[PATCH 15/33] libtest: Add rtems_test_run()
Sebastian Huber
Tue Jul 21 15:04:32 UTC 2020
Update #3199.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/simple-test.h | 14 +++++
cpukit/libtest/testrun.c | 87 ++++++++++++++++++++++++++++++
spec/build/cpukit/librtemstest.yml | 1 +
4 files changed, 103 insertions(+)
create mode 100644 cpukit/libtest/testrun.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index ce25efe10b..89edaefb17 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1855,6 +1855,7 @@ librtemstest_a_SOURCES += libtest/testbeginend.c
librtemstest_a_SOURCES += libtest/testbusy.c
librtemstest_a_SOURCES += libtest/testextension.c
librtemstest_a_SOURCES += libtest/testparallel.c
+librtemstest_a_SOURCES += libtest/testrun.c
librtemstest_a_SOURCES += libtest/testwrappers.c
librtemstest_a_SOURCES += libtest/t-test.c
librtemstest_a_SOURCES += libtest/t-test-busy.c
diff --git a/cpukit/include/rtems/simple-test.h b/cpukit/include/rtems/simple-test.h
index 42f5235af8..d5580bdebb 100644
--- a/cpukit/include/rtems/simple-test.h
+++ b/cpukit/include/rtems/simple-test.h
@@ -304,6 +304,20 @@ void rtems_test_parallel(
void rtems_test_busy_cpu_usage(time_t seconds, long nanoseconds);
+ * @brief Runs the test cases of the RTEMS Test Framework using a default
+ * configuration in the context of a task.
+ * The application must provide rtems_test_name.
+ * @param arg is the task argument.
+ * @param state is the test state.
+RTEMS_NO_RETURN void rtems_test_run(
+ rtems_task_argument arg,
+ const RTEMS_TEST_STATE state
#ifdef __cplusplus
diff --git a/cpukit/libtest/testrun.c b/cpukit/libtest/testrun.c
new file mode 100644
index 0000000000..5f5c3ebe66
--- /dev/null
+++ b/cpukit/libtest/testrun.c
@@ -0,0 +1,87 @@
+ * @file
+ * @ingroup RTEMSAPI
+ * @brief Implementation of rtems_test_run_default().
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/simple-test.h>
+#include <rtems/test.h>
+static char buffer[ 512 ];
+static const T_action actions[] = {
+ T_report_hash_sha256,
+ T_check_task_context,
+ T_check_file_descriptors,
+ T_check_rtems_barriers,
+ T_check_rtems_extensions,
+ T_check_rtems_message_queues,
+ T_check_rtems_partitions,
+ T_check_rtems_periods,
+ T_check_rtems_regions,
+ T_check_rtems_semaphores,
+ T_check_rtems_tasks,
+ T_check_rtems_timers,
+ T_check_posix_keys
+static const T_config config = {
+ .name = rtems_test_name,
+ .buf = buffer,
+ .buf_size = sizeof( buffer ),
+ .putchar = T_putchar_default,
+ .verbosity = T_VERBOSE,
+ .now = T_now_clock,
+ .action_count = T_ARRAY_SIZE( actions ),
+ .actions = actions
+void rtems_test_run(
+ (void) arg;
+ rtems_test_begin( rtems_test_name, state );
+ T_register();
+ if ( T_main( &config ) == 0 ) {
+ rtems_test_end( rtems_test_name );
+ rtems_test_exit( 0 );
diff --git a/spec/build/cpukit/librtemstest.yml b/spec/build/cpukit/librtemstest.yml
index f6c6fb53e6..227baf1960 100644
--- a/spec/build/cpukit/librtemstest.yml
+++ b/spec/build/cpukit/librtemstest.yml
@@ -15,6 +15,7 @@ source:
- cpukit/libtest/testbusy.c
- cpukit/libtest/testextension.c
- cpukit/libtest/testparallel.c
+- cpukit/libtest/testrundefault.c
- cpukit/libtest/testwrappers.c
- cpukit/libtest/t-test.c
- cpukit/libtest/t-test-checks.c
2.26.2
