Doubt regarding thread creation in RTEMS
Richi Dubey richidubey at gmail.com
Thu Jul 23 11:10:54 UTC 2020
Thank you for the clarification.
On Thu, Jul 23, 2020 at 12:25 PM Sebastian Huber <
> On 23/07/2020 08:12, Richi Dubey wrote:
> > I am still having a hard time understanding this. What do you mean by
> > no code which blocks? Does the thread which executes our task (Say a
> > function Loop with 30k loops) block? What does block mean here?
> Block means here that the thread calls _Scheduler_Block(). If it
> executes an infinite loop, then it does NOT block. Actually, the default
> implementation of an idle thread body is:
> void *_CPU_Thread_Idle_body( uintptr_t ignored )
>    while ( true ) {
>      /* Do nothing */
>    return NULL;
> On most targets, it is an infinite loop which executes a some code which
> puts the processor in a low-power mode.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200723/e6a81ff4/attachment-0001.html>
