Strong APA Scheduler : First Draft
Andrew Butterfield
Andrew.Butterfield at scss.tcd.ie
Thu Jul 23 14:58:58 UTC 2020
Hi Richi,
a quick answer to 1 below
> On 23 Jul 2020, at 15:20, Richi Dubey <richidubey at gmail.com> wrote:
> 1)Both the algorithms require the use of a FIFO Queue to support the insert and dequeue operations.
> I believe we can use chains and use the chain_append() and combination of _Chain_Extract and _Chain_First or just _Chain_First and node->next to achieve the FIFO requirements.
You might want to look at chain_get() - it removes the first element, so does a FIFO protocol in tandem with chain_append()
Regards,
Andrew
> devel mailing list
> devel at rtems.org
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/
