[PATCH rtems v2 3/3] bsps/fdt: Make sure data is cache aligned.
Gedare Bloom
gedare at rtems.org
Mon Jul 20 20:01:35 UTC 2020
looks good if it works, thanks Christian!
On Sun, Jul 19, 2020 at 11:47 PM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> The cache of the fdt blob is flushed after copy. Therefore it should be
> aligned.
> bsps/shared/start/bsp-fdt.c | 8 +++++---
> 1 file changed, 5 insertions(+), 3 deletions(-)
> diff --git a/bsps/shared/start/bsp-fdt.c b/bsps/shared/start/bsp-fdt.c
> index 7e8d8922a8..50a485eb16 100644
> --- a/bsps/shared/start/bsp-fdt.c
> +++ b/bsps/shared/start/bsp-fdt.c
> @@ -29,10 +29,11 @@
> #ifdef BSP_FDT_BLOB_READ_ONLY
> static const uint32_t
> -bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)] = { 0xdeadbeef };
> +bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)] CPU_STRUCTURE_ALIGNMENT =
> + { 0xdeadbeef };
> #else
> static uint32_t
> -bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)];
> +bsp_fdt_blob[BSP_FDT_BLOB_SIZE_MAX / sizeof(uint32_t)] CPU_STRUCTURE_ALIGNMENT;
> #endif
> void bsp_fdt_copy(const void *src)
> @@ -48,6 +49,7 @@ void bsp_fdt_copy(const void *src)
> if (s != d) {
> size_t m = MIN(sizeof(bsp_fdt_blob), fdt_totalsize(src));
> + size_t aligned_size = roundup2(m, CPU_CACHE_LINE_BYTES);
> size_t n = (m + sizeof(*d) - 1) / sizeof(*d);
> size_t i;
> @@ -55,7 +57,7 @@ void bsp_fdt_copy(const void *src)
> d[i] = s[i];
> - rtems_cache_flush_multiple_data_lines(d, m);
> + rtems_cache_flush_multiple_data_lines(d, aligned_size);
> 2.26.2
