[PATCH 32/33] spintrcritical24: Use T_interrupt_test()
Tue Jul 21 15:04:49 UTC 2020
 testsuites/sptests/Makefile.am                |   4 +-
 testsuites/sptests/spintrcritical24/init.c    | 128 +++++++++++++-----
 .../spintrcritical24/spintrcritical24.scn     |  32 +++++
 3 files changed, 125 insertions(+), 39 deletions(-)
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 14826811dc..5404ba4302 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1380,9 +1380,7 @@ if TEST_spintrcritical24
 sp_tests += spintrcritical24
 sp_screens += spintrcritical24/spintrcritical24.scn
 sp_docs += spintrcritical24/spintrcritical24.doc
-spintrcritical24_SOURCES = spintrcritical24/init.c \
-	spintrcritical_support/intrcritical.h \
-	spintrcritical_support/intrcritical.c
+spintrcritical24_SOURCES = spintrcritical24/init.c
 spintrcritical24_CPPFLAGS = $(AM_CPPFLAGS) \
 	$(TEST_FLAGS_spintrcritical24) $(support_includes) \
 	-I$(top_srcdir)/spintrcritical_support
diff --git a/testsuites/sptests/spintrcritical24/init.c b/testsuites/sptests/spintrcritical24/init.c
index 785ebacadd..d02fdcaebf 100644
--- a/testsuites/sptests/spintrcritical24/init.c
+++ b/testsuites/sptests/spintrcritical24/init.c
@@ -1,11 +1,5 @@
- * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
+ * Copyright (C) 2017, 2020 embedded brains GmbH (http://www.embedded-brains.de)
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
@@ -17,25 +11,29 @@
 #endif
 #include <sys/stat.h>
+#include <errno.h>
 #include <fcntl.h>
+#include <string.h>
 #include <unistd.h>
-#include <errno.h>
 #include <rtems/imfs.h>
-#include <tmacros.h>
-#include <intrcritical.h>
+#include <rtems/libio_.h>
+#include <rtems/simple-test.h>
+#include <rtems/test.h>
 const char rtems_test_name[] = "SPINTRCRITICAL 24";
 typedef struct {
   int fd;
+  rtems_libio_t *iop;
+  long early_count;
+  long late_count;
+  long potential_hit_count;
   long append_count;
   long no_append_count;
+  volatile bool closed;
 } test_context;
-static test_context test_instance;
 static const char path[] = "generic";
 static int handler_close(rtems_libio_t *iop)
@@ -43,6 +41,7 @@ static int handler_close(rtems_libio_t *iop)
   test_context *ctx;
   ctx = IMFS_generic_get_context_by_iop(iop);
+  ctx->closed = true;
   if (rtems_libio_iop_is_append(iop)) {
     ++ctx->append_count;
@@ -67,67 +66,126 @@ static const IMFS_node_control node_control = {
   .node_destroy = IMFS_node_destroy_default
-static void do_fcntl(rtems_id timer, void *arg)
+static T_interrupt_test_state interrupt(void *arg)
-  /* The arg is NULL */
   test_context *ctx;
+  T_interrupt_test_state state;
   int rv;
+  unsigned int flags;
+  state = T_interrupt_test_change_state(
+    T_INTERRUPT_TEST_ACTION,
-  ctx = &test_instance;
+  if (state != T_INTERRUPT_TEST_ACTION) {
+    return T_INTERRUPT_TEST_CONTINUE;
+  ctx = arg;
+  flags = rtems_libio_iop_flags_set(ctx->iop, 0);
+  if ((flags & LIBIO_FLAGS_OPEN) != 0) {
+    ++ctx->early_count;
+    state = T_INTERRUPT_TEST_EARLY;
+  } else if (ctx->closed) {
+    ++ctx->late_count;
+    state = T_INTERRUPT_TEST_LATE;
+  } else {
+    ++ctx->potential_hit_count;
+    if (ctx->potential_hit_count >= 13) {
+      state = T_INTERRUPT_TEST_DONE;
+    } else {
+      state = T_INTERRUPT_TEST_CONTINUE;
   rv = fcntl(ctx->fd, F_SETFL, O_APPEND);
   if (rv != 0) {
-    rtems_test_assert(rv == -1);
-    rtems_test_assert(errno == EBADF);
+    T_quiet_psx_error(rv, EBADF);
+  return state;
-static bool test_body(void *arg)
+static void prepare(void *arg)
   test_context *ctx;
-  int rv;
   ctx = arg;
   ctx->fd = open(path, O_RDWR);
-  rtems_test_assert(ctx->fd >= 0);
+  T_quiet_ge_int(ctx->fd, 0);
+  ctx->closed = false;
+  ctx->iop = rtems_libio_iop(ctx->fd);
+static void action(void *arg)
+  test_context *ctx;
+  int rv;
+  ctx = arg;
   rv = close(ctx->fd);
-  rtems_test_assert(rv == 0);
+  T_quiet_psx_success(rv);
-  return false;
+  do {
+    state = T_interrupt_test_get_state();
+  } while (state == T_INTERRUPT_TEST_ACTION);
-static void test(test_context *ctx)
+static const T_interrupt_test_config config = {
+  .prepare = prepare,
+  .action = action,
+  .interrupt = interrupt,
+  .max_iteration_count = 10000
+T_TEST_CASE(CloseInterrupt)
+  test_context ctx;
   const char *path = "generic";
   int rv;
+  memset(&ctx, 0, sizeof(ctx));
   rv = IMFS_make_generic_node(
     path,
     S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
     &node_control,
-    ctx
+    &ctx
+  T_psx_success(rv);
+  state = T_interrupt_test(&config, &ctx);
+  T_eq_int(state, T_INTERRUPT_TEST_DONE);
-  interrupt_critical_section_test(test_body, ctx, do_fcntl);
+  T_log(T_NORMAL, "early count = %ld", ctx.early_count);
+  T_log(T_NORMAL, "late count = %ld", ctx.late_count);
+  T_log(T_NORMAL, "potential hit count = %ld", ctx.potential_hit_count);
+  T_log(T_NORMAL, "append count = %ld", ctx.append_count);
+  T_log(T_NORMAL, "no append count = %ld", ctx.no_append_count);
   /* There is no reliable indicator if the test case has been hit */
-  rtems_test_assert(ctx->append_count > 0);
-  rtems_test_assert(ctx->no_append_count > 0);
+  T_gt_int(ctx.early_count, 0);
+  T_gt_int(ctx.late_count, 0);
+  T_gt_int(ctx.potential_hit_count, 0);
+  T_gt_int(ctx.append_count, 0);
+  T_gt_int(ctx.no_append_count, 0);
   rv = unlink(path);
 static void Init(rtems_task_argument arg)
-  TEST_BEGIN();
-  test(&test_instance);
-  TEST_END();
-  rtems_test_exit(0);
+  rtems_test_run(arg, TEST_STATE);
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
@@ -138,8 +196,6 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
 #define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/sptests/spintrcritical24/spintrcritical24.scn b/testsuites/sptests/spintrcritical24/spintrcritical24.scn
index 3f2eef3853..9022f5d6e4 100644
--- a/testsuites/sptests/spintrcritical24/spintrcritical24.scn
+++ b/testsuites/sptests/spintrcritical24/spintrcritical24.scn
@@ -1,2 +1,34 @@
 *** BEGIN OF TEST SPINTRCRITICAL 24 ***
+*** TEST VERSION: 6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+A:SPINTRCRITICAL 24
+S:Platform:RTEMS
+S:Compiler:10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+S:Version:6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:CloseInterrupt
+P:0:0:UI1:init.c:164
+P:1:0:UI1:init.c:167
+L:early count = 743
+L:late count = 805
+L:potential hit count = 13
+L:append count = 743
+L:no append count = 818
+P:2:0:UI1:init.c:176
+P:3:0:UI1:init.c:177
+P:4:0:UI1:init.c:178
+P:5:0:UI1:init.c:179
+P:6:0:UI1:init.c:180
+P:7:0:UI1:init.c:183
+E:CloseInterrupt:N:8:F:0:D:2.052931
+Z:SPINTRCRITICAL 24:C:1:N:8:F:0:D:2.054026
+Y:ReportHash:SHA256:950758e81490ad319486e6dc135fe5634bc9c9e7b19537346335e759f932fb56
 *** END OF TEST SPINTRCRITICAL 24 ***
2.26.2
