[PATCH 2/2] malloc: Make deferred free support optional
Gedare Bloom
gedare at rtems.org
Thu Jul 23 17:19:48 UTC 2020
looks good, other than my comment on 1/2.
On Thu, Jul 23, 2020 at 6:21 AM Sebastian Huber
> Only include the deferred free support if free() is actually used by the
> application.
> The free() implementation in RTEMS supports that allocated memory is
> freed in interrupt context. Since the heap is protected by a mutex, the
> frees issued in interrupt context cannot immediately be freed to the
> heap, instead they are placed on a deferred free list. This list is
> emptied by the core allocation function
> rtems_heap_allocate_aligned_with_boundary(). This adds a dependency to
> free() in rtems_heap_allocate_aligned_with_boundary(). In order to
> better support applications which only allocate memory and never free
> it, this dependency should be avoided. Provide a weak default
> implementation of _Malloc_Process_deferred_frees() for
> rtems_heap_allocate_aligned_with_boundary(). In the free() module
> provide the strong implementation.
> Update #4032.
> cpukit/libcsupport/src/free.c | 43 ++++++++++++++++++++++++
> cpukit/libcsupport/src/malloc_deferred.c | 40 ++--------------------
> cpukit/libcsupport/src/malloc_p.h | 2 --
> 3 files changed, 46 insertions(+), 39 deletions(-)
> diff --git a/cpukit/libcsupport/src/free.c b/cpukit/libcsupport/src/free.c
> index f4542e0c72..9f7c577852 100644
> --- a/cpukit/libcsupport/src/free.c
> +++ b/cpukit/libcsupport/src/free.c
> @@ -23,6 +23,49 @@
> #include "malloc_p.h"
> #include <stdlib.h>
> +#include <rtems/chain.h>
> +static RTEMS_CHAIN_DEFINE_EMPTY( _Malloc_GC_list );
> +RTEMS_INTERRUPT_LOCK_DEFINE( static, _Malloc_GC_lock, "Malloc GC" )
> +static void *_Malloc_Get_deferred_free( void )
> + rtems_interrupt_lock_context lock_context;
> + void *p;
> + rtems_interrupt_lock_acquire( &_Malloc_GC_lock, &lock_context );
> + p = rtems_chain_get_unprotected( &_Malloc_GC_list );
> + rtems_interrupt_lock_release( &_Malloc_GC_lock, &lock_context );
> + return p;
> +void _Malloc_Process_deferred_frees( void )
> + rtems_chain_node *to_be_freed;
> + * If some free's have been deferred, then do them now.
> + while ( ( to_be_freed = _Malloc_Get_deferred_free() ) != NULL ) {
> + free( to_be_freed );
> +static void _Malloc_Deferred_free( void *p )
> + rtems_chain_node *node;
> + node = (rtems_chain_node *) p;
> + rtems_chain_initialize_node( node );
> + rtems_chain_append_unprotected( &_Malloc_GC_list, node );
> void free(
> void *ptr
> diff --git a/cpukit/libcsupport/src/malloc_deferred.c b/cpukit/libcsupport/src/malloc_deferred.c
> index 62c231d2f8..f66dd54676 100644
> --- a/cpukit/libcsupport/src/malloc_deferred.c
> +++ b/cpukit/libcsupport/src/malloc_deferred.c
> @@ -27,14 +27,9 @@
> -#include <rtems/chain.h>
> #include <rtems/score/sysstate.h>
> #include <rtems/score/threaddispatch.h>
> -static RTEMS_CHAIN_DEFINE_EMPTY( _Malloc_GC_list );
> -RTEMS_INTERRUPT_LOCK_DEFINE( static, _Malloc_GC_lock, "Malloc GC" )
> Malloc_System_state _Malloc_System_state( void )
> System_state_Codes state = _System_state_Get();
> @@ -52,28 +47,12 @@ Malloc_System_state _Malloc_System_state( void )
> -static void *_Malloc_Get_deferred_free( void )
> - rtems_interrupt_lock_context lock_context;
> - void *p;
> - rtems_interrupt_lock_acquire( &_Malloc_GC_lock, &lock_context );
> - p = rtems_chain_get_unprotected( &_Malloc_GC_list );
> - rtems_interrupt_lock_release( &_Malloc_GC_lock, &lock_context );
> - return p;
> -void _Malloc_Process_deferred_frees( void )
> +RTEMS_WEAK void _Malloc_Process_deferred_frees( void )
> - rtems_chain_node *to_be_freed;
> - * If some free's have been deferred, then do them now.
> + * Do nothing by default. If free() is used by the application, then a
> + * strong implementation of this function will be provided.
> - while ( ( to_be_freed = _Malloc_Get_deferred_free() ) != NULL ) {
> - free( to_be_freed );
> void *rtems_heap_allocate_aligned_with_boundary(
> @@ -125,19 +104,6 @@ void *rtems_heap_allocate_aligned_with_boundary(
> return p;
> -void _Malloc_Deferred_free( void *p )
> - rtems_chain_node *node;
> - node = (rtems_chain_node *) p;
> - rtems_chain_initialize_node( node );
> - rtems_chain_append_unprotected( &_Malloc_GC_list, node );
> void *rtems_malloc( size_t size )
> if ( size == 0 ) {
> diff --git a/cpukit/libcsupport/src/malloc_p.h b/cpukit/libcsupport/src/malloc_p.h
> index f3715a9966..cb26050ff1 100644
> --- a/cpukit/libcsupport/src/malloc_p.h
> +++ b/cpukit/libcsupport/src/malloc_p.h
> @@ -25,8 +25,6 @@ typedef enum {
> Malloc_System_state _Malloc_System_state( void );
> -void _Malloc_Deferred_free( void * );
> void _Malloc_Process_deferred_frees( void );
> #ifdef __cplusplus
> 2.26.2
> devel mailing list
> devel at rtems.org
