[PATCH v2 1/2] Changed ARM fenv support similar to X86_64
Eshan dhawan
eshandhawan51 at gmail.com
Thu Jul 23 19:41:37 UTC 2020
Removed soft float files
arm/fenv.c: Fix use of defines and format
Fix the build. Remove superfluous code. Remove parameter names in
the header file. Move implementation details out of the header file.
Patch by: Eshan Dhawan <eshandhawan51 at gmail.com> and
Sebastain huber <sebastian.huber at embedded-brains.de>
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
newlib/libc/machine/arm/machine/fenv-mangle.h | 53 ---
.../libc/machine/arm/machine/fenv-softfloat.h | 187 ----------
newlib/libc/machine/arm/machine/fenv-vfp.h | 187 ----------
newlib/libc/machine/arm/sys/fenv.h | 66 +---
newlib/libm/machine/arm/Makefile.am | 4 +-
newlib/libm/machine/arm/Makefile.in | 19 +-
newlib/libm/machine/arm/fenv-softfp.c | 32 --
newlib/libm/machine/arm/fenv-vfp.c | 32 --
newlib/libm/machine/arm/fenv.c | 319 ++++++------------
9 files changed, 127 insertions(+), 772 deletions(-)
delete mode 100644 newlib/libc/machine/arm/machine/fenv-mangle.h
delete mode 100644 newlib/libc/machine/arm/machine/fenv-softfloat.h
delete mode 100644 newlib/libc/machine/arm/machine/fenv-vfp.h
delete mode 100644 newlib/libm/machine/arm/fenv-softfp.c
delete mode 100644 newlib/libm/machine/arm/fenv-vfp.c
diff --git a/newlib/libc/machine/arm/machine/fenv-mangle.h b/newlib/libc/machine/arm/machine/fenv-mangle.h
deleted file mode 100644
index 476f7b20c..000000000
--- a/newlib/libc/machine/arm/machine/fenv-mangle.h
+++ /dev/null
@@ -1,53 +0,0 @@
- * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * $FreeBSD$
-#ifdef _FENV_MANGLE_H_
-#error Only include fenv-mangle.h once
-#endif
-#define _FENV_MANGLE_H_
-#ifndef FENV_MANGLE
-#error FENV_MANGLE is undefined
-#endif
-#define feclearexcept FENV_MANGLE(feclearexcept)
-#define fegetexceptflag FENV_MANGLE(fegetexceptflag)
-#define fesetexceptflag FENV_MANGLE(fesetexceptflag)
-#define feraiseexcept FENV_MANGLE(feraiseexcept)
-#define fetestexcept FENV_MANGLE(fetestexcept)
-#define fegetround FENV_MANGLE(fegetround)
-#define fesetround FENV_MANGLE(fesetround)
-#define fegetenv FENV_MANGLE(fegetenv)
-#define feholdexcept FENV_MANGLE(feholdexcept)
-#define fesetenv FENV_MANGLE(fesetenv)
-#define feupdateenv FENV_MANGLE(feupdateenv)
-#define feenableexcept FENV_MANGLE(feenableexcept)
-#define fedisableexcept FENV_MANGLE(fedisableexcept)
-#define fegetexcept FENV_MANGLE(fegetexcept)
diff --git a/newlib/libc/machine/arm/machine/fenv-softfloat.h b/newlib/libc/machine/arm/machine/fenv-softfloat.h
index 5d33e18d0..000000000
--- a/newlib/libc/machine/arm/machine/fenv-softfloat.h
+++ /dev/null
@@ -1,187 +0,0 @@
- * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
- * Copyright (c) 2004-2011 David Schultz <das at FreeBSD.ORG>
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#ifndef _SYS_FENV_H_
-#error "This file is meant to be included only by <sys/fenv.h>."
-#endif
-/* the file can be added from architecture specific fenv.h file found in
- *libc/sys/arch/sys *
- * This file implements the functionality of <fenv.h> on platforms that
- * lack an FPU and use softfloat in libc for floating point. To use it,
- * you must write an <fenv.h> that provides the following:
- * - a typedef for fenv_t, which may be an integer or struct type
- * - a typedef for fexcept_t (XXX This file assumes fexcept_t is a
- * simple integer type containing the exception mask.)
- * - definitions of FE_* constants for the five exceptions and four
- * rounding modes in IEEE 754, as described in fenv(3)
- * - a definition, and the corresponding external symbol, for FE_DFL_ENV
- * - a macro __set_env(env, flags, mask, rnd), which sets the given fenv_t
- * from the exception flags, mask, and rounding mode
- * - macros __env_flags(env), __env_mask(env), and __env_round(env), which
- * extract fields from an fenv_t
- * - a definition of __fenv_static
- * If the architecture supports an optional FPU, it's recommended that you
- * define fenv_t and fexcept_t to match the hardware ABI. Otherwise, it
- * doesn't matter how you define them.
-#include <errno.h>
-int __softfloat_float_exception_flags;
-int __softfloat_float_exception_mask;
-int __softfloat_float_rounding_mode;
-__fenv_static inline int
-feclearexcept(int excepts)
- __softfloat_float_exception_flags &= ~excepts;
- return (0);
-fegetexceptflag(fexcept_t *flagp, int excepts)
- *flagp = __softfloat_float_exception_flags & excepts;
- return (0);
-fesetexceptflag(const fexcept_t *flagp, int excepts)
- __softfloat_float_exception_flags |= *flagp & excepts;
- return (0);
-feraiseexcept(int excepts)
- return (excepts ? -ENOTSUP : 0);
-fetestexcept(int excepts)
- return (__softfloat_float_exception_flags & excepts);
-fegetround(void)
- return (__softfloat_float_rounding_mode);
-fesetround(int round)
- __softfloat_float_rounding_mode = round;
- return (0);
-fegetenv(fenv_t *envp)
- __set_env(*envp, __softfloat_float_exception_flags,
- __softfloat_float_exception_mask, __softfloat_float_rounding_mode);
- return (0);
-feholdexcept(fenv_t *envp)
- fenv_t __env;
- fegetenv(envp);
- __softfloat_float_exception_flags = 0;
- __softfloat_float_exception_mask = 0;
- return (0);
-fesetenv(const fenv_t *envp)
- __softfloat_float_exception_flags = __env_flags(*envp);
- __softfloat_float_exception_mask = __env_mask(*envp);
- __softfloat_float_rounding_mode = __env_round(*envp);
- return (0);
-feupdateenv(const fenv_t *envp)
- int __oflags = __softfloat_float_exception_flags;
- fesetenv(envp);
- feraiseexcept(__oflags);
- return (0);
-#if __BSD_VISIBLE
-/* We currently provide no external definitions of the functions below. */
-feenableexcept(int __mask)
- int __omask = __softfloat_float_exception_mask;
- __softfloat_float_exception_mask |= __mask;
- return (__omask);
-fedisableexcept(int __mask)
- __softfloat_float_exception_mask &= ~__mask;
- return (__omask);
-fegetexcept(void)
- return (__softfloat_float_exception_mask);
-#endif /* __BSD_VISIBLE */
diff --git a/newlib/libc/machine/arm/machine/fenv-vfp.h b/newlib/libc/machine/arm/machine/fenv-vfp.h
index 25d71f3ab..000000000
--- a/newlib/libc/machine/arm/machine/fenv-vfp.h
+++ /dev/null
@@ -1,187 +0,0 @@
- * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#define vmrs_fpscr(__r) __asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
-#define vmsr_fpscr(__r) __asm __volatile("vmsr fpscr, %0" : : "r"(__r))
-#define _FPU_MASK_SHIFT 8
-__fenv_static inline int feclearexcept(int excepts)
- fexcept_t __fpsr;
- vmrs_fpscr(__fpsr);
- __fpsr &= ~excepts;
- vmsr_fpscr(__fpsr);
- return (0);
- fexcept_t __fpsr;
- *flagp = __fpsr & excepts;
- return (0);
- fexcept_t __fpsr;
- __fpsr |= *flagp & excepts;
- return (0);
- fexcept_t __ex = excepts;
- fesetexceptflag(&__ex, excepts); /* XXX */
- return (0);
- fexcept_t __fpsr;
- return (__fpsr & excepts);
-fegetround(void)
- fenv_t __fpsr;
- return (__fpsr & _ROUND_MASK);
- fenv_t __fpsr;
- __fpsr &= ~(_ROUND_MASK);
- __fpsr |= round;
- return (0);
- vmrs_fpscr(*envp);
- return (0);
- fenv_t __env;
- vmrs_fpscr(__env);
- *envp = __env;
- __env &= ~(FE_ALL_EXCEPT);
- vmsr_fpscr(__env);
- return (0);
- vmsr_fpscr(*envp);
- return (0);
- fexcept_t __fpsr;
- feraiseexcept(__fpsr & FE_ALL_EXCEPT);
- return (0);
-#if __BSD_VISIBLE
- fenv_t __old_fpsr, __new_fpsr;
- vmrs_fpscr(__old_fpsr);
- __new_fpsr = __old_fpsr |
- ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
- vmsr_fpscr(__new_fpsr);
- return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
- __new_fpsr = __old_fpsr &
- ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
-fegetexcept(void)
- fenv_t __fpsr;
- return (__fpsr & FE_ALL_EXCEPT);
diff --git a/newlib/libc/machine/arm/sys/fenv.h b/newlib/libc/machine/arm/sys/fenv.h
index 740995a1a..70bd57be4 100644
--- a/newlib/libc/machine/arm/sys/fenv.h
+++ b/newlib/libc/machine/arm/sys/fenv.h
@@ -38,10 +38,6 @@
extern "C" {
#endif
-#ifndef __fenv_static
-#define __fenv_static static
-#endif
typedef int fenv_t;
typedef int fexcept_t;
@@ -51,7 +47,7 @@ typedef int fexcept_t;
#define FE_OVERFLOW 0x0004
#define FE_UNDERFLOW 0x0008
#define FE_INEXACT 0x0010
-#ifdef __ARM_PCS_VFP
+#ifndef __SOFTFP__
#define FE_DENORMAL 0x0080
#define FE_ALL_EXCEPT (FE_DIVBYZERO | FE_INEXACT | \
FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW | FE_DENORMAL)
@@ -60,61 +56,33 @@ typedef int fexcept_t;
FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW)
#endif
/* Rounding modes */
-#define VFP_FE_TONEAREST 0x00000000
-#define VFP_FE_UPWARD 0x00400000
-#define VFP_FE_DOWNWARD 0x00800000
-#define VFP_FE_TOWARDZERO 0x00c00000
-#define FE_TONEAREST VFP_FE_TONEAREST
-#define FE_UPWARD VFP_FE_UPWARD
-#define FE_DOWNWARD VFP_FE_DOWNWARD
-#define FE_TOWARDZERO VFP_FE_TOWARDZERO
-#else
-#define FE_TONEAREST 0x0000
-#define FE_TOWARDZERO 0x0001
-#define FE_UPWARD 0x0002
-#define FE_DOWNWARD 0x0003
-#endif
-#define _ROUND_MASK (FE_TONEAREST | FE_DOWNWARD | \
- FE_UPWARD | FE_TOWARDZERO)
+#define FE_TONEAREST 0x00000000
+#define FE_UPWARD 0x00400000
+#define FE_DOWNWARD 0x00800000
+#define FE_TOWARDZERO 0x00c00000
/* Default floating-point environment */
extern const fenv_t *_fe_dfl_env;
#define FE_DFL_ENV (_fe_dfl_env)
-/* We need to be able to map status flag positions to mask flag positions */
-#ifndef __ARM_PCS_VFP
-#define _FPUSW_SHIFT 16
-#define _ENABLE_MASK (FE_ALL_EXCEPT << _FPUSW_SHIFT)
-#endif
-int feclearexcept(int excepts);
-int fegetexceptflag(fexcept_t *flagp, int excepts);
-int fesetexceptflag(const fexcept_t *flagp, int excepts);
-int feraiseexcept(int excepts);
-int fetestexcept(int excepts);
+int feclearexcept(int);
+int fegetexceptflag(fexcept_t *, int);
+int fesetexceptflag(const fexcept_t *, int);
+int feraiseexcept(int);
+int fetestexcept(int);
int fegetround(void);
-int fesetround(int round);
-int fegetenv(fenv_t *envp);
-int feholdexcept(fenv_t *envp);
-int fesetenv(const fenv_t *envp);
-int feupdateenv(const fenv_t *envp);
+int fesetround(int);
+int fegetenv(fenv_t *);
+int feholdexcept(fenv_t *);
+int fesetenv(const fenv_t *);
+int feupdateenv(const fenv_t *);
#if __BSD_VISIBLE
-int feenableexcept(int __mask);
-int fedisableexcept(int __mask);
+int feenableexcept(int);
+int fedisableexcept(int);
int fegetexcept(void);
#ifdef __cplusplus
#endif
diff --git a/newlib/libm/machine/arm/Makefile.am b/newlib/libm/machine/arm/Makefile.am
index a64ee59d5..180a37f44 100644
--- a/newlib/libm/machine/arm/Makefile.am
+++ b/newlib/libm/machine/arm/Makefile.am
@@ -32,9 +32,7 @@ LIB_SOURCES = \
fesetexceptflag.c \
fesetround.c \
fetestexcept.c \
- feupdateenv.c \
- fenv-vfp.c \
- fenv-softfp.c
+ feupdateenv.c
noinst_LIBRARIES = lib.a
diff --git a/newlib/libm/machine/arm/Makefile.in b/newlib/libm/machine/arm/Makefile.in
index ecfa684e7..aa23dd4d5 100644
--- a/newlib/libm/machine/arm/Makefile.in
+++ b/newlib/libm/machine/arm/Makefile.in
@@ -83,8 +83,7 @@ am__objects_1 = lib_a-e_sqrt.$(OBJEXT) lib_a-ef_sqrt.$(OBJEXT) \
lib_a-fenv.$(OBJEXT) lib_a-feraiseexcept.$(OBJEXT) \
lib_a-fesetenv.$(OBJEXT) lib_a-fesetexceptflag.$(OBJEXT) \
lib_a-fesetround.$(OBJEXT) lib_a-fetestexcept.$(OBJEXT) \
- lib_a-feupdateenv.$(OBJEXT) lib_a-fenv-vfp.$(OBJEXT) \
- lib_a-fenv-softfp.$(OBJEXT)
+ lib_a-feupdateenv.$(OBJEXT)
am_lib_a_OBJECTS = $(am__objects_1)
lib_a_OBJECTS = $(am_lib_a_OBJECTS)
DEFAULT_INCLUDES = -I. at am__isrc@
@@ -237,9 +236,7 @@ LIB_SOURCES = \
fesetexceptflag.c \
fesetround.c \
fetestexcept.c \
- feupdateenv.c \
- fenv-vfp.c \
- fenv-softfp.c
+ feupdateenv.c
lib_a_SOURCES = $(LIB_SOURCES)
@@ -479,18 +476,6 @@ lib_a-feupdateenv.o: feupdateenv.c
lib_a-feupdateenv.obj: feupdateenv.c
$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-feupdateenv.obj `if test -f 'feupdateenv.c'; then $(CYGPATH_W) 'feupdateenv.c'; else $(CYGPATH_W) '$(srcdir)/feupdateenv.c'; fi`
-lib_a-fenv-vfp.o: fenv-vfp.c
- $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo '$(srcdir)/'`fenv-vfp.c
-lib_a-fenv-vfp.obj: fenv-vfp.c
- $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-vfp.obj `if test -f 'fenv-vfp.c'; then $(CYGPATH_W) 'fenv-vfp.c'; else $(CYGPATH_W) '$(srcdir)/fenv-vfp.c'; fi`
-lib_a-fenv-softfp.o: fenv-softfp.c
- $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.o `test -f 'fenv-softfp.c' || echo '$(srcdir)/'`fenv-softfp.c
-lib_a-fenv-softfp.obj: fenv-softfp.c
- $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) $(lib_a_CFLAGS) $(CFLAGS) -c -o lib_a-fenv-softfp.obj `if test -f 'fenv-softfp.c'; then $(CYGPATH_W) 'fenv-softfp.c'; else $(CYGPATH_W) '$(srcdir)/fenv-softfp.c'; fi`
ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
unique=`for i in $$list; do \
diff --git a/newlib/libm/machine/arm/fenv-softfp.c b/newlib/libm/machine/arm/fenv-softfp.c
index a576cc1b2..000000000
--- a/newlib/libm/machine/arm/fenv-softfp.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#define FENV_MANGLE(x) __softfp_ ##x
-#include <machine/fenv-mangle.h>
-#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv-vfp.c b/newlib/libm/machine/arm/fenv-vfp.c
index 297e81296..000000000
--- a/newlib/libm/machine/arm/fenv-vfp.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#define FENV_MANGLE(x) __vfp_ ##x
-#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv.c b/newlib/libm/machine/arm/fenv.c
index 5b61ab81f..0735cd1c5 100644
--- a/newlib/libm/machine/arm/fenv.c
+++ b/newlib/libm/machine/arm/fenv.c
@@ -1,7 +1,7 @@
- * Copyright (c) 2004 David Schultz <das at FreeBSD.ORG>
+ * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
@@ -29,300 +29,195 @@
* $FreeBSD$
#include <fenv.h>
-#include <machine/acle-compat.h>
-#if __ARM_ARCH >= 6
-#define FENV_ARMv6
-#endif
-/* When SOFTFP_ABI is defined we are using the softfp ABI. */
-#if defined(__VFP_FP__) && !defined(__ARM_PCS_VFP)
-#define SOFTFP_ABI
+#ifndef __SOFTFP__
+#define vmrs_fpscr(__r) __asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
+#define vmsr_fpscr(__r) __asm __volatile("vmsr fpscr, %0" : : "r"(__r))
+#define _FPU_MASK_SHIFT 8
+#define _ROUND_MASK (FE_TONEAREST | FE_DOWNWARD | \
+ FE_UPWARD | FE_TOWARDZERO)
#endif
- * Hopefully the system ID byte is immutable, so it's valid to use
- * this as a default environment.
fenv_t __fe_dfl_env = { 0 };
const fenv_t *_fe_dfl_env = &__fe_dfl_env;
-#endif
-/* If this is a non-mangled softfp version special processing is required */
-#if defined(FENV_MANGLE) || !defined(SOFTFP_ABI) || !defined(FENV_ARMv6)
- * The following macros map between the softfloat emulator's flags and
- * the hardware's FPSR. The hardware this file was written for doesn't
- * have rounding control bits, so we stick those in the system ID byte.
-#define __set_env(env, flags, mask, rnd) env = ((flags) \
- | (mask)<<_FPUSW_SHIFT \
- | (rnd) << 24)
-#define __env_flags(env) ((env) & FE_ALL_EXCEPT)
-#define __env_mask(env) (((env) >> _FPUSW_SHIFT) \
- & FE_ALL_EXCEPT)
-#define __env_round(env) (((env) >> 24) & _ROUND_MASK)
-#include <machine/fenv-softfloat.h>
-#else /* __ARM_PCS_VFP PRESENT */
-#include <machine/fenv-vfp.h>
-#endif /* __ARM_PCS_VFP */
-#ifdef __GNUC_GNU_INLINE__
-#error "This file must be compiled with C99 'inline' semantics"
-#endif
-extern inline int feclearexcept(int excepts);
-extern inline int fegetexceptflag(fexcept_t *flagp, int excepts);
-extern inline int fesetexceptflag(const fexcept_t *flagp, int excepts);
-extern inline int feraiseexcept(int excepts);
-extern inline int fetestexcept(int excepts);
-extern inline int fegetround(void);
-extern inline int fesetround(int round);
-extern inline int fegetenv(fenv_t *envp);
-extern inline int feholdexcept(fenv_t *envp);
-extern inline int fesetenv(const fenv_t *envp);
-extern inline int feupdateenv(const fenv_t *envp);
-extern inline int feenableexcept(int __mask);
-extern inline int fedisableexcept(int __mask);
-extern inline int fegetexcept(void);
-#else /* !FENV_MANGLE && SOFTFP_ABI */
-/* Set by libc when the VFP unit is enabled */
-int _libc_arm_fpu_present;
-int __softfp_feclearexcept(int excepts);
-int __softfp_fegetexceptflag(fexcept_t *flagp, int excepts);
-int __softfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
-int __softfp_feraiseexcept(int excepts);
-int __softfp_fetestexcept(int excepts);
-int __softfp_fegetround(void);
-int __softfp_fesetround(int round);
-int __softfp_fegetenv(fenv_t *envp);
-int __softfp_feholdexcept(fenv_t *envp);
-int __softfp_fesetenv(const fenv_t *envp);
-int __softfp_feupdateenv(const fenv_t *envp);
-int __softfp_feenableexcept(int __mask);
-int __softfp_fedisableexcept(int __mask);
-int __softfp_fegetexcept(void);
-int __vfp_feclearexcept(int excepts);
-int __vfp_fegetexceptflag(fexcept_t *flagp, int excepts);
-int __vfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
-int __vfp_feraiseexcept(int excepts);
-int __vfp_fetestexcept(int excepts);
-int __vfp_fegetround(void);
-int __vfp_fesetround(int round);
-int __vfp_fegetenv(fenv_t *envp);
-int __vfp_feholdexcept(fenv_t *envp);
-int __vfp_fesetenv(const fenv_t *envp);
-int __vfp_feupdateenv(const fenv_t *envp);
-int __vfp_feenableexcept(int __mask);
-int __vfp_fedisableexcept(int __mask);
-int __vfp_fegetexcept(void);
-static int
-__softfp_round_to_vfp(int round)
- switch (round) {
- case FE_TONEAREST:
- default:
- return VFP_FE_TONEAREST;
- case FE_TOWARDZERO:
- return VFP_FE_TOWARDZERO;
- case FE_UPWARD:
- return VFP_FE_UPWARD;
- case FE_DOWNWARD:
- return VFP_FE_DOWNWARD;
-static int
-__softfp_round_from_vfp(int round)
- switch (round) {
- case VFP_FE_TONEAREST:
- default:
- return FE_TONEAREST;
- case VFP_FE_TOWARDZERO:
- return FE_TOWARDZERO;
- case VFP_FE_UPWARD:
- return FE_UPWARD;
- case VFP_FE_DOWNWARD:
- return FE_DOWNWARD;
+#ifndef __SOFTFP__
+ fexcept_t __fpsr;
- if (_libc_arm_fpu_present)
- __vfp_feclearexcept(excepts);
- __softfp_feclearexcept(excepts);
+ vmrs_fpscr(__fpsr);
+ __fpsr &= ~excepts;
+ vmsr_fpscr(__fpsr);
+#endif
return (0);
- fexcept_t __vfp_flagp;
- __vfp_flagp = 0;
- __vfp_fegetexceptflag(&__vfp_flagp, excepts);
- __softfp_fegetexceptflag(flagp, excepts);
- *flagp |= __vfp_flagp;
+#ifndef __SOFTFP__
+ fexcept_t __fpsr;
+ __fpsr |= *flagp & excepts;
+#endif
return (0);
+#ifndef __SOFTFP__
+ fexcept_t __fpsr;
- __vfp_fesetexceptflag(flagp, excepts);
- __softfp_fesetexceptflag(flagp, excepts);
+#endif
return (0);
+#ifndef __SOFTFP__
+ fexcept_t __ex = excepts;
- __vfp_feraiseexcept(excepts);
- __softfp_feraiseexcept(excepts);
+ fesetexceptflag(&__ex, excepts);
+#endif
return (0);
- int __got_excepts;
+#ifndef __SOFTFP__
+ fexcept_t __fpsr;
- __got_excepts = 0;
- __got_excepts = __vfp_fetestexcept(excepts);
- __got_excepts |= __softfp_fetestexcept(excepts);
- return (__got_excepts);
+ return (__fpsr & excepts);
+#else
+ return (0);
+#endif
+#ifndef __SOFTFP__
+ fenv_t __fpsr;
- return __softfp_round_from_vfp(__vfp_fegetround());
- return __softfp_fegetround();
+ return (__fpsr & _ROUND_MASK);
+#else
+#ifdef FE_TONEAREST
+ return (FE_TONEAREST);
+#else
+ return (0);
+#endif
+#endif
+#ifndef __SOFTFP__
+ fenv_t __fpsr;
- __vfp_fesetround(__softfp_round_to_vfp(round));
- __softfp_fesetround(round);
+ __fpsr &= ~(_ROUND_MASK);
+ __fpsr |= round;
+#endif
return (0);
- fenv_t __vfp_envp;
- __vfp_envp = 0;
- __vfp_fegetenv(&__vfp_envp);
- __softfp_fegetenv(envp);
- *envp |= __vfp_envp;
+#ifndef __SOFTFP__
+ vmrs_fpscr(*envp);
+#endif
return (0);
- __vfp_envp = 0;
- __vfp_feholdexcept(&__vfp_envp);
- __softfp_feholdexcept(envp);
+#ifndef __SOFTFP__
+ fenv_t __env;
+ vmrs_fpscr(__env);
+ *envp = __env;
+ __env &= ~(FE_ALL_EXCEPT);
+ vmsr_fpscr(__env);
+#endif
return (0);
- __vfp_fesetenv(envp);
- __softfp_fesetenv(envp);
+#ifndef __SOFTFP__
+ vmsr_fpscr(*envp);
+#endif
return (0);
+#ifndef __SOFTFP__
+ fexcept_t __fpsr;
- __vfp_feupdateenv(envp);
- __softfp_feupdateenv(envp);
+ feraiseexcept(__fpsr & FE_ALL_EXCEPT);
+#else
+#if defined(FE_NOMASK_ENV) && FE_ALL_EXCEPT != 0
+ if (envp == FE_NOMASK_ENV)
+ return (1);
+#endif
+#endif
return (0);
- int __unmasked;
- __unmasked = 0;
- __unmasked = __vfp_feenableexcept(__mask);
- __unmasked |= __softfp_feenableexcept(__mask);
+#ifndef __SOFTFP__
+ fenv_t __old_fpsr, __new_fpsr;
- return (__unmasked);
+ vmrs_fpscr(__old_fpsr);
+ __new_fpsr = __old_fpsr |
+ ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+ vmsr_fpscr(__new_fpsr);
+ return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
+#else
+ return (0);
+#endif
- int __unmasked;
+#ifndef __SOFTFP__
- __unmasked = 0;
- __unmasked = __vfp_fedisableexcept(__mask);
- __unmasked |= __softfp_fedisableexcept(__mask);
+ __new_fpsr = __old_fpsr &
+ ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+#else
+ return (0);
+#endif
- int __unmasked;
- __unmasked = 0;
- __unmasked = __vfp_fegetexcept();
- __unmasked |= __softfp_fegetexcept();
+#ifndef __SOFTFP__
+ fenv_t __fpsr;
+ return (__fpsr & FE_ALL_EXCEPT);
+#else
+ return (0);
#endif
2.17.1
