[PATCH 26/33] spintrcritical16: Use T_interrupt_test()
Tue Jul 21 15:04:43 UTC 2020
 testsuites/sptests/Makefile.am                |   4 +-
 testsuites/sptests/spintrcritical16/init.c    | 135 +++++++++++-------
 .../spintrcritical16/spintrcritical16.scn     |  31 +++-
 3 files changed, 109 insertions(+), 61 deletions(-)
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 0cf00f7fa6..136a8378b5 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1320,9 +1320,7 @@ if TEST_spintrcritical16
 sp_tests += spintrcritical16
 sp_screens += spintrcritical16/spintrcritical16.scn
 sp_docs += spintrcritical16/spintrcritical16.doc
-spintrcritical16_SOURCES = spintrcritical16/init.c \
-	spintrcritical_support/intrcritical.c \
-	spintrcritical_support/intrcritical.h
+spintrcritical16_SOURCES = spintrcritical16/init.c
 spintrcritical16_CPPFLAGS = $(AM_CPPFLAGS) \
 	$(TEST_FLAGS_spintrcritical16) $(support_includes) \
 	-I$(top_srcdir)/spintrcritical_support
diff --git a/testsuites/sptests/spintrcritical16/init.c b/testsuites/sptests/spintrcritical16/init.c
index 1879cbd189..f32776fe4a 100644
--- a/testsuites/sptests/spintrcritical16/init.c
+++ b/testsuites/sptests/spintrcritical16/init.c
@@ -1,4 +1,6 @@
+ *  Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
@@ -11,88 +13,121 @@
 #include "config.h"
 #endif
-#include <tmacros.h>
-#include <intrcritical.h>
+#include <rtems/test.h>
+#include <rtems/simple-test.h>
 const char rtems_test_name[] = "SPINTRCRITICAL 16";
-static Thread_Control *Main_TCB;
-static rtems_id Semaphore;
-static bool case_hit;
+typedef struct {
+  Thread_Control *thread;
+  rtems_id        semaphore;
+} test_context;
-static bool interrupts_blocking_op(void)
+static T_interrupt_test_state interrupt( void *arg )
-  Thread_Wait_flags flags = _Thread_Wait_flags_get( Main_TCB );
+  test_context *ctx;
+  T_interrupt_test_state state;
+  Thread_Wait_flags flags;
+  rtems_status_code sc;
-  return
-    flags == ( THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_INTEND_TO_BLOCK );
+  ctx = arg;
+  state = T_interrupt_test_change_state(
+    T_INTERRUPT_TEST_ACTION,
-static rtems_timer_service_routine test_release_from_isr(
-  rtems_id  timer,
-  void     *arg
-  if ( interrupts_blocking_op() ) {
-    case_hit = true;
-    (void) rtems_semaphore_release( Semaphore );
+  if (state != T_INTERRUPT_TEST_ACTION) {
+    return T_INTERRUPT_TEST_CONTINUE;
-  if ( Main_TCB->Wait.queue != NULL ) {
-    _Thread_Timeout( &Main_TCB->Timer.Watchdog );
+  flags = _Thread_Wait_flags_get( ctx->thread );
+  if (
+    flags == ( THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_INTEND_TO_BLOCK )
+    state = T_INTERRUPT_TEST_DONE;
+  } else if (
+    flags == ( THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_BLOCKED )
+    state = T_INTERRUPT_TEST_LATE;
+  } else {
+    state = T_INTERRUPT_TEST_EARLY;
+  sc = rtems_semaphore_release( ctx->semaphore );
+  T_quiet_rsc_success( sc );
+  return state;
-static bool test_body( void *arg )
+static void action( void *arg )
-  (void) arg;
+  ctx = arg;
+  sc = rtems_semaphore_obtain( ctx->semaphore, RTEMS_DEFAULT_OPTIONS, 2 );
+static void blocked( void *arg )
-  sc = rtems_semaphore_obtain( Semaphore, RTEMS_DEFAULT_OPTIONS, 2 );
-  rtems_test_assert( sc == RTEMS_SUCCESSFUL || sc == RTEMS_TIMEOUT );
+  ctx = arg;
+    T_INTERRUPT_TEST_LATE
-  return case_hit;
+  if ( state == T_INTERRUPT_TEST_ACTION ) {
-static rtems_task Init(
-  rtems_task_argument ignored
+static const T_interrupt_test_config config = {
+  .action = action,
+  .interrupt = interrupt,
+  .blocked = blocked,
+  .max_iteration_count = 10000
+ * Trying to generate timeout of a thread that had its blocking request
+ * satisfied while blocking but before time timeout.
+T_TEST_CASE( SemaphoreSatisfyBeforeTimeout )
-  rtems_status_code     sc;
+  test_context ctx;
-  TEST_BEGIN();
-  puts(
-    "Init - Trying to generate timeout of a thread that had its blocking\n"
-    "Init -   request satisfied while blocking but before time timeout"
+  ctx.thread = _Thread_Get_executing();
-  puts( "Init - rtems_semaphore_create - OK" );
   sc = rtems_semaphore_create(
     rtems_build_name( 'S', 'M', '1', ' ' ),
     0,
     RTEMS_DEFAULT_ATTRIBUTES,
     RTEMS_NO_PRIORITY,
-    &Semaphore
+    &ctx.semaphore
-  directive_failed( sc, "rtems_semaphore_create of SM1" );
-  Main_TCB  = _Thread_Get_executing();
+  T_assert_rsc_success( sc );
-  interrupt_critical_section_test( test_body, NULL, test_release_from_isr );
-  if ( case_hit ) {
-    puts( "Init - Case hit" );
-    TEST_END();
-  } else
-    puts( "Init - Case not hit - ran too long" );
+  state = T_interrupt_test( &config, &ctx );
+  T_eq_int( state, T_INTERRUPT_TEST_DONE );
+  sc = rtems_semaphore_delete( ctx.semaphore );
+  T_rsc_success( sc );
-  rtems_test_exit(0);
+static rtems_task Init( rtems_task_argument argument )
+  rtems_test_run( argument, TEST_STATE );
 /* configuration information */
@@ -101,9 +136,7 @@ static rtems_task Init(
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_MAXIMUM_TASKS          1
-#define CONFIGURE_MAXIMUM_TIMERS         1
 #define CONFIGURE_MAXIMUM_SEMAPHORES     1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
 #define CONFIGURE_MICROSECONDS_PER_TICK  1000
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/sptests/spintrcritical16/spintrcritical16.scn b/testsuites/sptests/spintrcritical16/spintrcritical16.scn
index 49e6597047..aeb8946788 100644
--- a/testsuites/sptests/spintrcritical16/spintrcritical16.scn
+++ b/testsuites/sptests/spintrcritical16/spintrcritical16.scn
@@ -1,7 +1,24 @@
-*** TEST INTERRUPT CRITICAL SECTION 16 ***
-Init - Trying to generate timeout of a thread that had its blocking
-Init -   request satisfied while blocking but before time timeout
-Init - rtems_semaphore_create - OK
-Support - rtems_timer_create - creating timer 1
-Init - Case hit
-*** END OF TEST INTERRUPT CRITICAL SECTION 16 ***
+*** BEGIN OF TEST SPINTRCRITICAL 16 ***
+*** TEST VERSION: 6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+A:SPINTRCRITICAL 16
+S:Platform:RTEMS
+S:Compiler:10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+S:Version:6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:SemaphoreSatisfyBeforeTimeout
+P:0:0:UI1:init.c:119
+P:1:0:UI1:init.c:122
+P:2:0:UI1:init.c:125
+E:SemaphoreSatisfyBeforeTimeout:N:3:F:0:D:0.058378
+Z:SPINTRCRITICAL 16:C:1:N:3:F:0:D:0.059654
+Y:ReportHash:SHA256:c1e358e47313edf10cbf9e1aef2cdd06ce96bc85c69d109e3494b4d1e0880f8f
+*** END OF TEST SPINTRCRITICAL 16 ***
2.26.2
