[PATCH v2] eng: Update test framework chapter
Sebastian Huber
Wed Jul 22 09:21:19 UTC 2020
Document the dynamic text fixtures, utility functions, and the interrupt
test support. Reorder some sections and reword some paragraphs based on
review comments.
Update #3199.
v2:
Address review comments. I updated:
https://ftp.rtems.org/pub/rtems/people/sebh/eng2.pdf
eng/index.rst | 4 +-
eng/test-framework.rst | 412 +++++++++++++++++++++++++---------
images/eng/interrupt-test.odg | Bin 0 -> 14829 bytes
images/eng/interrupt-test.pdf | Bin 0 -> 14153 bytes
images/eng/interrupt-test.png | Bin 0 -> 75272 bytes
5 files changed, 313 insertions(+), 103 deletions(-)
create mode 100644 images/eng/interrupt-test.odg
create mode 100644 images/eng/interrupt-test.pdf
create mode 100644 images/eng/interrupt-test.png
diff --git a/eng/index.rst b/eng/index.rst
index 8f91c5e..f6b02ec 100644
--- a/eng/index.rst
+++ b/eng/index.rst
@@ -11,8 +11,8 @@ RTEMS Software Engineering (|version|)
.. topic:: Copyrights and License
- | |copy| 2018, 2019 embedded brains GmbH
- | |copy| 2018, 2019 Sebastian Huber
+ | |copy| 2018, 2020 embedded brains GmbH
+ | |copy| 2018, 2020 Sebastian Huber
| |copy| 1988, 2015 On-Line Applications Research Corporation (OAR)
.. include:: ../common/license.rst
diff --git a/eng/test-framework.rst b/eng/test-framework.rst
index b6411b5..45db446 100644
--- a/eng/test-framework.rst
+++ b/eng/test-framework.rst
@@ -1,7 +1,7 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2018, 2019 embedded brains GmbH
-.. Copyright (C) 2018, 2019 Sebastian Huber
+.. Copyright (C) 2018, 2020 embedded brains GmbH
+.. Copyright (C) 2018, 2020 Sebastian Huber
Software Test Framework
@@ -16,6 +16,8 @@ features:
* Implemented in standard C11
+* Tests can be written in C or C++
* Runs on at least FreeBSD, MSYS2, Linux and RTEMS
* Test runner and test case code can be in separate translation units
@@ -67,11 +69,11 @@ A `test suite` is a collection of test cases. A `test case` consists of
individual test actions and checks. A `test check` determines if the outcome
of a test action meets its expectation. A `test action` is a program sequence
with an observable outcome, for example a function invocation with a return
-status. If the test action outcome is all right, then the test check passes,
-otherwise the test check fails. The test check failures of a test case are
-summed up. A test case passes, if the failure count of this test case is zero,
-otherwise the test case fails. The test suite passes if all test cases pass,
-otherwise it fails.
+status. If a test action produces the expected outcome as determined by the
+corresponding test check, then this test check passes, otherwise this test
+check fails. The test check failures of a test case are summed up. A test
+case passes, if the failure count of this test case is zero, otherwise the test
+case fails. The test suite passes if all test cases pass, otherwise it fails.
Test Cases
@@ -89,7 +91,7 @@ body:
The test case `name` must be a valid C designator. The test case names must be
unique within the test suite. Just link modules with test cases to the test
runner to form a test suite. The test cases are automatically registered via
-static constructors.
+static C constructors.
.. code-block:: c
:caption: Test Case Example
@@ -144,13 +146,43 @@ macro followed by a function body:
unique within the test suite. The `fixture` must point to a statically
-initialized read-only object of type `T_fixture`. The test fixture
-provides methods to setup, stop and tear down a test case. A context is passed
-to the methods. The initial context is defined by the read-only fixture
-object. The context can be obtained by the `T_fixture_context()`
-function. It can be set within the scope of one test case by the
-`T_set_fixture_context()` function. This can be used for example to
-dynamically allocate a test environment in the setup method.
+initialized read-only object of type `T_fixture`.
+.. code-block:: c
+ typedef struct T_fixture {
+ void (*setup)(void *context);
+ void (*stop)(void *context);
+ void (*teardown)(void *context);
+ void (*scope)(void *context, char *buffer, size_t size);
+ void *initial_context;
+ } T_fixture;
+The test fixture provides methods to setup, stop, and teardown a test case as
+well as the scope for log messages. A context is passed to each of the
+methods. The initial context is defined by the read-only fixture object. The
+context can be obtained by the `T_fixture_context()` function. The context can
+be changed within the scope of one test case by the `T_set_fixture_context()`
+function. The next test case execution using the same fixture will start again
+with the initial context defined by the read-only fixture object. Setting the
+context can be used for example to dynamically allocate a test environment in
+the setup method.
+The test case fixtures of a test case are organized as a stack. Fixtures can
+be dynamically added to a test case and removed from a test case via the
+`T_push_fixture()` and `T_pop_fixture()` functions.
+.. code-block:: c
+ void *T_push_fixture(T_fixture_node *node, const T_fixture *fixture);
+ void T_pop_fixture(void);
+The `T_push_fixture()` function needs an uninitialized fixture node which must
+exist until `T_pop_fixture()` is called. It returns the initial context of the
+fixture. At the end of a test case all pushed fixtures are popped
+automatically. A call of `T_pop_fixture()` invokes the teardown method of the
+fixture and must correspond to a previous call to `T_push_fixture()`.
.. code-block:: c
:caption: Test Fixture Example
@@ -237,9 +269,9 @@ dynamically allocate a test environment in the setup method.
Test Case Planning
-Each non-quiet test check fetches and increments the test step counter
-atomically. For each test case execution the planned steps can be specified
-with the `T_plan()` function.
+A non-quiet test check fetches and increments the test step counter atomically.
+For each test case execution the planned steps can be specified with the
+`T_plan()` function.
.. code-block:: c
@@ -318,7 +350,7 @@ execution follows exactly the planned steps.
Test Case Resource Accounting
-The framework can check if various resources are leaked during a test case
+The framework can check if various resources have leaked during a test case
execution. The resource checkers are specified by the test run configuration.
On RTEMS, checks for the following resources are available
@@ -452,13 +484,14 @@ test case execution. You can provide an optional destroy function to
Test Case Destructors
-You can add test case destructors with `T_add_destructor()`. They are called
-automatically at the test case end before the resource accounting takes place.
-Optionally, a registered destructor can be removed before the test case end
-with `T_remove_destructor()`. The `T_destructor` structure of a destructor
-must exist after the return from the test case body. Do not use stack memory
-or dynamic memory obtained via `T_malloc()`, `T_calloc()` or `T_zalloc()` for
-the `T_destructor` structure.
+You can add test case destructors with `T_add_destructor()`. The destructors
+are called automatically at the test case end before the resource accounting
+takes place. Optionally, a registered destructor can be removed before the
+test case end with `T_remove_destructor()`. The `T_destructor` structure of a
+destructor must exist after the return from the test case body. It is
+recommended to use statically allocated memory. Do not use stack memory or
+dynamic memory obtained via `T_malloc()`, `T_calloc()` or `T_zalloc()` for the
+`T_destructor` structure.
.. code-block:: c
@@ -497,16 +530,31 @@ the `T_destructor` structure.
Test Checks
-A `test check` determines if the actual value presented to the test check meets
-its expectation. The actual value should represent the outcome of a test
-action. If the actual value is all right, then the test check passes,
-otherwise the test check fails. A failed test check does not stop the test
-case execution immediately unless the `T_assert_*()` test variant is used.
-Each test check increments the test step counter unless the `T_quiet_*()` test
-variant is used. The test step counter is initialized to zero before the test
-case begins to execute. The `T_step_*(step, ...)` test check variants verify
-that the test step counter is equal to the planned test step value, otherwise
-the test check fails.
+A `test check` determines if the actual value presented to the test check has
+the expected properties. The actual value should represent the outcome of a
+test action. If a test action produces the expected outcome as determined by
+the corresponding test check, then this test check passes, otherwise this test
+check fails. A failed test check does not stop the test case execution
+immediately unless the `T_assert_*()` test variant is used. Each test check
+increments the test step counter unless the `T_quiet_*()` test variant is used.
+The test step counter is initialized to zero before the test case begins to
+execute. The `T_step_*(step, ...)` test check variants verify that the test
+step counter is equal to the planned test step value, otherwise the test check
+fails.
+Test Check Variant Conventions
+The `T_quiet_*()` test check variants do not increment the test step counter
+and only print a message if the test check fails. This is helpful in case a
+test check appears in a tight loop.
+The `T_step_*(step, ...)` test check variants check in addition that the test
+step counter is equal to the specified test step value, otherwise the test
+check fails.
+The `T_assert_*()` and `T_step_assert_*(step, ...)` test check variants stop
+the current test case execution if the test check fails.
Test Check Parameter Conventions
@@ -557,21 +605,10 @@ lt
If the actual value satisfies the test check condition, then the test check
passes, otherwise it fails.
-Test Check Variant Conventions
-The `T_quiet_*()` test check variants do not increment the test step counter
-and only print a message if the test check fails. This is helpful in case a
-test check appears in a tight loop.
-The `T_step_*(step, ...)` test check variants check in addition that the test
-step counter is equal to the specified test step value, otherwise the test
-check fails.
-The `T_assert_*()` and `T_step_assert_*(step, ...)` test check variants stop
-the current test case execution if the test check fails.
+Test Check Type Conventions
-The following names for test check type variants are used:
+The following names for test check types are used:
ptr
The test value must be a pointer (`void *`).
@@ -654,6 +691,57 @@ ssz
sz
The test value must be of type `size_t`.
+Integers
+Let `xyz` be the type variant which shall be one of `schar`, `uchar`, `short`,
+`ushort`, `int`, `uint`, `long`, `ulong`, `ll`, `ull`, `i8`, `u8`, `i16`,
+`u16`, `i32`, `u32`, `i64`, `u64`, `iptr`, `uptr`, `ssz`, and `sz`.
+Let `I` be the type name which shall be compatible to the type variant.
+The following test checks for integers are available:
+.. code-block:: c
+ void T_eq_xyz(I a, I e);
+ void T_assert_eq_xyz(I a, I e);
+ void T_quiet_eq_xyz(I a, I e);
+ void T_step_eq_xyz(unsigned int step, I a, I e);
+ void T_step_assert_eq_xyz(unsigned int step, I a, I e);
+ void T_ne_xyz(I a, I e);
+ void T_assert_ne_xyz(I a, I e);
+ void T_quiet_ne_xyz(I a, I e);
+ void T_step_ne_xyz(unsigned int step, I a, I e);
+ void T_step_assert_ne_xyz(unsigned int step, I a, I e);
+ void T_ge_xyz(I a, I e);
+ void T_assert_ge_xyz(I a, I e);
+ void T_quiet_ge_xyz(I a, I e);
+ void T_step_ge_xyz(unsigned int step, I a, I e);
+ void T_step_assert_ge_xyz(unsigned int step, I a, I e);
+ void T_gt_xyz(I a, I e);
+ void T_assert_gt_xyz(I a, I e);
+ void T_quiet_gt_xyz(I a, I e);
+ void T_step_gt_xyz(unsigned int step, I a, I e);
+ void T_step_assert_gt_xyz(unsigned int step, I a, I e);
+ void T_le_xyz(I a, I e);
+ void T_assert_le_xyz(I a, I e);
+ void T_quiet_le_xyz(I a, I e);
+ void T_step_le_xyz(unsigned int step, I a, I e);
+ void T_step_assert_le_xyz(unsigned int step, I a, I e);
+ void T_lt_xyz(I a, I e);
+ void T_assert_lt_xyz(I a, I e);
+ void T_quiet_lt_xyz(I a, I e);
+ void T_step_lt_xyz(unsigned int step, I a, I e);
+ void T_step_assert_lt_xyz(unsigned int step, I a, I e);
+An automatically generated message is printed in case the test check fails.
Boolean Expressions
@@ -838,57 +926,6 @@ The following test checks for characters (`char`) are available:
-Integers
-The following test checks for integers are available:
-.. code-block:: c
- void T_eq_xyz(I a, I e);
- void T_assert_eq_xyz(I a, I e);
- void T_quiet_eq_xyz(I a, I e);
- void T_step_eq_xyz(unsigned int step, I a, I e);
- void T_step_assert_eq_xyz(unsigned int step, I a, I e);
- void T_ne_xyz(I a, I e);
- void T_assert_ne_xyz(I a, I e);
- void T_quiet_ne_xyz(I a, I e);
- void T_step_ne_xyz(unsigned int step, I a, I e);
- void T_step_assert_ne_xyz(unsigned int step, I a, I e);
- void T_ge_xyz(I a, I e);
- void T_assert_ge_xyz(I a, I e);
- void T_quiet_ge_xyz(I a, I e);
- void T_step_ge_xyz(unsigned int step, I a, I e);
- void T_step_assert_ge_xyz(unsigned int step, I a, I e);
- void T_gt_xyz(I a, I e);
- void T_assert_gt_xyz(I a, I e);
- void T_quiet_gt_xyz(I a, I e);
- void T_step_gt_xyz(unsigned int step, I a, I e);
- void T_step_assert_gt_xyz(unsigned int step, I a, I e);
- void T_le_xyz(I a, I e);
- void T_assert_le_xyz(I a, I e);
- void T_quiet_le_xyz(I a, I e);
- void T_step_le_xyz(unsigned int step, I a, I e);
- void T_step_assert_le_xyz(unsigned int step, I a, I e);
- void T_lt_xyz(I a, I e);
- void T_assert_lt_xyz(I a, I e);
- void T_quiet_lt_xyz(I a, I e);
- void T_step_lt_xyz(unsigned int step, I a, I e);
- void T_step_assert_lt_xyz(unsigned int step, I a, I e);
-The type variant `xyz` must be `schar`, `uchar`, `short`, `ushort`, `int`,
-`uint`, `long`, `ulong`, `ll`, `ull`, `i8`, `u8`, `i16`, `u16`, `i32`, `u32`,
-`i64`, `u64`, `iptr`, `uptr`, `ssz`, or `sz`.
-The type name `I` must be compatible to the type variant.
-An automatically generated message is printed in case the test check fails.
RTEMS Status Codes
@@ -1028,6 +1065,35 @@ RTEMS, floating-point operations are only supported in special tasks and may be
forbidden in interrupt context. The formatted output functions provided by the
test framework work in every context.
+Utility
+You can stop a test case via the ``T_stop()`` function. This function does not
+return. You can indicate unreachable code paths with the ``T_unreachable()``
+function. If this function is called, then the test case stops.
+You can busy wait with the ``T_busy()`` function:
+.. code-block:: c
+ void T_busy(uint_fast32_t count);
+It performs a busy loop with the specified iteration count. This function is
+optimized to not perform memory accesses and should have a small jitter. The
+loop iterations have a processor-specific duration.
+You can get an iteration count for the ``T_busy()`` function which corresponds
+roughly to one clock tick interval with the ``T_get_one_clock_tick_busy()``
+function:
+.. code-block:: c
+ uint_fast32_t T_get_one_clock_tick_busy(void);
+This function requires a clock driver. It must be called from thread context
+with interrupts enabled. It may return a different value each time it is
+called.
Time Services
@@ -1353,6 +1419,150 @@ reported.
M:E:Empty:D:0.015188063
E:measure_empty:N:1:F:0:D:14.284869
+Interrupt Tests
+In the operating system implementation you may have two kinds of critical
+sections. Firstly, there are low-level critical sections protected by
+interrupts disabled and maybe also some SMP spin lock. Secondly, there are
+high-level critical sections which are protected by disabled thread
+dispatching. The high-level critical sections may contain several low-level
+critical sections. Between these low-level critical sections interrupts may
+happen which could alter the code path taken in the high-level critical
+section.
+The test framework provides support to write test cases for high-level critical
+sections though the `T_interrupt_test()` function:
+.. code-block:: c
+ typedef enum {
+ T_INTERRUPT_TEST_INITIAL,
+ T_INTERRUPT_TEST_ACTION,
+ T_INTERRUPT_TEST_BLOCKED,
+ T_INTERRUPT_TEST_CONTINUE,
+ T_INTERRUPT_TEST_DONE,
+ T_INTERRUPT_TEST_EARLY,
+ T_INTERRUPT_TEST_INTERRUPT,
+ T_INTERRUPT_TEST_LATE,
+ T_INTERRUPT_TEST_TIMEOUT
+ } T_interrupt_test_state;
+ typedef struct {
+ void (*prepare)(void *arg);
+ void (*action)(void *arg);
+ T_interrupt_test_state (*interrupt)(void *arg);
+ void (*blocked)(void *arg);
+ uint32_t max_iteration_count;
+ } T_interrupt_test_config;
+ T_interrupt_test_state T_interrupt_test(
+ const T_interrupt_test_config *config,
+ void *arg
+This function returns ``T_INTERRUPT_TEST_DONE`` if the test condition was
+satisfied within the maximum iteration count, otherwise it returns
+``T_INTERRUPT_TEST_TIMEOUT``. The interrupt test run uses the specified
+configuration and passes the specified argument to all configured handlers.
+The function shall be called from thread context with interrupts enabled.
+.. image:: ../images/eng/interrupt-test.*
+ :scale: 60
+ :align: center
+The interrupt test uses an *adaptive bisection algorithm* to try to hit the
+code section under test by an interrupt. In each test iteration, it waits for
+a time point one quarter of the clock tick interval after a clock tick using
+the monotonic clock. Then it performs a busy wait using ``T_busy()`` with a
+busy count controlled by the adaptive bisection algorithm. The test maintains
+a sample set of upper and lower bound busy wait count values. Initially, the
+lower bound values are zero and the upper bound values are set to a value
+returned by ``T_get_one_clock_tick_busy()``. The busy wait count for an
+iteration is set to the middle point between the arithmetic mean of the lower
+and upper bound sample values. After the action handler returns, the set of
+lower and upper bound sample values is updated based on the test state. If the
+test state is ``T_INTERRUPT_TEST_EARLY``, then the oldest upper bound sample is
+replaced by the busy wait count used to delay the action and the latest lower
+bound sample value is slightly decreased. Reducing the lower bound helps to
+avoid a zero length interval between the upper and lower bounds. If the test
+state is ``T_INTERRUPT_TEST_LATE``, then the oldest lower bound sample is
+replaced by the busy wait count used to delay the action and the latest upper
+bound sample value is slightly increased. In all other test states the timing
+values remain as is. Using the arithmetic mean of a sample set dampens the
+effect of each test iteration and is an heuristic to mitigate the influence of
+jitters in the action code execution.
+The optional *prepare* handler should prepare the system so that the *action*
+handler can be called. It is called in a tight loop, so all the time consuming
+setup should be done before ``T_interrupt_test()`` is called. During the
+preparation the test state is ``T_INTERRUPT_TEST_INITIAL``. The preparation
+handler shall not change the test state.
+The *action* handler should call the function which executes the code section
+under test. The execution path up to the code section under test should have a
+low jitter. Otherwise, the adaptive bisection algorithm may not find the right
+spot.
+The *interrupt* handler should check if the test condition is satisfied or a
+new iteration is necessary. This handler is called in interrupt context. It
+shall return ``T_INTERRUPT_TEST_DONE`` if the test condition is satisfied and
+the test run is done. It shall return ``T_INTERRUPT_TEST_EARLY`` if the
+interrupt happened too early to satisfy the test condition. It shall return
+``T_INTERRUPT_TEST_LATE`` if the interrupt happened too late to satisfy the
+test condition. It shall return ``T_INTERRUPT_TEST_CONTINUE`` if the test
+should continue with the current timing settings. Other states shall not be
+returned. It is critical to return the early and late states if the test
+condition was not satisfied, otherwise the adaptive bisection algorithm may not
+work. The returned state is used to try to change the test state from
+``T_INTERRUPT_TEST_ACTION`` to the returned state.
+The optional *blocked* handler is invoked if the executing thread blocks during
+the action processing. It should remove the blocking condition of the thread
+so that the next iteration can start. It can use
+``T_interrupt_change_state()`` to change the interrupt test state.
+The *max iteration count* configuration member defines the maximum iteration
+count of the test loop. If the maximum iteration count is reached before the
+test condition is satisfied, then ``T_interrupt_test()`` returns
+The *interrupt* and *blocked* handlers may be called in arbitrary test states.
+The *action*, *interrupt*, and *blocked* handlers can use
+``T_interrupt_test_get_state()`` to get the current test state:
+.. code-block:: c
+ T_interrupt_test_state T_interrupt_test_get_state(void);
+``T_interrupt_test_change_state()`` to try to change the test state from an
+expected state to a desired state:
+.. code-block:: c
+ T_interrupt_test_state T_interrupt_test_change_state(
+ T_interrupt_test_state expected_state,
+ T_interrupt_test_state desired_state
+The function returns the previous state. If it **differs from the expected
+state**, then the requested state **change to the desired state did not take
+place**. In an SMP configuration, do not call this function in a tight loop.
+It could lock up the test run. To busy wait for a state change, use
+``T_interrupt_test_get_state()``.
+The *action* handler can use ``T_interrupt_test_busy_wait_for_interrupt()`` to
+busy wait for the interrupt:
+.. code-block:: c
+ void T_interrupt_test_busy_wait_for_interrupt(void);
+This is useful if the action code does not block to wait for the interrupt. If
+the action handler just returns the test code immediately prepares the next
+iteration and may miss an interrupt which happens too late.
Test Runner
2.26.2
