are
>>>>> > you used to get to here. I am sorry if I missed it in a previous post.
>>>>> > The error indicates a set up issue. It normally means the networking software
>>>>> > (rtems-libbsd) has not been installed into a prefix path EPICS looks in.
>>>>> > I am posting the entire command set further ahead in the email which will make things
>>>>> > easier to understand.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200718/f4a5d115/attachment.html>
