[GSoC 2020]: Weekly thread: Preparing RSB recipies for EPICS
Mritunjay Sharma mritunjaysharma394 at gmail.com
Tue Jul 21 20:16:34 UTC 2020
I cancelled the earlier message because the log file size was very big
and could not be posted in the devel list.
[UPDATE]: Applying PATCH for RTEMS-pc386 support to EPICS and
making other changes in code worked and EPICS7 was successfully built
and installed using the RSB recipe.
Tha changes that made it work:
diff --git a/rtems/config/epics/epics-7-1.cfg
b/rtems/config/epics/epics-7-1.cfg
new file mode 100644
index 00000000..ed1f768b
--- /dev/null
+++ b/rtems/config/epics/epics-7-1.cfg
@@ -0,0 +1,28 @@
+# EPICS 3afec267ab08568ea454789e562450b00feea5c0
+%if %{release} == %{nil}
+ %define release 1
+%endif
+#%include %{_configdir}/rtems-bsp.cfg
+# EPICS Version
+%define epics_version 3afec267ab08568ea454789e562450b00feea5c0
+#%hash sha512 epics-%{ntp_version}.tar.gz
8d76fc7e92b2ea6dd5031e6030a7aba4ff6fb3e19d3bc0153852509861be5d0960e70604814163caedb81f8315a451d78371f99634a50b55cfe1cbd2c69e3046
+# Patch for RTEMS support.
+%patch add epics -p1
file:///home/mritunjay/development/rtems/src/rsb_GSoC/rtems/patches/0001-Added-Support-for-RTEMS-pc386.patch
+#%hash  sha512 rtems-ntp-4.2.6p5.diff
257223d207d0b77cde2b9d7add22e3b9d657b58998411d2e20d0b1adf36910be21f1277386c54c34f5d9616fccd29f721d007295708047ea7ae0270a00be25a0
+# EPICS Build configuration
+%include %{_configdir}/epics-7-1.cfg
diff --git a/rtems/config/epics/epics-base.bset
b/rtems/config/epics/epics-base.bset
index 00000000..550daad0
--- /dev/null
+++ b/rtems/config/epics/epics-base.bset
@@ -0,0 +1,26 @@
+# Build set for EPICS
+%define release 1
+# RTEMS Version
+%define rtems_version 5
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# The RTEMS Package defines
+%include rtems-package.bset
+# Build EPICS.
+epics/epics-7-1.cfg
\ No newline at end of file
diff --git a/source-builder/config/epics-7-1.cfg
b/source-builder/config/epics-7-1.cfg
index ea25f284..b18f62bd 100644
--- a/source-builder/config/epics-7-1.cfg
+++ b/source-builder/config/epics-7-1.cfg
@@ -31,6 +31,7 @@ URL:  https://epics.mpg.de/
   source_dir_epics="epicsBaseOwnPlayground-%{epics_version}"
   %source setup epics -q -n epicsBaseOwnPlayground-%{epics_version}
+  %patch setup epics -p1
   cd ${build_top}
@@ -43,10 +44,7 @@ URL:  https://epics.mpg.de/
   %{__make} PREFIX=%{_prefix}
-  ./configure \
-    --prefix=%{_prefix}
-  %{__make} %{?_smp_mflags}
+  #%{__make} %{?_smp_mflags}
   cd ${build_top}
The changes can also be looked here:
https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support?expand=1
On Tue, Jul 21, 2020 at 10:23 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Jul 21, 2020 at 10:42 AM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> > [UPDATE]: The error was actually a mismatch of names which was fixed
> with the following
> > changes:
> > index fe1fb458..ea25f284 100644
> > @@ -10,7 +10,7 @@
> > -Name:      epics-%{epics_version}-%{_host}-%{release}
> > +Name:      epicsBaseOwnPlayground-%{epics_version}-%{_host}-%{release}
> >  Summary:   EPICS v%{epics_version} for target %{_target} on host
> %{_host}
> >  Version:   %{epics_version}
> >  Release:   %{release}
> > @@ -19,7 +19,8 @@ URL:  https://epics.mpg.de/
> >  # Source
> > -%source set epics --rsb-file=epics-%{epics_version}.zip
> https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.zip
> > +%source set epics
> --rsb-file=epicsBaseOwnPlayground-%{epics_version}.tar.gz
> https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.tar.gz
> >  # Prepare the source code.
> > @@ -27,25 +28,20 @@ URL:  https://epics.mpg.de/
> >  %prep
> >    build_top=$(pwd)
> > -  source_dir_epics="epics-%{epics_version}"
> > +  source_dir_epics="epicsBaseOwnPlayground-%{epics_version}"
> > -  %source setup epics -q -n epics-%{epics_version}
> > +  %source setup epics -q -n epicsBaseOwnPlayground-%{epics_version}
> We will eventually want this to work from the upstream EPICS.
Yes, I think we need to discuss it with Heinz when he is available.
> >    cd ${build_top}
> >  %build
> >    build_top=$(pwd)
> > -  %{build_directory}
> > -  mkdir -p ${build_dir}
> > -  cd ${build_dir}
> > +  cd ${source_dir_epics}
> > -  %{host_build_flags}
> > +  %{build_build_flags}
> > -  #cd ${source_dir_epics}
> > +  %{__make} PREFIX=%{_prefix}
> >    ./configure \
> >      --prefix=%{_prefix}
> > After this, I ran the command
> > `../source-builder/sb-builder --prefix=/home/mritunjay/development
> --log=log_epics epics-7-1 --trace`
> > again. The error that has come now was expected because the changes I
> made in epicsBaseOwnPlayground/configure file
> > were done manually and here it has to be done through a script. The
> changes that I did manually were;
> >> in epics-base/configure/CONFIG_SITE
> >> set
> >> CROSS_COMPILER_TARGET_ARCHS=
> >    What I entered:
> >    CROSS_COMPILER_TARGET_ARCHS=  RTEMS-pc386-qemu
> >> e.g. RTEMS-pc386
> >> or RTEMS-xilinx_zynq_a9_qemu
> >> in epics-base/configure/os there must be a file for the target used,
> >> e.g.
> >> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
> >> or
> >> CONFIG.Common.RTEMS-pc386
> > Checked.  CONFIG.Common.RTEMS-pc386 was there
> >> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
> >> where to find RTEMS:
> >> # Where to find RTEMS
> >> # APS:
> >> #RTEMS_VERSION = 4.10.2
> >> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
> > In my system, I entered this:
> > #FHI
> > RTEMS_VERSION = 5
> > RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)
> > I have a doubt on how to implement the above changes in the
> `source-builder/config/epics-7-1.cfg` to make it work.
> > Do we have to write a patch? And what will be the best way to do it?
> This is a good question. These configuration changes need to be
> populated somehow based on the target being built. If this is only
> doable by writing files directly, then we'll probably need a way to
> apply patches for each different target. This seems unwieldy, so
> further thought should be considered on how to configure EPICS based
> on the RTEMS BSP build.
> You can start with a manually-created patch file, but eventually we
> need something that can be used across different BSPs / architectures.
The manually-created patch file has worked.
Now, what can be done to make it work across different BSPs / architectures?
Will writing similar patches for each architecture should be our way?
And I guess in the #FHI section as well we have to do something so that
user
can add the path interactively where the user's BSP are installed?
Would you like to give any other feedback/suggestions?
Thanks
Mritunjay
> > The latest error looks somewhat like this which is because I have to
> change the configurations in epics directory.
> > The question is how to accomplish it through the script.
> > ../../configure/os/CONFIG.Common.RTEMS:36:
> /Users/junkes/MVME6100/RTEMS/rtems-5/powerpc-rtems5/beatnik/Makefile.inc:
> No such file or directory
> > Thanks
> > Mritunjay
> > On Tue, Jul 21, 2020 at 4:09 AM Mritunjay Sharma <
> >> Hello all,
> >> I went through the
> https://docs.rtems.org/branches/master/user/rsb/index.html
> >> and started writing a recipe for building EPICS 7.
> >> The code is based on a very raw idea just now and
> >> so was expected to give errors.
> >> The code can be found here:
> https://github.com/mritunjaysharma394/rtems-source-builder/blob/epics-support/source-builder/config/epics-7-1.cfg
> >> After this, just to check, what errors it might gave,
> >> I ran the following command:
> >> This gave me the following error:
> >> `+ cd epics-3afec267ab08568ea454789e562450b00feea5c0
> /home/mritunjay/development/rtems/src/rsb_GSoC/rtems/build/epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1/do-build:
> 90: cd: can't cd to epics-3afec267ab08568ea454789e562450b00feea5c0
> >> shell cmd failed: /bin/sh -ex
> >> error: building
> epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1`
> >> I think there seems to be some problem with naming the directory.
> >> I request you all to kindly help with the error as well as please check
> the code
> >> to see if I am on the right path.
> >> I am attaching the log and trace file as well.
> >> Thanks,
> >> Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200722/902458ca/attachment-0001.html>
