[PATCH 00/33] Test framework improvements
Sebastian Huber
Tue Jul 21 15:04:17 UTC 2020
This patch set adds a couple of improvements to the test framework:
* The header file changes from <t.h> to <rtems/test.h>.
* Support for a stack of test fixtures. This helps to write test
building blocks.
* The test check messages are now optional.
* The support for interrupt tests and change all the interrupt critical
tests to use this new test support. This should address the sporadic
failures and timeouts.
For the documentation please have a look at:
https://ftp.rtems.org/pub/rtems/people/sebh/eng2.pdf
Sebastian Huber (33):
libtest: <rtems/test.h> to <rtems/simple-test.h>
libtest: Move <t.h> to <rtems/test.h>
libtest: Add T_busy()
libtest: Add T_get_one_clock_tick_busy()
libtest: Add T_make_runner()
libtest: Support custom scope messages via fixture
libtest: Add push/pop fixture support
libtest: Add T_get_scope()
libtest: Split POSIX Keys support
libtest: Add T_stop()
libtest: Add T_CHECK_FMT
libtest: Make check message optional
libtest: Add T_unreachable()
libtest: Add quiet assert NULL pointer checks
libtest: Add rtems_test_run()
libtest: Add T_interrupt_test()
psxintrcritical01: Use T_interrupt_test()
spintrcritical01/2/3/4/5: Use T_interrupt_test()
spintrcritical06/spintrcritical07: Remove tests
spintrcritical08: Use T_interrupt_test()
spintrcritical09: Use T_interrupt_test()
spintrcritical10: Use T_interrupt_test()
spintrcritical11/12: Use T_interrupt_test()
spintrcritical13/14: Use T_interrupt_test()
spintrcritical15: Use T_interrupt_test()
spintrcritical16: Use T_interrupt_test()
spintrcritical18: Use T_interrupt_test()
spintrcritical20: Use T_interrupt_test()
spintrcritical21: Use T_interrupt_test()
spintrcritical22: Use T_interrupt_test()
spintrcritical23: Use T_interrupt_test()
spintrcritical24: Use T_interrupt_test()
spintrcritical_support: Remove
cpukit/Makefile.am | 5 +
cpukit/headers.am | 3 +-
cpukit/include/rtems/doxygen-appl-config.h | 3736 +++++++++++++++++
cpukit/include/rtems/simple-test.h | 327 ++
cpukit/include/rtems/test.h | 2653 ++++++++++--
cpukit/include/t.h | 2379 -----------
cpukit/libtest/t-test-busy-tick.c | 121 +
cpukit/libtest/t-test-busy.c | 58 +
cpukit/libtest/t-test-checks-eno.c | 10 +-
cpukit/libtest/t-test-checks-psx.c | 10 +-
cpukit/libtest/t-test-checks.c | 194 +-
cpukit/libtest/t-test-hash-sha256.c | 2 +-
cpukit/libtest/t-test-interrupt.c | 420 ++
cpukit/libtest/t-test-malloc.c | 2 +-
cpukit/libtest/t-test-rtems-context.c | 8 +-
cpukit/libtest/t-test-rtems-fds.c | 5 +-
cpukit/libtest/t-test-rtems-heap.c | 6 +-
cpukit/libtest/t-test-rtems-measure.c | 2 +-
cpukit/libtest/t-test-rtems-objs.c | 100 +-
cpukit/libtest/t-test-rtems-posix-keys.c | 116 +
cpukit/libtest/t-test-rtems.c | 10 +-
cpukit/libtest/t-test-rtems.h | 62 +
cpukit/libtest/t-test-time.c | 2 +-
cpukit/libtest/t-test.c | 279 +-
cpukit/libtest/testbeginend.c | 2 +-
cpukit/libtest/testbusy.c | 89 +-
cpukit/libtest/testextension.c | 2 +-
cpukit/libtest/testparallel.c | 2 +-
cpukit/libtest/testrun.c | 87 +
cpukit/libtest/testwrappers.c | 2 +-
spec/build/cpukit/librtemstest.yml | 1 +
testsuites/ada/support/initimpl.h | 2 +-
testsuites/libtests/Makefile.am | 9 +
testsuites/libtests/block08/system.h | 2 +-
testsuites/libtests/block09/init.c | 2 +-
testsuites/libtests/block10/init.c | 2 +-
testsuites/libtests/capture01/system.h | 2 +-
testsuites/libtests/configure.ac | 1 +
testsuites/libtests/dl01/dl01-o1.c | 2 +-
testsuites/libtests/dl02/dl02-o1.c | 2 +-
testsuites/libtests/dl02/dl02-o2.c | 2 +-
testsuites/libtests/dl05/dl05-o5.cc | 2 +-
testsuites/libtests/dl06/dl06-o1.c | 2 +-
testsuites/libtests/dl06/dl06-o2.c | 2 +-
testsuites/libtests/dl07/dl07-o1.c | 2 +-
testsuites/libtests/dl07/dl07-o2.c | 2 +-
testsuites/libtests/dl07/dl07-o3.c | 2 +-
testsuites/libtests/dl07/dl07-o4.c | 2 +-
testsuites/libtests/dl07/dl07-o5.c | 2 +-
testsuites/libtests/dl08/dl08-o1.c | 2 +-
testsuites/libtests/dl08/dl08-o2.c | 2 +-
testsuites/libtests/dl08/dl08-o3.c | 2 +-
testsuites/libtests/dl08/dl08-o4.c | 2 +-
testsuites/libtests/dl08/dl08-o5.c | 2 +-
.../dl08/dl08-o6-123456789-123456789.c | 2 +-
testsuites/libtests/dl09/dl09-o1.c | 2 +-
testsuites/libtests/dl09/dl09-o2.c | 2 +-
testsuites/libtests/dl09/dl09-o3.c | 2 +-
testsuites/libtests/dl09/dl09-o4.c | 2 +-
testsuites/libtests/dl09/dl09-o5.c | 2 +-
testsuites/libtests/dl10/dl10-o1.c | 2 +-
testsuites/libtests/dl10/dl10-o2.c | 2 +-
testsuites/libtests/dl10/dl10-o3.c | 2 +-
testsuites/libtests/dl10/dl10-o4.c | 2 +-
testsuites/libtests/dl10/dl10-o5.c | 2 +-
testsuites/libtests/dl10/dl10-o6.c | 2 +-
testsuites/libtests/mathl/init.c | 2 +-
testsuites/libtests/ttest01/init.c | 6 +-
testsuites/libtests/ttest01/test-assert.c | 2 +-
testsuites/libtests/ttest01/test-checks.c | 25 +-
testsuites/libtests/ttest01/test-destructor.c | 2 +-
testsuites/libtests/ttest01/test-eno.c | 2 +-
testsuites/libtests/ttest01/test-example.c | 2 +-
testsuites/libtests/ttest01/test-fixture.c | 121 +-
testsuites/libtests/ttest01/test-leak.c | 2 +-
testsuites/libtests/ttest01/test-log.c | 2 +-
testsuites/libtests/ttest01/test-malloc.c | 2 +-
testsuites/libtests/ttest01/test-plan.c | 2 +-
testsuites/libtests/ttest01/test-psx.c | 2 +-
testsuites/libtests/ttest01/test-rtems.c | 2 +-
testsuites/libtests/ttest01/test-simple.c | 2 +-
testsuites/libtests/ttest01/test-step.c | 2 +-
.../libtests/ttest01/test-task-context.c | 2 +-
testsuites/libtests/ttest01/test-time.c | 2 +-
testsuites/libtests/ttest01/test-verbosity.c | 2 +-
testsuites/libtests/ttest02/init.c | 176 +
testsuites/libtests/ttest02/ttest02.doc | 11 +
testsuites/libtests/ttest02/ttest02.scn | 37 +
testsuites/psxtests/Makefile.am | 3 +-
testsuites/psxtests/psxbarrier01/main.c | 2 +-
testsuites/psxtests/psxconfig01/init.c | 2 +-
testsuites/psxtests/psxfenv01/init.c | 2 +-
testsuites/psxtests/psxintrcritical01/init.c | 135 +-
.../psxintrcritical01/psxintrcritical01.scn | 33 +-
testsuites/psxtests/psxinttypes01/init.c | 2 +-
testsuites/psxtests/psxndbm01/init.c | 2 +-
testsuites/psxtests/psxrwlock01/main.c | 2 +-
testsuites/samples/base_mp/system.h | 2 +-
testsuites/samples/base_sp/system.h | 2 +-
testsuites/samples/capture/system.h | 2 +-
testsuites/samples/cdtest/main.cc | 2 +-
testsuites/samples/cdtest/system.h | 2 +-
testsuites/samples/fileio/system.h | 2 +-
testsuites/samples/iostream/system.h | 2 +-
testsuites/samples/nsecs/system.h | 2 +-
testsuites/samples/paranoia/system.h | 2 +-
testsuites/samples/pppd/system.h | 2 +-
testsuites/samples/ticker/system.h | 2 +-
testsuites/smptests/smpatomic01/init.c | 2 +-
testsuites/smptests/smplock01/init.c | 2 +-
testsuites/smptests/smpmulticast01/init.c | 2 +-
testsuites/smptests/smpscheduler03/init.c | 2 +-
testsuites/smptests/smpscheduler05/init.c | 2 +-
testsuites/smptests/smpscheduler06/init.c | 2 +-
testsuites/smptests/smpscheduler07/init.c | 2 +-
testsuites/sptests/Makefile.am | 95 +-
testsuites/sptests/configure.ac | 2 -
testsuites/sptests/spheapprot/init.c | 2 +-
.../spintrcritical01/spintrcritical01.scn | 30 +-
.../spintrcritical01/spintrcritical01impl.h | 121 +-
.../spintrcritical02/spintrcritical02.scn | 30 +-
.../spintrcritical03/spintrcritical03.scn | 30 +-
.../spintrcritical04/spintrcritical04.scn | 30 +-
.../spintrcritical05/spintrcritical05.scn | 30 +-
testsuites/sptests/spintrcritical06/init.c | 2 -
.../spintrcritical06/spintrcritical06.doc | 28 -
.../spintrcritical06/spintrcritical06.scn | 6 -
.../spintrcritical06/spintrcritical06impl.h | 145 -
testsuites/sptests/spintrcritical07/init.c | 2 -
.../spintrcritical07/spintrcritical07.doc | 28 -
.../spintrcritical07/spintrcritical07.scn | 6 -
testsuites/sptests/spintrcritical08/init.c | 165 +-
.../spintrcritical08/spintrcritical08.scn | 30 +-
testsuites/sptests/spintrcritical09/init.c | 121 +-
.../spintrcritical09/spintrcritical09.scn | 28 +-
testsuites/sptests/spintrcritical10/init.c | 198 +-
.../spintrcritical10/spintrcritical10.scn | 33 +-
.../spintrcritical11/spintrcritical11.scn | 30 +-
.../spintrcritical11/spintrcritical11impl.h | 110 +-
.../spintrcritical12/spintrcritical12.scn | 30 +-
.../spintrcritical13/spintrcritical13.scn | 31 +-
.../spintrcritical13/spintrcritical13impl.h | 150 +-
.../spintrcritical14/spintrcritical14.scn | 31 +-
testsuites/sptests/spintrcritical15/init.c | 133 +-
.../spintrcritical15/spintrcritical15.scn | 34 +-
testsuites/sptests/spintrcritical16/init.c | 135 +-
.../spintrcritical16/spintrcritical16.scn | 31 +-
testsuites/sptests/spintrcritical18/init.c | 146 +-
.../spintrcritical18/spintrcritical18.scn | 30 +-
testsuites/sptests/spintrcritical20/init.c | 145 +-
.../spintrcritical20/spintrcritical20.scn | 32 +-
testsuites/sptests/spintrcritical21/init.c | 220 +-
.../spintrcritical21/spintrcritical21.scn | 27 +-
testsuites/sptests/spintrcritical21/system.h | 39 -
testsuites/sptests/spintrcritical22/init.c | 103 +-
.../spintrcritical22/spintrcritical22.scn | 20 +
testsuites/sptests/spintrcritical23/init.c | 117 +-
.../spintrcritical23/spintrcritical23.scn | 20 +
testsuites/sptests/spintrcritical24/init.c | 128 +-
.../spintrcritical24/spintrcritical24.scn | 32 +
.../spintrcritical_support/intrcritical.c | 171 -
.../spintrcritical_support/intrcritical.h | 52 -
testsuites/sptests/sptimecounter02/init.c | 2 +-
testsuites/sptests/sptimecounter03/init.c | 2 +-
testsuites/sptests/sptimecounter04/init.c | 2 +-
testsuites/support/include/buffer_test_io.h | 2 +-
testsuites/support/include/tmacros.h | 2 +-
testsuites/tmtests/tmfine01/init.c | 2 +-
testsuites/tmtests/tmonetoone/init.c | 2 +-
169 files changed, 10028 insertions(+), 4543 deletions(-)
create mode 100644 cpukit/include/rtems/doxygen-appl-config.h
create mode 100644 cpukit/include/rtems/simple-test.h
delete mode 100644 cpukit/include/t.h
create mode 100644 cpukit/libtest/t-test-busy-tick.c
create mode 100644 cpukit/libtest/t-test-busy.c
create mode 100644 cpukit/libtest/t-test-interrupt.c
create mode 100644 cpukit/libtest/t-test-rtems-posix-keys.c
create mode 100644 cpukit/libtest/t-test-rtems.h
create mode 100644 cpukit/libtest/testrun.c
create mode 100644 testsuites/libtests/ttest02/init.c
create mode 100644 testsuites/libtests/ttest02/ttest02.doc
create mode 100644 testsuites/libtests/ttest02/ttest02.scn
delete mode 100644 testsuites/sptests/spintrcritical06/init.c
delete mode 100644 testsuites/sptests/spintrcritical06/spintrcritical06.doc
delete mode 100644 testsuites/sptests/spintrcritical06/spintrcritical06.scn
delete mode 100644 testsuites/sptests/spintrcritical06/spintrcritical06impl.h
delete mode 100644 testsuites/sptests/spintrcritical07/init.c
delete mode 100644 testsuites/sptests/spintrcritical07/spintrcritical07.doc
delete mode 100644 testsuites/sptests/spintrcritical07/spintrcritical07.scn
delete mode 100644 testsuites/sptests/spintrcritical21/system.h
delete mode 100644 testsuites/sptests/spintrcritical_support/intrcritical.c
delete mode 100644 testsuites/sptests/spintrcritical_support/intrcritical.h
2.26.2
