[PATCH 09/33] libtest: Split POSIX Keys support
Tue Jul 21 15:04:26 UTC 2020
Update #3199.
 cpukit/Makefile.am                       |   1 +
 cpukit/libtest/t-test-rtems-objs.c       |  95 +++----------------
 cpukit/libtest/t-test-rtems-posix-keys.c | 115 +++++++++++++++++++++++
 cpukit/libtest/t-test-rtems.h            |  62 ++++++++++++
 4 files changed, 193 insertions(+), 80 deletions(-)
 create mode 100644 cpukit/libtest/t-test-rtems-posix-keys.c
 create mode 100644 cpukit/libtest/t-test-rtems.h
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index a119055abb..ce25efe10b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1870,6 +1870,7 @@ librtemstest_a_SOURCES += libtest/t-test-rtems-fds.c
 librtemstest_a_SOURCES += libtest/t-test-rtems-heap.c
 librtemstest_a_SOURCES += libtest/t-test-rtems-measure.c
 librtemstest_a_SOURCES += libtest/t-test-rtems-objs.c
+librtemstest_a_SOURCES += libtest/t-test-rtems-posix-keys.c
 librtemstest_a_SOURCES += libtest/t-test-time.c
 project_lib_LIBRARIES += libftpd.a
diff --git a/cpukit/libtest/t-test-rtems-objs.c b/cpukit/libtest/t-test-rtems-objs.c
index a5d6b4d72f..72447fd22f 100644
--- a/cpukit/libtest/t-test-rtems-objs.c
+++ b/cpukit/libtest/t-test-rtems-objs.c
@@ -1,7 +1,15 @@
- * SPDX-License-Identifier: BSD-2-Clause
+ * @file
- * Copyright (C) 2018 embedded brains GmbH
+ * @ingroup RTEMSTestFramework
+ * @brief RTEMS Objects Support for Test Framework
+ * Copyright (C) 2018 embedded brains GmbH (http://www.embedded-brains.de)
  * modification, are permitted provided that the following conditions
@@ -27,15 +35,15 @@
 #undef __STRICT_ANSI__
+#include "t-test-rtems.h"
 #include <rtems/test.h>
 #include <inttypes.h>
-#include <rtems/score/objectimpl.h>
-#include <rtems/posix/keyimpl.h>
-static Objects_Maximum
+Objects_Maximum
 T_objects_count(Objects_APIs api, uint16_t cls)
 	const Objects_Information *information;
@@ -56,7 +64,7 @@ T_objects_count(Objects_APIs api, uint16_t cls)
 	return count;
-static void
+void
 T_objects_check(Objects_APIs api, uint16_t cls,
     Objects_Maximum *expected, const char *name)
@@ -372,76 +380,3 @@ T_check_rtems_timers(T_event event, const char *name)
 		break;
-static Objects_Maximum T_posix_key_count;
-static ssize_t T_posix_key_value_count;
-static POSIX_Keys_Control *
-T_get_next_posix_key(Objects_Id *id)
-	return (POSIX_Keys_Control *)
-	    _Objects_Get_next(*id, &_POSIX_Keys_Information, id);
-static ssize_t
-T_get_active_posix_key_value_pairs(void)
-	ssize_t count;
-	Objects_Id id;
-	POSIX_Keys_Control *the_key;
-	count = 0;
-	id = OBJECTS_ID_INITIAL_INDEX;
-	while ((the_key = T_get_next_posix_key(&id)) != NULL ) {
-		count += (ssize_t)
-		    _Chain_Node_count_unprotected(&the_key->Key_value_pairs);
-		_Objects_Allocator_unlock();
-	return count;
-static void
-T_posix_keys_run_initialize(void)
-	T_posix_key_count = T_objects_count(OBJECTS_POSIX_API,
-	    OBJECTS_POSIX_KEYS);
-	T_posix_key_value_count = T_get_active_posix_key_value_pairs();
-static void
-T_posix_keys_case_end(void)
-	ssize_t count;
-	ssize_t delta;
-	T_objects_check(OBJECTS_POSIX_API, OBJECTS_POSIX_KEYS,
-	    &T_posix_key_count, "POSIX key");
-	count = T_get_active_posix_key_value_pairs();
-	delta = count - T_posix_key_value_count;
-	if (delta != 0) {
-		T_posix_key_value_count = count;
-		T_check_true(false, NULL, "POSIX key value pair leak (%zi)", delta);
-void
-T_check_posix_keys(T_event event, const char *name)
-	(void)name;
-	switch (event) {
-	case T_EVENT_RUN_INITIALIZE_EARLY:
-		T_posix_keys_run_initialize();
-		break;
-	case T_EVENT_CASE_END:
-		T_posix_keys_case_end();
-		break;
-	default:
-		break;
diff --git a/cpukit/libtest/t-test-rtems-posix-keys.c b/cpukit/libtest/t-test-rtems-posix-keys.c
new file mode 100644
index 0000000000..0769f68ba8
--- /dev/null
+++ b/cpukit/libtest/t-test-rtems-posix-keys.c
@@ -0,0 +1,115 @@
+ * @file
+ * @brief RTEMS POSIX Keys Support for Test Framework
+ * are met:
+#undef __STRICT_ANSI__
+#include <rtems/test.h>
+#include <rtems/posix/keyimpl.h>
+static Objects_Maximum T_posix_key_count;
+static ssize_t T_posix_key_value_count;
+static POSIX_Keys_Control *
+T_get_next_posix_key(Objects_Id *id)
+	return (POSIX_Keys_Control *)
+	    _Objects_Get_next(*id, &_POSIX_Keys_Information, id);
+static ssize_t
+T_get_active_posix_key_value_pairs(void)
+	ssize_t count;
+	Objects_Id id;
+	POSIX_Keys_Control *the_key;
+	count = 0;
+	id = OBJECTS_ID_INITIAL_INDEX;
+	while ((the_key = T_get_next_posix_key(&id)) != NULL ) {
+		count += (ssize_t)
+		    _Chain_Node_count_unprotected(&the_key->Key_value_pairs);
+		_Objects_Allocator_unlock();
+	return count;
+static void
+T_posix_keys_run_initialize(void)
+	T_posix_key_count = T_objects_count(OBJECTS_POSIX_API,
+	    OBJECTS_POSIX_KEYS);
+	T_posix_key_value_count = T_get_active_posix_key_value_pairs();
+static void
+T_posix_keys_case_end(void)
+	ssize_t count;
+	ssize_t delta;
+	T_objects_check(OBJECTS_POSIX_API, OBJECTS_POSIX_KEYS,
+	    &T_posix_key_count, "POSIX key");
+	count = T_get_active_posix_key_value_pairs();
+	delta = count - T_posix_key_value_count;
+	if (delta != 0) {
+		T_posix_key_value_count = count;
+		T_check_true(false, NULL, "POSIX key value pair leak (%zi)", delta);
+void
+T_check_posix_keys(T_event event, const char *name)
+	(void)name;
+	switch (event) {
+	case T_EVENT_RUN_INITIALIZE_EARLY:
+		T_posix_keys_run_initialize();
+		break;
+	case T_EVENT_CASE_END:
+		T_posix_keys_case_end();
+		break;
+	default:
+		break;
diff --git a/cpukit/libtest/t-test-rtems.h b/cpukit/libtest/t-test-rtems.h
index 0000000000..cc36ba96a1
--- /dev/null
+++ b/cpukit/libtest/t-test-rtems.h
@@ -0,0 +1,62 @@
+ * @file
+ * @ingroup RTEMSTestFrameworkImpl
+ * @brief RTEMS Support for Test Framework
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifndef _T_TEST_RTEMS_H
+#define _T_TEST_RTEMS_H
+#include <rtems/score/objectimpl.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSTestFrameworkImpl
+Objects_Maximum T_objects_count(Objects_APIs api, uint16_t cls);
+void T_objects_check(Objects_APIs api, uint16_t cls,
+    Objects_Maximum *expected, const char *name);
+#ifdef __cplusplus
+#endif
+#endif /* _T_TEST_RTEMS_H */
2.26.2
